Welcome to the North American Subaru Impreza Owners Club Monday March 18, 2019
Old 09-16-2015, 12:05 AM   #126
Joshwrx04
Member#: 135429
'05 Cornfed CGM STi
94 Legacy SS
Originally Posted by outfrontmotorsports View Post
The remaining thread from stock is .010 which is .005" per side. then the tap goes down the hole and removes 90% of the material in this area, thus it would be undetectable by the eye and is really splitting hairs. in fact I will make a video or show some pics in the near future to show and explain this.
so no there is not an issue with stud design. When you called and talked to the shop you talked to our shortblock assembler. Maybe I wasn't here but I am the one that does the tapping. I can not know what you two discussed about the procedure. We use a mill to do the tapping, I do not know what your shop uses. You can have 5 guys tap 5 holes and they could all be different in quality such as side loading a tap, pressure, cutting oils, etc. Timeserting is the only solution for what you have at this point. timesert makes a super long 1.5" insert, is that what is getting installed? , I suggest to remove the upper lip of the insert so that the counter boring process is eliminated. Installing all 12 timeserts should be a $300-600 range depending on the shop, their speed, etc.
Doing this is not normal nor have we ever seen a soft block yet because it's only a guess at this point. remember the only one we have had an issue with is getting timeserts to and we don't get it back
Look, we had a customer that wanted to do 14mm studs, we told him we would not do the job as we are not set up for the tapping. he went to another local shop. we get it back to do the boreing with deck plates. one of the studs pulled out! he went back to the shop and they would do nothing for him, they had charged him $850 to tap the block and then told him to pound sand and that it couldn't be the machining anything is possible.
good luck with your project
You are now!
I want to know what conclusion you find about my block
Joshwrx04 is offline   Reply With Quote
Old 09-17-2015, 12:42 PM   #127
spoolinsti05
Member#: 108051
2005 TickingTimeBomb
Jr tuned TT Sleeved
Just curious do these engines that are ripping studs out utilize dual avcs?
spoolinsti05 is offline   Reply With Quote
Old 09-17-2015, 02:20 PM   #128
Shortpersonbk
Member#: 319017
15 Prius
2JZ miata Death Trap
Mine was, one of juniors was, but cam only has single avcs though so that theory is kinda bunk.
Shortpersonbk is offline   Reply With Quote
Old 09-17-2015, 02:38 PM   #129
Joshwrx04
Member#: 135429
'05 Cornfed CGM STi
94 Legacy SS
Mine is single avcs
Old 09-18-2015, 12:12 AM   #130
spoolinsti05
Member#: 108051
Jr tuned TT Sleeved
Default Outfront 1/2" headstuds pulling threads at 21psi
True guess it's just cylinder pressures then I must be lucky I guess with the arp2000 that hold 42psi
Old 09-18-2015, 06:08 AM   #131
Shortpersonbk
Member#: 319017
15 Prius
Arp2000s are not the ones we are ripping out. Those will stretch before they pull out the threads on the block.
OP had it happen without the car being pushed or really tuned at all. Seems more like a machining or install error vs a cyl pressure issue.
Old 09-18-2015, 12:44 PM   #132
spoolinsti05
Member#: 108051
Jr tuned TT Sleeved
I'd like to agree with you on that but we would need to see the details. Is that what happened when your 625s ripped out too?
Old 12-21-2015, 02:54 PM   #133
KinkSti
Member#: 414850
2004 WRX STI
Originally Posted by Joshwrx04 View Post
I had a perfectly good set of l19's i should have kept. Lol
Yooo! Im selling my new l19s. I bought them, then I wanted 625+. So pm me!
KinkSti is offline   Reply With Quote
Old 12-21-2015, 08:52 PM   #134
Joshwrx04
Member#: 135429
'05 Cornfed CGM STi
94 Legacy SS
I have 625's also. Motor is already in the car. Thanks tho
Old 12-21-2015, 08:58 PM   #135
KinkSti
Member#: 414850
2004 WRX STI
What you running? They holding up?
Old 12-22-2015, 12:33 AM   #136
Joshwrx04
Member#: 135429
'05 Cornfed CGM STi
94 Legacy SS
Haven't turned it up yet on e85 and 30 psi. But they will do just fine. People have pushed 40 psi with them
Old 12-22-2015, 07:28 AM   #137
spoolinsti05
Member#: 108051
Jr tuned TT Sleeved
42psi on 6266 here with arp2000 and copper orings.
Old 12-22-2015, 09:29 AM   #138
KinkSti
Member#: 414850
2004 WRX STI
What numbers you making? Impressive. I am doing 625 with orings and 6266 but if I could sell my 6266 pte, then 6766 will do
Old 12-22-2015, 09:30 AM   #139
KinkSti
Member#: 414850
2004 WRX STI
How many runs in 42 psi already? You daily it?
Old 12-22-2015, 11:37 PM   #140
mattistrouble
Member#: 377637
What headstuds would you guys recommend? ARP 625+ or IAG 1/2 headstuds, going to pushing around 43psi on a 6466.
mattistrouble is offline   Reply With Quote
Old 12-23-2015, 08:18 AM   #141
spoolinsti05
Member#: 108051
Jr tuned TT Sleeved
Yeah Daily, few dozen and few dozen 3rd gear pulls. I put a gen2 6466 I'm only on 28psi for now went 136mph with new 6466 haven't went to track on 6266 @42psi
Old 12-23-2015, 09:04 AM   #142
KinkSti
Member#: 414850
2004 WRX STI
Made more power with 6466
Old 12-23-2015, 12:55 PM   #143
spoolinsti05
Member#: 108051
Jr tuned TT Sleeved
Idk still hasn't been re tuned for 6466 pushed thrust bearing after p&l triple disc install and spun rod #2
Old 01-28-2016, 11:34 PM   #144
linkubus06
Member#: 335449
07 WRX 20G 6MT
12 CTS-V Sedan 6MT
IAG started using 14mm studs now...hmmm
linkubus06 is offline   Reply With Quote
Old 01-29-2016, 05:57 PM   #145
Razgeiz
Member#: 358782
2013 STi
They use both 1/2 and 14mm
Razgeiz is offline   Reply With Quote
Old 01-25-2019, 03:23 PM   #146
Elfrenm
Member#: 437557
IAG 14mm
Elfrenm is offline   Reply With Quote
Old 01-25-2019, 09:14 PM   #147
SW00P_G
Member#: 5591
EJ257 Gt35r
Still rocking my Outfront 1/2" stud block. Running strong since 2013 with 30k+ miles!
SW00P_G is offline   Reply With Quote
Old 01-29-2019, 01:28 PM   #148
stu
Member#: 25768
2003 GEN 2 GTX35R
OFCD Bugeye Slowbaru
Me to, no problems with my 1/2 studs 4 years now.
stu is offline   Reply With Quote
Old 02-10-2019, 03:05 PM   #149
rexworx
Member#: 103232
GTX 3071R'd 11WRX
PPG,4.44,LSD,E85,6spdx3
1/2" studs is the way to go. Also the 14mm studs distort the factory block case a lot when torqued. It make the main tunnel funky.
Ian Hayes,
rexworx is offline   Reply With Quote
