Welcome to the North American Subaru Impreza Owners Club Monday March 25, 2019
Old 05-09-2017, 09:37 PM   #26
rocsubie77
Member#: 446285
Dude one bolt will not come out of corse the last one and I've tarted many things already. Any suggestions on how I can get it out without ****ing up the head?
rocsubie77 is offline   Reply With Quote
Old 05-10-2017, 08:48 AM   #27
Samurai Jack
Member#: 21145
2002 Enemy of Aku
Define " will not come out "?
Does the bolt just spin in place or are you unable to turn the bolt at all?
Samurai Jack is offline   Reply With Quote
Old 05-10-2017, 11:10 AM   #28
Bikelok
Member#: 254851
2002 WRX wagon 5mt
Like Samurai Jack said.
What do you mean not come out?
Spinning or just not turning?
Bikelok is offline   Reply With Quote
Old 05-10-2017, 06:09 PM   #29
rocsubie77
Member#: 446285
Bolt head got stripped. Tried to fit different socket, tried to cut slice and unscrew. Nothing so far. The way it sits I can't get a drill to easy out. Any suggestions? Obtw I'm at 115k, should I just pull it and do the head gaskets at same time? Need some help from someone who has been there
Old 05-10-2017, 09:20 PM   #30
Charlie-III
Member#: 30669
1998 Legacy 2.5GT
Silver Sleeper BK, 5MT
Sears, and other places, sells a screw extractor kit for rounded heads, just what you need in the space you have.
Old 05-10-2017, 09:23 PM   #31
Bikelok
Member#: 254851
2002 WRX wagon 5mt
If the bolt head is truly toast and will no way fit a socket/wrench, try a good quality vice grip and get it secured on there very well before even thinking of turning it.
If that does not work I would suggest giving something like this a try.
https://www.google.com/express/produ...Fcp8YgodkwsC_A
Hopefully the bolt is one of the upper ones. If not, you may have to lift the motor slightly to get the tool on the bolt head.
Last ditch effort if nothing else works, you may have to cut the head off, then vice grip it when the cover comes off.
There is no reason to do the head gasket unless it's leaking.
Old 05-10-2017, 09:27 PM   #32
Charlie-III
Member#: 30669
1998 Legacy 2.5GT
Post timing is everything......your link is what I was talking about.
Old 05-10-2017, 10:01 PM   #33
Bikelok
Member#: 254851
2002 WRX wagon 5mt
Yeah, they do work.
Old 05-11-2017, 02:41 PM   #34
rocsubie77
Member#: 446285
Originally Posted by Bikelok View Post
Yeah, they do work.
Thanks dude will try something soon as I can get it in the air
Old 09-30-2017, 08:30 PM   #35
fleezy
Member#: 436768
2004 WRX
did this today on my 04 rex. point of note: remove the coil pack bolt before trying to unclip the plugs. makes it 150x easier.
ps. those bottom bolts on the pass side, omg what a pain. in. the. ass!
fleezy is offline   Reply With Quote
Old 10-03-2017, 12:49 AM   #36
Bikelok
Member#: 254851
2002 WRX wagon 5mt
I made a edit with your suggestion.
Old 10-07-2017, 06:26 PM   #37
Scoobydoobydude
Member#: 468311
2003 WRX wagon
World Rally Blue!
Thanks for this im going to have to do this fairly soon (as soon as the parts come in the mail)
Scoobydoobydude is offline   Reply With Quote
Old 11-23-2017, 08:54 PM   #38
Bikelok
Member#: 254851
2002 WRX wagon 5mt
Bumping this because too many people are going to the dead thread on this topic.
Old 12-04-2017, 01:36 PM   #39
version2.5
Member#: 331537
2003 Bugeye WRX
Thanks For The Write up! Much Appreciated!
version2.5 is offline   Reply With Quote
Old 12-31-2017, 01:21 PM   #40
Swedaru
Member#: 171962
2005 92-X
Red
Default No need to raise motor?
I was surprised to see that you could get the passenger side bottom bolts out without raising the engine. My mechanic wants $800 to do the VCGs on both side, partly because he thinks he has to raise the motor. I almost think with your thread and photos I can do it myself!
Swedaru is offline   Reply With Quote
Old 12-31-2017, 01:32 PM   #41
Charlie-III
Member#: 30669
1998 Legacy 2.5GT
No big deal to raise the engine, pull the pitch stop and both motor mount nuts, big wood block between the oil pan and jack....raise engine.....
Done.
You can pry the engine either way to get more clearance.
Drop motor and reattach motor mount nuts and pitch stop.
Any questions?
You're in Boston, drive to NNJ (07456), I'll do both for $400 P&L for you......and still make money. You drive here and back. I have done that trip many, many times (field service with customers in south Boston, downtown Boston, Waltham, etc......).
Old 12-31-2017, 06:21 PM   #42
Vancouver98STi
Member#: 459287
1998 JDM Impreza STi
White GF8 wagon
Done.
Oooooo, that would scare me! Is there a reason why you'd prefer to raise the engine by jacking under the oil pan as opposed to under the tranny?
I ask only because I had to jack up my engine using a block of wood under the tranny (when I was updating my oil pan), and it worked fine. I'd be afraid that putting stress on the oil pan might deform it to some degree and/or cause a leak.
Vancouver98STi is offline   Reply With Quote
Old 12-31-2017, 07:24 PM   #43
Swedaru
Member#: 171962
2005 92-X
Red
tempting offer! I do go to Dobbs Ferry, NY on a pretty frequent basis and it appears that you are not far from there.
Old 01-01-2018, 03:34 AM   #44
Elbert Bass
Member#: 283429
2016 Fuji Sunfire 03
Done.
Any questions?
Better to lift on the differential housing. That also allows you to rock the engine side to side.
Elbert Bass is offline   Reply With Quote
Old 01-04-2018, 12:42 AM   #45
Bikelok
Member#: 254851
2002 WRX wagon 5mt
No need to lift the engine to do this.
As was mentioned by Charlie III and Elbert Bass, it can be jacked up a bit if you run into a problem and need more room.
If you are even moderately handy and have the right tools, most people could do this. If you want, you can even break it up and do one side one weekend, then the other side on another weekend. So you donít have to rush it.
Old 01-15-2018, 12:34 PM   #46
Soobaroo4ester
Member#: 224835
98 Forester S
Could you give me an idea of how much oil I will lose when I do this? I just changed my oil, don't know if I should just wait until my next interval to do this.
Soobaroo4ester is offline   Reply With Quote
Old 01-15-2018, 04:15 PM   #47
Bikelok
Member#: 254851
2002 WRX wagon 5mt
1/4-1/2 quart. Enough to make a good mess.
Old 01-15-2018, 05:10 PM   #48
Soobaroo4ester
Member#: 224835
98 Forester S
That's not too bad, I'll just buy another quart. Thanks!
Old 08-18-2018, 08:27 PM   #49
some dude
Member#: 100300
06 WRX
CGM
I'm did this gasket on passenger side.
I got all bolts off without moving the engine.
1 or 2 I used a wrench instead of a socket.
A ratcheting wrench would be THE tool, I used a plain old wrench and got the bolt(s) off in a few minutes each.
some dude is offline   Reply With Quote
Old 11-19-2018, 11:20 AM   #50
Bvl115
Member#: 429877
When applying the RTV sealant, is it best to apply bead from the tube tip, or spread with your finger?
Bvl115 is offline   Reply With Quote
