Welcome to the North American Subaru Impreza Owners Club Wednesday March 20, 2019
Old 03-21-2018, 05:01 PM   #1
Vaultorb
Member#: 351747
2003 WRX
Default 03 WRX Cold Start Squeal
Hey guys, so my Bugeye has recently been having a fairly loud squeal that only happens during cold starts. Usually only lasts a couple mins then once the car is warmed up I won't hear it again unless I leave my car sitting for awhile and basically do a cold start again.
I've already checked and replaced the simplest sources that I hoped could of been the cause however they were not:
-Checked/Tightened Power Steering/AC belts
-Replaced AC Idler Pulley
-Replaced both Power steering and AC belts
-Checked/Tightened the new belts
Unfortunately after checking all of those possible sources, my Bugeye still screams like a banshee on cold starts.
This is the only video I could find online that is identical to the exact same sound my Bugeye is making.
If anyone has had this issue or can steer me in the right direction for a solution that would be much appreciated. Thank you for your time!
Vaultorb is offline   Reply With Quote
Old 03-21-2018, 05:25 PM   #2
Charlie-III
Member#: 30669
1998 Legacy 2.5GT
Silver Sleeper BK, 5MT
Make a mark across the face of the crank pulley.
Then after you start it and hear the squeal, shut the engine off and see if the mark is still lined up.
The stock pulley is 2 metal pieces with a rubber isolator between them. Over time, the rubber can fail allowing the inner part to rotate inside the outer part until friction locks them together.
Making a mark across the face (engine off) allows you to watch their relative motion after a cold start.
If they're moving relative to each other, replace it. It's about $35 on RockAuto.
If the crank pulley looks fine, double check belt tension. Longest run of either belt should have about 3/8" deflection with moderate pushing.
Old 03-22-2018, 11:31 AM   #3
Vaultorb
Member#: 351747
2003 WRX
Thank you for the advice! Gonna try it out today and follow up with an update
Old 01-26-2019, 09:34 AM   #4
1ofeach
Member#: 8641
2002 WRX DayGlo Blue
2001 S2000, 2017 FoRS
Default 02 with the same sound
My 02 has the exact same sound, and I originally thought it was the belts. I went to replace the belts, and with them both removed, I started the car and the squeal was still there, so I know it's not a belt issue.
I'm thinking it is an idler or something from the timing belt, even though I had the timing belt replaced only 2-3 years ago.
Did you ever get to the bottom of your issue?
1ofeach is offline   Reply With Quote
Old 01-29-2019, 04:20 PM   #5
03jdmlegacy
Member#: 497001
My car has done this for years lol
Goes away after its warm and I've never cared beyond that
03jdmlegacy is offline   Reply With Quote
Old 01-30-2019, 11:24 AM   #6
SubLGT
Member#: 207528
2005 Legacy GT
Could be the starter motor. Cold start squeal is a common issue in Legacies. It can be cured temporarily with lubrication of the pinion shaft.
https://legacygt.com/forums/showthre...cs-218329.html
SubLGT is offline   Reply With Quote
Old 01-30-2019, 05:22 PM   #7
rezzy1776
Member#: 497157
Default Hi all new to the forum
Hey guys what's up ... new to the forum... my name is Nick and I currently own a 2016 sti limited... have had a few other subarus in the past including a 2005 sti and a forester.
To you problem... it is almost certainly your power steering... you prob have some air in the system... Jack up the front two wheels open the reservoir and turn the wheels back and forth.
rezzy1776 is offline   Reply With Quote
