Welcome to the North American Subaru Impreza Owners Club Friday March 22, 2019
Old 06-20-2018, 09:33 AM   #1
turboedbug
Member#: 155981
1969 vw bug
ej20k ems stinger 4424
Default filler metal
i was wondering if anyone had any suggestions on filler metal to use on a intake manifold.
i am planning to trim off all the casting stuff i dont need and fill in any holes.
i also have a nose cone on a trans that needs some filler metal as well.
turboedbug is offline   Reply With Quote
Old 06-20-2018, 10:48 AM   #2
isotopesope
Member#: 265783
2017 Forester XT
Niner ROS 9
i've used Loctite's Metal Magic steel epoxy putty with good results. i think they make an aluminum version as well? but i think the steel one works with aluminum...
http://www.loctite.sg/sea/content_da...0_FixMMSEN.pdf
isotopesope is offline   Reply With Quote
Old 06-21-2018, 08:58 AM   #3
danscomp
Member#: 305358
Tig weld?
danscomp is offline   Reply With Quote
Old 06-21-2018, 09:00 AM   #4
turboedbug
Member#: 155981
1969 vw bug
ya i plan to tig it up. was mainly curious to what type of filler metal people have been using.
Old 06-21-2018, 02:19 PM   #5
Charlie-III
Member#: 30669
1998 Legacy 2.5GT
Silver Sleeper BK, 5MT
For the trans nose cone, either get a new one (most are bolt on) or get a ToB with a repair sleeve. The sleeve is a snug fit on the old nose (may need to file down ridges on the nose) and a ToB with a slightly larger ID. This means you will ALWAYS need the different bearing so make note of it.
Welding may distort the tube and the ToB may hang up.
For filler, like pretty much any welding, it depends on the base metal. I would guess cast aluminum filler is different from plate material.
For the intake, I would an epoxy like stated earlier, let cure, then file and paint as needed. Little holes are not structural and if you get blobs inside, pretty hard/impossible to fix.
Charlie-III is online now   Reply With Quote
Old 06-21-2018, 02:25 PM   #6
turboedbug
Member#: 155981
1969 vw bug
i am welding the nose cone because i deleted the center diff.
had to shorten the housing to fit it into my vw beetle.
gonna tig it up.
just wondering what people use.
Old 06-21-2018, 02:32 PM   #7
Charlie-III
Member#: 30669
1998 Legacy 2.5GT
gonna tig it up.
Soooooo.......you shortend the TAIL CONE which allows the driveshaft go to the rear diff (which you don't have).
Nose cone is usually the front of the trans by the clutch.
Old 06-21-2018, 02:34 PM   #8
turboedbug
Member#: 155981
1969 vw bug
its the nose now hahahahah
