Welcome to the North American Subaru Impreza Owners Club Monday March 25, 2019
Old 07-14-2018, 06:51 PM   #1
albersondh
Member#: 196882
08 WRX
Default Lifter bucket grinder?
I need to remove some material from one piece lifter buckets to set lash. My lash changed about .001 after lapping and Im on the tight side now.
I want to use a mill and cutter, end mill, grinding bit, whatever, to take off some material. I can see some guys use dremil bits on a drill press but Im hoping to find something a bit more reliable in tems of straight/square. Im thinking a thicker shank (Dremil is 1/8) and maybe a fine stone? Ideas for a bit to get this done and leave a decent finish?
albersondh is offline   Reply With Quote
Old 07-14-2018, 07:22 PM   #2
Charlie-III
Member#: 30669
1998 Legacy 2.5GT
Silver Sleeper BK, 5MT
Surface grinder with a magnetic base/table, very small cuts. Maybe run a green wheel (normally used for carbide).
Everything else is.....well.....ghetto....
Granted, other methods can work, you REALLY want a smooth flat finish. Otherwise, you can wipe out a cam lobe, then, you start all over.......for many valves......
I am not a machinist, I'm a decent "metal hacker". I have a few years working on my own and in shops.
I know when to "MacGuyver" and when to do it right.
Old 07-14-2018, 09:51 PM   #3
n2oiroc
Member#: 141952
18 golf arrrr!
id think you would grind the underside where it touches the valve stem.
n2oiroc is online now   Reply With Quote
Old 07-15-2018, 12:24 AM   #4
albersondh
Member#: 196882
08 WRX
Yes. I wouldn't touch the surface that laps to the cam. Pretty sure it is not flat to promote lifter spin. Im referring to removing material from the nub that contacts the valve stem.
Old 07-15-2018, 01:29 AM   #5
Subie_
Member#: 419354
2007 STI
Crystal gray metallic
Is there another bucket you can swap it with and still have both within spec?
You can always just order the correct size... they're only $15-$20.
Subie_ is offline   Reply With Quote
Old 07-15-2018, 08:34 AM   #6
albersondh
Member#: 196882
08 WRX
I want the capability without having to tip valves or buy new.
Old 07-15-2018, 04:50 PM   #7
Elbert Bass
Member#: 283429
2016 Fuji Sunfire 03
I have seen folks grind the valve stem tip, but never the bucket - that is some hard material there...
Elbert Bass is offline   Reply With Quote
Old 07-15-2018, 07:56 PM   #8
Charlie-III
Member#: 30669
1998 Legacy 2.5GT
Yes. Issue sorta is.....
Suitable stone (green for carbide is best), keeping surface flat, etc. limited room to work.
If you hack at it, likely less than flat surface which will change gaps with little wear.
Also, grinding heats the material, thus harder to measure, reset, then grind more.
Depends on the system, some are about $17ea, some are closer to $60. Look them up on Subaru.partsonline.com or similar.
Checking gaps on a bench is one thing, checking when the head is torqued to a block may be another.
Doing something on a weekend when no new parts are around is one thing, doing something that lasts for 50K+ miles is another.
Not saying you can't hand grind within a bucket to get a gap, just really hard to do right.
Old 08-08-2018, 09:46 PM   #9
CarbideCarGuy
Member#: 489895
2005 STi
I thought about this myself and I think the best way is order a new bucket.
The second best way is to keep lapping it.
And the quickest way to take off a bunch of material is on a lathe with a really rigid setup and a carbide tip. Indicate it straight withing a few tenths and take a pass a few tenths shy of where you need to be.
I would only use this method if you're taking material off the inside of the bucket. That being said, i don't know if there's any geometry inside of the bucket on the boss tip. you could run an indicator on the boss to find out if its concave, convex or flat.
CarbideCarGuy is offline   Reply With Quote
Old 08-10-2018, 05:59 PM   #10
rtv900
Member#: 428511
2016 STI
indicate it within a few tenths and then take a pass a FEW TENTHS shy of where you want to finish?
I'm guessing you've never done anything like that on a lathe.
rtv900 is offline   Reply With Quote
