Welcome to the North American Subaru Impreza Owners Club Tuesday March 26, 2019
Old 01-07-2019, 09:04 PM   #1
housed1
Member#: 481812
Default 2002 wrx Parking lights wont turn on
Hi all,
2002 wrx wagon, parking lights in headlights will not turn on. All fuses check out, no other lights are out, and new bulbs.
Any suggestions? I'm stumped.
Thanks for the help
housed1 is offline   Reply With Quote
Old 01-07-2019, 09:56 PM   #2
satrya
Member#: 5887
2002 GDAA (bugeye)
797 (blaze yellow)
For the parking lights, are they tungsten filament bulbs or LED bulbs?
satrya is offline   Reply With Quote
Old 01-08-2019, 08:43 AM   #3
housed1
Member#: 481812
Good ole filament,
some members have said to check the taillight relay, which i will tonight, i will get a test bulb and start poking around in the fuse box, #5 #7 #12.
Any suggestions on any where else to check?
Thank you!
Old 01-09-2019, 10:56 PM   #4
satrya
Member#: 5887
2002 GDAA (bugeye)
797 (blaze yellow)
Iirc, the parking lights have its own connector (or maybe shares a connector with the sidemarkers); maybe there's damage to those wires?
Old 02-12-2019, 08:46 AM   #5
housed1
Member#: 481812
I will be digging back into the car this weekend I will look for damage in this area.
Thank you!
Old 02-13-2019, 01:02 PM   #6
Cougar4
Member#: 53443
2001 LL Bean Outback
Winestone
Do the rear parking lights work? If so then there is a problem with the branch to the front lights. If the rears also don't work then check the switch on top of the steering column. See if it works. If it does, then that switch is the trouble. Power bypasses through the switch to the lights even while the switch is OFF.
