Welcome to the North American Subaru Impreza Owners Club Tuesday March 26, 2019
Old 01-22-2019, 04:37 PM   #1
subopolois
Member#: 421572
Default oil usage/"burning"
I have my 2012 STi and just checked oil level. It was lower than what it should be and what i like. This isnt the first time its happened.
I did some research and apparently subaru stands by the belief that it is normal for their cars the use 1 quart oil for every 1000-1200 miles driven.
No I havent kept track of how much i top it up, but i feel like it hasnt been 1 quart/1000-1200 miles (less oil than this).
Also I dont smell any burning oil from the exhaust or engine bay.
My question is is this normal, does anyone else have this oil usage problem? I understand as cars get older they tend to g through more oil.
subopolois is offline   Reply With Quote
Old 01-22-2019, 06:26 PM   #2
CarmelValleyWRX
Member#: 453872
2005 wrx wagon
48w
the boxer tends to eat lots of oil. i think because the oil sits on the cylinder walls and goes into the combustion chamber easier than an upright engine. also the PCV system sucks lots of blow by gasses/oil mix into the intake.
CarmelValleyWRX is offline   Reply With Quote
Old 01-22-2019, 11:54 PM   #3
welding rod
Member#: 116108
In over 35 years of driving and having owned dozens of vehicles, I can remember only one, a high mileage 1973 Jeep CJ5 with AMC 304, that required the addition of ANY oil between oil changes, and my historic oil change intervals have been 5,000 miles (most vehicles) to 8,000 - 9,000 miles (for my 2013 Jeep with ~125,00 miles on it). My 2019 STI has 2,000 miles on it and is still almost at the full mark on the dip stick... almost exactly where it was when I first got it.
I would consider an engine that used 1 quart per 1,000 miles to have some kind of problem.
welding rod is offline   Reply With Quote
Old 01-23-2019, 06:18 AM   #4
rtv900
Member#: 428511
2016 STI
at 75k my sti still consumes no oil between 5k intervals
IMO any vehicle around 150k + will begin consuming oil either due to slight leakage or just plain consumption
and no, you will not see or smell this unless it is absolutely out of control
rtv900 is online now   Reply With Quote
Old 01-23-2019, 07:35 AM   #5
Jay11STI
Member#: 492422
It is normal for any forced induction car to consume oil but subaru engines are very well known for this issue. I would highly recommend keeping up with checking your oil. I would advise you check your oil every fill up so you get an idea of how much it consumes a week and over the course of an oil change interval. If this becomes an excessive consumption, it may be time for a compression and leakdown test to determine engine health.
My car is a 2011 sti with 60K on the clock and it does not consume any oil between 3K oil change intervals.
Jay11STI is offline   Reply With Quote
Old 01-23-2019, 07:43 AM   #6
Turpid Porpoise
Member#: 476573
2008 Impreza WRX STi
Check for leaks if you can't smell any oil being burned.
Do you have an AOS?
Turpid Porpoise is offline   Reply With Quote
Old 01-23-2019, 09:01 AM   #7
Charlie-III
Member#: 30669
1998 Legacy 2.5GT
Silver Sleeper BK, 5MT
Flat engines have a higher tendency to burn oil more than other engines. Whether it's a Subaru, Porsche or aircraft engine.
Not a guarantee it WILL go through more oil, but is more likely.
Yes, keep an eye on the level of oil, log mileage every time you add so you know the consumption rate.
Yes, most engines I would be concerned at having to add much oil between changes.
Old 01-23-2019, 10:05 AM   #8
Zcypot
Member#: 372777
2014 WRX Sedan Lmtd
Mine eats a lot of oil, but I hammered it a lot and run higher boost than stock. I have an AOS too. Which reminds me, I need to go buy another quart...
Zcypot is offline   Reply With Quote
Old 01-24-2019, 04:54 PM   #9
danger1138
Member#: 279525
06 Fxt
Yea a little less than 1 qt between oil changes seems right at least in my case. Built bottom end and i like to engine brake alot, not sure if that makes a difference or not.
danger1138 is offline   Reply With Quote
Old 01-24-2019, 05:02 PM   #10
Waddlz
Member#: 395275
2012 STi
GM also considers 1 quart of oil per 1000 miles to be normal oil usage. I had them do an oil consumption test on my wifes Colorado with the V8 and they said it was well within normal parameters.
We traded it in
Waddlz is offline   Reply With Quote
Old 01-24-2019, 06:45 PM   #11
RaPower
Member#: 496698
2007 WRX Wagon
If I remember correctly a lot of oil gets into the intake through the PCV system on the wrx/sti. There are some good catch cans on the market. Helps clean up emissions too
RaPower is offline   Reply With Quote
Old 01-24-2019, 08:58 PM   #12
CarmelValleyWRX
Member#: 453872
2005 wrx wagon
48w
i made a "catch can" out of an old oil quart bottle. it caught a good 1/3quart in a week. i bought an IAG AOS.
Old 01-25-2019, 07:25 AM   #13
Jay11STI
Member#: 492422
Another thing to consider would be oil thickness. Alot of guys use 5w-40 in their sti's including myself.
Old 02-14-2019, 01:22 PM   #14
jake07wrx
Member#: 497779
07 impreza wrx TR
wrb
With my '07 WRX TR I go through about a quart on oil a week. Not sure if that much is normal, but still looking for advice/help. thanks
jake07wrx is offline   Reply With Quote
Old 02-14-2019, 01:28 PM   #15
Charlie-III
Member#: 30669
1998 Legacy 2.5GT
Oil usage over time means crap......oil usage over distance means something.
Some peeps do 100 miles in a week, others do over 1000 miles in a week.
Old 02-14-2019, 11:13 PM   #16
BigWrecKs
Member#: 93830
11.5 New Balance
Shoes
Not normal at all.
Even if you drive 1000 miles/week.
BigWrecKs is offline   Reply With Quote
Old 02-15-2019, 02:22 AM   #17
JBoogs
Member#: 497813
Compression test all 4 cylinders and see if all are balanced, if you find a low cylinder, might have a broken ringland.
JBoogs is offline   Reply With Quote
Old 02-17-2019, 01:00 AM   #18
welding rod
Member#: 116108
My 19 STI just got its first oil change today at 3,300 miles. I have checked the oil with every tank of gas, at the same spot inside my garage after having driven to achieve normal operating temp, then waiting about 5 minutes. Today before the oil change the oil level was still pretty much at the full mark - it was slightly above the full mark when brand new. So the oil level dropped about 1/8" (3 mm) on the stick in 3,300 miles, and that included break-in and then plenty of boosting.
Old 02-17-2019, 01:27 PM   #19
the_saintusa
Member#: 171486
2004 WRX STI
No appreciable drop in oil levels between changes on my 04 STi.
On the 'rebuilt' engine (currently less than 10k miles) it has used zero appreciable oil between changes at 4-5k intervals (albeit only 2 changes, after break-in).
On the original engine the turbo (70k miles) was the source of oil loss in the months leading up to a rebuild. It was noticeable with a James Bond cloaking cloud under heavy boost. I parked the car for 2 years until I decided what to do, as it also developed a CEL for a misfire. I was convinced I had a bad ring landing, and I knew I needed a turbo (rebuild/replacement). Finally got to a point I wanted to drive the STi again as I was driving my C63 in the winter and wanted the STi as the winter beater.
The original motor had compression numbers of 145 across the board, and leak down values of 4% across the board which made me both happy and sad. Why replace an engine in good shape? Why not? The cause of the CEL ended up being the connector to the injector.
The oil consumption was never a problem until the turbo decided to go
Regardless, a new SB was built and installed (the original one in excellent shape was sold) and I continue to check the oil levels on a regular basis.
the_saintusa is offline   Reply With Quote
Old 02-22-2019, 12:58 AM   #20
slow.wagon
Member#: 484841
2008 WRX STI
Lightning Red
In my experience, they all burn oil, even brand new ones.
slow.wagon is offline   Reply With Quote
Old 02-26-2019, 07:24 AM   #21
soonchefmike1
Member#: 498303
I agree, check for leaks. It may be pooling in not so obvious places. If you have that plastic splash guard under your vehicle, I would take it off and do a thorough inspection.
soonchefmike1 is offline   Reply With Quote
