Welcome to the North American Subaru Impreza Owners Club Monday July 22, 2019
Old 02-04-2019, 07:46 PM   #1
Panacea
Member#: 349037
2019 STi Limited
Default Did My Clutch Get Hurt?
Let my coworker drive my 2019 STi today at lunch. Bad idea. While he was on a hill, he revs it to 3500 and slowly releases to clutch pedal. It stunk for a few minutes. What are the odds he hurt something? On the drive home it felt a bit soft starting in first gear but I’m chalking that up to mental trauma. Thoughts? It only has 1600 miles.
Panacea is offline   Reply With Quote
Old 02-04-2019, 07:52 PM   #2
freshazphuk
Member#: 494082
2003 wrx
it's probably fine 1 or 2 hard slips won't hurt it....drive home was probably just trauma lol i wouldn't stress it at all once it cools down it will go back to normal I'm sure.
freshazphuk is offline   Reply With Quote
Old 02-05-2019, 11:13 AM   #3
Panacea
Member#: 349037
2019 STi Limited
Yeah, it felt a little more normal today. Still not completely right. Again, probably mental. My brother says OE clutches can be forgiving.
Old 02-05-2019, 12:24 PM   #4
SirBrass
Member#: 207263
2019 WRX Limited
World Rally Blue
OE clutches are very forgiving. Your coworker only took a few hundred miles off of the clutch disc, most likely. No biggie.
Roasted clutch happens. If it's only a "happens once or twice" issue, no biggie.
Btw, it also can happen while clutching out when getting out of snow. It'll take a lot more and much heavier abuse to glaze the fiction surface or completely eat the friction material away quickly.
SirBrass is offline   Reply With Quote
Old 02-05-2019, 01:58 PM   #5
Panacea
Member#: 349037
2019 STi Limited
Thanks. This is precisely what I was worried about. I just had never seen such a blatant abuse of a clutch like that. He was apologetic but, you know.
Old 02-09-2019, 07:53 PM   #6
AcquaCow
Member#: 36838
2001 B50 RSTi Sedan
2011 DGM WRX hatch
If it makes you feel better, I got more than 30k miles out of a stock sti clutch, even with one or two weekly launches from 4K rpm on launch control.
I only took the stock clutch out because it wasn't holding the extra power after my tune. There was still a lot of life on it.
AcquaCow is online now   Reply With Quote
Old 02-11-2019, 02:57 PM   #7
Panacea
Member#: 349037
2019 STi Limited
Pretty tough, then, I take it?
Old 02-12-2019, 09:50 AM   #8
Panacea
Member#: 349037
2019 STi Limited
It just doesn't feel right. Like it used to. Either it feels like the bite point is higher or I need to give it more gas in first and reverse.
Old 02-12-2019, 07:35 PM   #9
R15
Member#: 409971
2018 WRX
10 bucks says now you notice the hill hold assist because you’re hyper focused on finding something wrong/different and obsessing on it every time you drive.
R15 is offline   Reply With Quote
Old 02-12-2019, 09:54 PM   #10
Panacea
Member#: 349037
2019 STi Limited
$10? Try $20. You’re probably right. Let me try turning it off.
Old 02-13-2019, 01:18 AM   #11
killadawg
Member#: 424203
2016 WRX stg 4 Rally
STI Drivetrain GM
My trans got stuck in 3rd.. I drove home in rush hour bumper to number, 2 hrs of traffic.. had to rev. the hell out of it not to stall with my clutch slipping all over. There were plumes of billowing smoke coming out of my car and it smelled terrible for about a week. Well it kept working fine once I fixed the trans, maybe 10k more, then I swapped for an sti drivetrain (that was a wrx 6mt I burnt a bit). I wouldn't worry these things are pretty hardy. Also if you plan on modding as many of us here do, running a stronger clutch might be a good upgrade. Good luck.
killadawg is offline   Reply With Quote
Old 02-15-2019, 04:01 PM   #12
Panacea
Member#: 349037
2019 STi Limited
Had an experienced fellow car guy drive the car. I made no mention of what happened. He didnít notice a thing. Should be fine. Issue closed. I feel better.
