Welcome to the North American Subaru Impreza Owners Club Monday March 18, 2019
Old 02-06-2019, 02:19 PM   #1
jared427
Member#: 187856
2005 Baja turbo
Default 2005 sti 6mt center differential issues with pictures
I purchased a wrecked 05 sti to put the 6mt and r180 in my baja. After install I noticed binding/ poping issues when turning sharp. So I pulled the center diff for inspection. After pulling it apart I noticed that on the planatary gear there are 6 dowels that are staked 3 of the dowels are slightly raised putting pressure on the friction discs. I don't think that they are supposed to be raised like they are. Also does anyone know where th sorce these from without having to buy a whole rebuild kit? Thanks in advance
jared427 is offline   Reply With Quote
Old 02-06-2019, 02:22 PM   #2
jared427
Member#: 187856
2005 Baja turbo
I also don't currently have a dccd controller.
Old 02-06-2019, 06:02 PM   #3
mrsaturn7085
Member#: 375462
2006 Impreza WRX STI
WR Blue
You would need a full rebuild kit. I've seen two staked pins fail, but never 3 - congrats, you now hold the record.
mrsaturn7085 is offline   Reply With Quote
Old 02-07-2019, 09:07 AM   #4
Bansheeboy11
Member#: 182415
1999 RS
This^ Also get a diff controller, id recommend the MAP unit.
Bansheeboy11 is offline   Reply With Quote
