Welcome to the North American Subaru Impreza Owners Club Tuesday March 19, 2019
Old 02-14-2019, 09:40 AM   #1
justinxecushyn
Member#: 190615
2007 WRX
Default Walbro F90000285 "Hellcat" fuel Pump
Has anyone used one yet? I've had nothing but great success with Walbro in the past, I previously used the 450 and loved it.
Walbro PN: F90000285
justinxecushyn is offline   Reply With Quote
Old 02-17-2019, 01:30 AM   #2
albersondh
Member#: 196882
08 WRX
Looks like an 8% flow increase but takes 15% more current to make it happen compared to the F90000274 (450lph). Without a pump controller that can handle the current (stock wont do it, for very long..) it would have to be hard wired. In which case I'm not sure the extra heat in the fuel would be worth it versus just running an additional switched pump for occasional high demand. Juice may not be worth squeeze. If your dedicated to a hard wired set-up and have decided the additional heat is not an issue than it may be a simple solution if your right on the edge of running out of pump.
albersondh is offline   Reply With Quote
Old 02-17-2019, 09:41 AM   #3
Homemade WRX
Member#: 33782
96 in the garage
search FIRST, then PM!!!
I think the bigger issue with these pumps, as mentioned, is getting them the amperage they want through the controller. There are some aftermarket controller options, a grounding mod for the stock one, etc...
Old 02-24-2019, 05:57 PM   #4
justinxecushyn
Member#: 190615
2007 WRX
I've never had a issue running the 450 without hard wiring.
Old 02-24-2019, 06:32 PM   #5
TDagen
Member#: 163648
2002 Resurrected WRX
Is it E85 safe?
TDagen is online now   Reply With Quote
Old 03-11-2019, 09:44 AM   #6
boogieman98
Member#: 402592
Can that pump run through the stock fuel lines from the tank to the engine bay without issue or should you upgrade those lines?
boogieman98 is offline   Reply With Quote
Old 03-13-2019, 03:41 PM   #7
linkubus06
Member#: 335449
07 WRX 20G 6MT
12 CTS-V Sedan 6MT
Does the Pope **** in the woods?
linkubus06 is offline   Reply With Quote
Old 03-14-2019, 04:16 PM   #8
boogieman98
Member#: 402592
No need for smart ass comments. If you don't know don't respond.
Old 03-14-2019, 04:19 PM   #9
Waddlz
Member#: 395275
2012 STi
I run a hardwired Walbro 450 with all stock lines with no issues. 50 psi base pressure.
Waddlz is offline   Reply With Quote
Old 03-14-2019, 07:01 PM   #10
boogieman98
Member#: 402592
Awesome thank you. I'm going for 60 psi base to push my 1300cc injectors to the max. I'm shooting for 550whp or more
