Welcome to the North American Subaru Impreza Owners Club Monday March 18, 2019
Old 02-14-2019, 04:02 PM   #1
rcrevolution
Member#: 239325
Default Splitting block, have some questions
Hello everyone,
I am in the process of splitting my EJ257 so I can take both halves to the machine shop to have the cylinders honed and rings fitted.
I am curious if I split the block, take the journal bearings off and mark them so I know exactly where the came out of, can I reuse them when I put the halves back together?
I am trying to avoid unbolting the connecting rods and also avoid buying new bearings and I need to know if crank bearings need to be replaced anytime a block is split.
The engine has 74k miles, never spun a bearing, ran out of oil etc.
rcrevolution is offline   Reply With Quote
Old 02-14-2019, 06:00 PM   #2
pploco
Member#: 88761
You shouldn't reuse journal bearings. You don't have to unbolt the rods from the crank to remove the mains. But you really should replace both mains and rod bearings while you have the case split.
pploco is offline   Reply With Quote
Old 03-02-2019, 12:03 PM   #3
Billm203
Member#: 498492
2005 Wrx sedan
Grey
If you already have the engine torn that far apart , you should really replace the journal bearings , and as said above do the rod bearings as well. A little extra money for some great preventive work
Billm203 is offline   Reply With Quote
