Welcome to the North American Subaru Impreza Owners Club Tuesday March 19, 2019
Old 02-17-2019, 12:35 PM   #1
Alejandro_okc
Member#: 497685
Default 2005 STI Overheating Issue
I have a 2005 Impreza Wrx sti thatís overheating. Iíve officially checked everything I think could cause my car to overheat. I drained the coolant and tested the thermostat. It was working and the coolant looked good. I drained oil and it was still new not milky. I replaced my coolant temperature censor. I put everything back on and new oil and coolant. I start the car and began the burping process. It was lifted in the front to allow a easier process. It was staying at operating temp at idle for a good amount of time. So I dropped the car and began driving it. The car began to overheat again when I would drive and the fans would not turn on. Then I would get to a stop light or something where the car wasnít moving and the car would go back to operating temperature. While driving I got A CEL ď bank 1 system too lean Ē and ď vehicle speed censor and low circuit inputĒ. Towards the end of my drive the temperature starting rising too much when I got home the fans kicked on but the temp didnít drop. There was also nothing in the extra expansion tank. Any ideas? Iíve already pressure tested the coolant system And it held 15lbs. The car also has good compression. Should I just assume itís a head gasket and get to work? Should I look more into the codes?
Alejandro_okc is offline   Reply With Quote
Old 02-17-2019, 02:16 PM   #2
Foo_Blyat
Member#: 93750
Excuse me if this is a stupid question but did you make sure to have your heat on and at full blast during burping
Foo_Blyat is offline   Reply With Quote
Old 02-17-2019, 07:12 PM   #3
Alejandro_okc
Member#: 497685
Yes I did.
Old 02-17-2019, 09:45 PM   #4
Charlie-III
Member#: 30669
1998 Legacy 2.5GT
Silver Sleeper BK, 5MT
Any air in the cooling system causes symptoms that look like bad HG's.
When you burped the system, did you have the overflow tank about 1/2 full?
When you installed the cap and shut it off, did it cool and suck liquid out of the overflow tank? It should and you need to have the overflow about 1/2 full at all times.
Old 02-18-2019, 04:38 PM   #5
Alejandro_okc
Member#: 497685
No I didnít I was told to fill it all the way up while burping the car? And the car when cool did not suck up anything itís still all the way up in the overflow.
Old 02-18-2019, 04:46 PM   #6
Charlie-III
Member#: 30669
1998 Legacy 2.5GT
OK, then you have.......
A ton of air that may still be pushing coolant out.
Bad HG that is pushing coolant out.
Either way, you should be pushing coolant out the,overflow tank or some,other leak.
The system should be filled as much as possible, coolant in the overflow, run it to temp, shut down, watch the overflow level.
Old 02-18-2019, 09:22 PM   #7
Alejandro_okc
Member#: 497685
Sorry for wasting everyoneís time. When I drove it last time I completely didnít notice the speedometer not working( as my boost gauge is mounted in front of it) . I also forgot I had a snap on obdII reader. I plugged it in and I monitored the temp and on my gauge it was all the way at the top while in the readers it was marking my coolant temp at 173 so itís not overheating a gauge issue.
