Welcome to the North American Subaru Impreza Owners Club Monday March 18, 2019
Old 02-24-2004, 11:08 AM   #1
Dakken
Member#: 24570
wrx [email protected] 1/4
1.72 best 60ft
Default Built motor? Check in here
Hey guys
I've been reading alot of the motor build threads and I'm about a month away from begining my own quest for 400+whp
If you've built a motor (or have a motor that wasn't stock with the car)in an older suby, WRX, sti, whatever.. please take a minute and check in here.
What shortblock? ____________
What heads? ___________
What turbo? ___________
What engine managment? _____________
Fuel modifications? _____________
Cooling Modifications (IC, Radiator, Oil cooler, etc) _________
How many miles? __________
WHP?__________(And what dyno you made this power on, please)
Problems, if any (Or if many) _____________
This might help to clear up some myths, focus on problems, and steer future engine builders in the right direction.
Thanks guys
Scott
Dakken is offline   Reply With Quote
Old 02-24-2004, 04:19 PM   #2
subjd40
Member#: 29028
2002 WRX 2.4L
Stage 4 Axis Power Racing Stroker Motor
- 2.35 Liter Displacement
- Polished & Balanced 2.5 STi Crank
- Pauter 4340 Chrome-Moly Forged Rods
- CP Forged Pistons (9:1 Compression)
- Cometic Head Gaskets
- ARP Head Studs (Over Sized)
Axis Power Racing Cylinder Heads
- Axis Racing Ported STi Spec C Cylinder Heads
- Axis Racing Dual Spring Valvetrain Kit
- JUN 272 Cams
Performance Mods
- Axis Racing Custom 70mm Throttle Body & Adapter Plate
- T60-1 Hybrid T3/T4 Turbonetics Turbocharger
- Custom Axis Racing FMIC & Piping
- Tial External Wastegate
- Custom Up-Pipe
- Spec-C TGVs
- Axis Power Racing Fuel Rails & Braided Line
- Aeromotive Fuel Pressure Regulator
- Aeromotive A1000 Fuel Pump
- Custom Downpipe w/ Vishnu Exhaust
- Electromotive Tec3 ECU
Other Modifications Include
- Built 5 Speed Transmission
- EXEDY Hyper-Twin Plate Clutch
- Brembo Gran-Turismo Big Brake Kit
- Cusco Rear Sway Bar
- Powder coated Intake Manifold
- Painted Valve and Timing Covers (OEM Subaru Paint)
- STi Projector Headlamps
- HKS SSQ Blow-Off Valve
- Battery Relocated to the Trunk
- GReddy Profec B Electronic Boost Controller
- Blitz Turbo Timer
also just installed a new radiator... off some touring car... don't know the brand... and the dyno graphs are on axis's website "project blue"
hope this helps
subjd40 is offline   Reply With Quote
Old 02-24-2004, 05:06 PM   #3
Dakken
Member#: 24570
1.72 best 60ft
Good good.
keep em comin
Scott
Old 02-24-2004, 06:35 PM   #4
totoherbs
Member#: 7321
.... 122 IggPoints
Work... ahhh... so tired.
I dont have one, but thies are the ones with the best reps...
www.axispowerracing.net( great guys, great blocks)
www.i-speedusa.com ( thier builder has been building BIG BIG hp ej dune bugies for a while. )
www.cobbtuning.com ( been around forever )
Link to an I-speed block in action...
http://forums.nasioc.com/forums/show...hreadid=507272
There are a few threads on cobb block and axis blocks...
Old 02-25-2004, 04:44 AM   #5
Delicious Tuning
Member#: 1990
Originally posted by totoherbs
Link to an axis block in action...
Just to clear things up here, that is an I-Speed USA block in action.
[edit]Sorry man, can't have people posting vendor-related items with personal accounts... they make me enforce the rules - North Ursalia[/edit]
Delicious Tuning is offline   Reply With Quote
Old 02-25-2004, 10:47 AM   #6
STFUTuning
Member#: 40729
2004 STi, EVO
AEM Factory Trained Tuner
STFUTuning is offline   Reply With Quote
Old 02-25-2004, 04:44 PM   #7
tolnep
Member#: 18602
2005 Moller Skycar
glow in dark purple
built motor = 10,000$ plus...(just the motor). Seems to be the consensus (not talking about hybrid 2.5 STIs or your WRX heads on an STI or JDM STI block)
tolnep is offline   Reply With Quote
Old 02-25-2004, 04:50 PM   #8
totoherbs
Member#: 7321
.... 122 IggPoints
Not realy... If you install it yourself you can cut the cost way down.
1k for basic head work
3k for the block
1k for needed install parts
500 to have someone slap the heads to the block
Now to get it running, tuned, and a turbo that will be of any use on it... you are right $10k easy, most likely more.
Old 02-25-2004, 05:01 PM   #9
tolnep
Member#: 18602
2005 Moller Skycar
glow in dark purple
3k for the block
Built. Like the Cobb stage III. Not installed. Everything done to the motor that is reasonable for a top drawer street motor. Start with best block (your choice). Add rods, pistons, sleeving, all machine shop work done, balanced, checked alignment of bores and crank. Add oil squirters if you want, notch sleeves.
Heads. pick best heads then flow them, best valves, retainers machined and assembled and clearances checked. Aftermarket cams, your choice. Aftermarket studs etc etc. At least port match the intake, perhaps tumbler delete etc etc.
At this point you have a motor you can drop into the car (I would do this myself). I would not do the machine work myself (no experience, no tools). I might double check simple things like CC the heads and pistons, check cam profile maybe).
A fully built stage three by one of the recognized builders on this forum (and there are others that aren't (pantera perhaps)) is going to cost you at least 10k.
Of course you could take a cobb stage three block and mix and match with your old heads or vice versa. But I was talking about basically a stage III crate motor with all the goodies.
Old 02-25-2004, 05:18 PM   #10
totoherbs
Member#: 7321
.... 122 IggPoints
Agreed, $10k all the goodies... but for just the block and heads you can get away with $5k. $3.5k for a built block(rods,pistons,ej22case,ej25 crank), $1k Valvetrain, $1k port/polish, and 1k for random goods like gasket, bolts, and what ever else comes up.
Old 02-25-2004, 06:02 PM   #11
Dakken
Member#: 24570
1.72 best 60ft
Keep up the info guys
I hoped this would spurt some discussion and it is.
Ya'll with the built motors, check in! Commawnnn!
I plan on a 2.2legacy block (built by axis most likely unless i build it reeeeeeeeeally slow by myself over summer/fall)
v7heads, possibly v8 valvetrain, or axis valvetrain.
Basicly I plan on maxing out my stock WRX motor, running it until it blows up, and hopefully while im doing that build a motor on the side that would be about ready to drop in when the stock motor goes.
350whp on the stock motor, who knows on the 2.2
Scott
Old 02-25-2004, 06:08 PM   #12
totoherbs
Member#: 7321
.... 122 IggPoints
Get a 2.2 with a ver8 crank, or the 2.35 with the 2.5L crank. Nice ways to go...
The jdm vavle train is good for high reving low displacement motors. The ver7 jdm STi cam is lower duration and hight vs the usdm wrx cam. The spec C is lower high, higher duration. The smaller juns are very very nice but they cost.
Old 02-25-2004, 06:18 PM   #13
tolnep
Member#: 18602
2005 Moller Skycar
glow in dark purple
That shouldn't be a problem. Is easy to blow up a fully built one too. Somewhere on one of these threads I made the statement:
"The tuner is more important than the engine build".
A built block only gives your tuner more headroom. But you can grenade this motor no mater how overbuilt it is. From what I have read on this and a few other forums, everyone is on new ground, trying to figure out how far you can push it and what can be done to make it tougher. There may be some out there that know the secrets (I hear rumors from time to time) but I think most are still gropping in the dark trying to find the right combination of build and tune for a long lasting config.
Old 02-25-2004, 06:20 PM   #14
Dakken
Member#: 24570
1.72 best 60ft
At this point I'm looking at a 7500ish redline.. slightly higher then a stock WRX, but nothing crazy. High RPM means more tuning, and i'm lazy like that.
JUN are sweet but I'm not building a racecar, so I'll go the affordable route and stick with some STi RA stuff.
originally i wanted 400whp and stop there.. Now that i see the stock motor can handle that (Bigturkey, for example..400whp on stock motor...which is awesome) I decided to draw the line at 350,375whp and conserve some longevity while i build up other stuff... 350whp from 200whp is going to be a blast im sure.. then when that motor finally does bite the dust (Bad tank of gas, mis shift..whatever) I'd like to have a 500+hp capable motor ready to be dropped in...and then start at 400whp till thats boring..then crank up boost a little and tune accordingly.. until that motor goes.. in which case I'll repeat the process :P
I'm already going to be knee-deep in penny spending with a v7/v8 transmission and a DECENT set of wheels. I'll keep the v7 takeoff suspension until the struts die (offroading tends to kill those quicker) and then I'll rock with a decent set of coilovers.
Old 02-26-2004, 02:23 AM   #15
STFUTuning
Member#: 40729
2004 STi, EVO
Built motor and heads (without Cams) = around $7500.
There are other misc costs that will bring that figure up as well. Plus, when it's out, you just cant seem to help yourself. I know I can't!
Old 02-26-2004, 11:54 AM   #16
Dakken
Member#: 24570
1.72 best 60ft
Yea, that's why I think I may just build this thing as I go rather then having it built somewhere else. Working on cars is my hobby, after all!
Scott
Old 02-26-2004, 03:07 PM   #17
totoherbs
Member#: 7321
.... 122 IggPoints
Scott
In the end its cheeper to use one of the known motor builder and install it, slap the heads on yourself. Once you add up the parts, and the machinist, and get it balanced.... it comes out to a lot more. Realy to make power on the biger blocks past 6k you need cams...
Old 02-26-2004, 04:33 PM   #18
pk!
Member#: 26812
-- sold 04 WRB STi
MINI S VERT soon JCW baby
$5,900
http://axispowerracing.net/stage5motor.html
pk! is offline   Reply With Quote
Old 02-26-2004, 04:50 PM   #19
totoherbs
Member#: 7321
.... 122 IggPoints
Originally posted by pk!
$5,900
and heads, and shipping.... tax.... putting heads on the block... install, even if you do it yourself its going to cost lots of time.
Old 02-26-2004, 05:29 PM   #20
MJU1983
Member#: 14364
2003 WRX, '06 Armada
05 Vette & 05 STi (sold)
Here is what Im using for my project coming summer 2004.
2.2T legacy block
darton ductile iron sleeves
ross pistons-98.5mm bore with custom pin height
pauter rods- stock 2.0 length
2.5 modified crank-79mm stroke
14mm head studs
total seal rings
cometic head gaskets
WRX, Ported. Valvetrain upgrade
JUN 264 Cams
Undecided
SDS, or UTEC if MAF to MAP is out
Custom Rails, lines, pump, etc.
Aluminum Radiator... PWR?
0
Estimate: I want 500whp on our dyno dynamics dyno.
Havent started yet. I can only imagine.
-Mike
MJU1983 is offline   Reply With Quote
Old 02-26-2004, 05:40 PM   #21
totoherbs
Member#: 7321
.... 122 IggPoints
Good luck Mike, make sure to let us know how it goes...
Cobb just droped thier new toys...
Most inpresive is the coated bearings...
http://cobbtuning.com/wrx/engine-int...html#rbearings
They also have thier 2.0,2.2,2.5 blocks....
http://cobbtuning.com/wrx/engine-ass...iginal.html#20
Also new 'tuner blocks'
http://cobbtuning.com/wrx/engine-ass...-tuner.html#20
That said I dont like the idea of just stroking a ej205 to 2.2....
Old 02-26-2004, 05:53 PM   #22
Dakken
Member#: 24570
1.72 best 60ft
Good luck, mike! 500whp on your evil dyno isn't the same as the high readers
I decided (Yea, i keep changing my mind..so its probably temporary anyway) i'll just wait until i have a trans in my car to even consider the engine buildup. Maybe by then we'll have some crazy new developments, or Mike will get tired of having 500whp and resort to something like a Festiva and I can buy his motor
/insert more wishfulthinking here
Old 02-26-2004, 06:43 PM   #23
MJU1983
Member#: 14364
I am slowly acquiring the necessary parts. I have the block, already sleeved. The crank, bearings, pistons & rings, studs and gaskets... need some rods.
I am working on scoring some heads at a good deal, then off to get ported.
It will be a slow process. Maybe Ill sell the entire car on ebay when Im done.
RHD track WRX, just 2 seats and a roll cage... and a couple HP to play with.
-Mike
Old 02-26-2004, 07:04 PM   #24
Dakken
Member#: 24570
1.72 best 60ft
Someone will be a happy camper if you sell em the setup youre building, i would imagine.
The more I think about it, the smaller I consider starting and building up from there.
VF22 and fuel mods with some decent tuning will have to suffice till I have the money for a tranny, methinks. :-\
Old 08-17-2018, 01:11 AM   #25
ssittnick
Member#: 490276
Heres a Build Sheet for my 2007 Subaru WRX engine build. Could be forgetting some things.
Engine:
IAG Stage 3 Tuff ClosedShort Block
1/2 ARP Head Studs
B25 EJ Heads
GSC +1mm Intake Valves
GSC +1mm Exhaust Valves
GSC Valves, Springs, Retainers.
Brian Crower 272 Camshafts
Most headwork done by IAG, some done by Aaron @ GFTP. (blended bowls, etc)
Gates Racing Timing Kit
OEM 12mm Oil Pump
Killer B Oil Pickup
Killer B Oil Pan
Killer B Oil Baffle
Custom AC delete, Custom Alternator Shroud, Custom Power Steering Shroud
Fluidampr Crank Pulley
Turbo/Exhaust/Intake
Precision Turbo and Engine 6266 Gen 2 Dual BB V-Band Turbo Charger (W/ Turbo Blanket)
ETS Fully Rotated Turbo Kit (W/ Heat Wrap)
ETS EL Headers/UpPipe
ETS Rotated Downpipe
Tial 44mm External Waste Gate and Dump Tube (1.4 Bar Spring)
Steel Braided Oil Feed Line
Perrin FMIC Kit (W/ Custom Rotated Charge Piping by Aaron @ GFTP; Painted by Casey @ GFTP)
Tial Q BOV
Process West Track Reverse Manifold
IAG 8mm Phenolic Spacers
IAG TGV Deletes
AEM Electronic Boost Control Solenoid
Omni 4 Bar MAP Sensor
Fueling:
IAG V3 Fuel Lines (W/ IAG Fuel Pulse Dampeners)
Injector Dynamics ID1700cc Fuel Injectors
IAG Braided Fuel Lines
Vibrant -8AN Fuel Feed Line
Vibrant 5/16 Fuel Return Line
Twin Walbro 450 Fuel Pumps on Modified OEM Fuel Pump Hanger (Hard Wired and Activated by Hobbs Switch)
Radium Engineering Fuel Pressure Regulator (w/Gauge)
Transmission:
2004 WRX STI Transmission
2004 STI Brembo Brakes
2004 STI Hubs
2004 STI Drive Shaft
2004 STI Axles
Excedy Twin Disk Heavy Duty Clutch Kit
Mounts/Accessories/Everything Else:
Torque Solutions Pitch Stop Mount
Torque Solutions Engine Mounts
Torque Solutions Trans Mounts
Mishimoto Carbon Fiber Catch Can
Perrin Coolant Over Flow
Suspension:
ISC N1 Coilovers (w/ Camber Plates)
Follow me on Instagram: @ssittnick
ssittnick is offline   Reply With Quote
wat grade dino oil for built motor break in? jacky599r Built Motor Discussion 23 11-30-2008 04:19 AM
Want your wheels or small pieces painted? in MA check in here. browniesti04 New England Impreza Club Forum -- NESIC 4 06-02-2008 10:12 AM
Soccer fans check in here!! Jazz95 Off-Topic 37 07-31-2004 03:55 PM
11/19/01 Night of the WTLW (n00bs, check in here first) WRXedUSA Off-Topic 15 11-19-2003 10:41 PM
All Minnesotans, check in here midlifecrisis Mid West Subaru Owners Club Forum -- MWSOC 253 08-28-2002 05:56 PM
