Welcome to the North American Subaru Impreza Owners Club Sunday March 24, 2019
Old 02-14-2019, 12:21 PM   #26
dud3tt3
Member#: 497730
Default I made 390whp/360wtq with my set up. I expected more?
Hey everyone,
I'm really just looking for some opinions. I recently finished my built motor and dyno tuned up in southern pa on a dyno jet. I only made 390whp/360twq and ran into some issues while tuning and wanted to know your thoughts.
Here's what I have:
Engine:
Built 2.7 Hydra by Element Tuning
100mm Manley pistons
Manley rods
GSC 272 Cams
Stock Crank
TGV Deletes
Super Tech Valvesprings
ARP Head studs
IAT Visconti
AEM 3.5 MAP Sensor
Grimmspeed 3 port EBC
Aeromotive Fuel Rails
Deatschwerks 340LPH Fuel Pump
Injector Dynamics 1050X (1065cc) Injectors
NGK Iridium Spark plugs
Speed Density on Cobb Access Port
Turbo smart BOV
Blouch 1.5 XT-R (Twinscroll)-IWG
3inch Inlet & 10cm hot side
Tomei Expreme Equal Length Headers & Up-pipe (Twinscroll)
Perrin FMIC
ACT Heavy Duty Street Performance Clutch
OEM Fly wheel
(I may be forgetting some things)
Located in Northern Va but tuned up at PSI Proformance in Lansdale PA.
Final Dyno pull on a Dynojet (Jan. 17, 2019)
4th gear 387whp/360tq @ 21PSI on 93 pump
When I first finished this project my goal was to break 400 to the wheels. I was confident with this set up to at least break 400whp and have torque right around the same, even on 93 pump. If I had to actually ballpark it, I expected to make around 420-430whp and 440-450tq.
Down the road, I do want to eventually go with a cobb flex fuel kit to have the ability to run E85, but it's not a necessity at this time.
While tuning we discovered that the IWG was opening up too soon. We also saw on that last pull that my clutch was starting to slip which pretty much concluded my dyno tune. Granted my clutch is relatively new, I have a friend who ran into this same issue with the same clutch. They are supposed to be rated 515tq to the crank, so I was quite surprised to see it not hold any more than 360 to the wheels.
"Wastegate duty cycles were mid 30's on hit to full boost (according to my tuner). The issue he ran into was he was 50-60% up and the turbo was tapering more than usual. If the spring was off it would have a slow PID to full boost. We had the opposite issue. The turbo was tapering more up top than usual, dropping power a tad even when hitting it with lots of WGDCs."
^(I know absolutely nothing when it comes to tuning so I don't fully understand what he's referring to in all of this tuning lingo.)
Now, knowing what I know, I have been contemplating converting to EWG's and knowing that I am twin scroll, I would need a dual ewg set up. It's rather a complex project to complete a dual ewg on a stock location turbo with this setup. A pretty penny is required (as usual with Subarus imo) to fabricate my current up pipe or have one completely fabricated from scratch to accommodate this. I also plan to invest (unfortunately) in yet another clutch that hopefully doesn't give out on me. I might just throw a 6puck disc in and call it a day, but I may also consider switching out to a lightweight flywheel as well.
Curious what are some of your opinions or thoughts on this and I'm open to suggestions on alternative solutions.
Thanks!
dud3tt3 is offline   Reply With Quote
Old 02-14-2019, 01:42 PM   #27
kharmicresonance
Member#: 461898
@dud3tt3
Disclaimer up front, I am not an expert.
It looks like your turbo does not match your build.
A 2.7 stroker, with 272 cams, would push a dom1.5 past its design parameters. I don't have charts with me here at work, but iirc the dom1.5 will only be good for about 400, on a plain 2.5, and will naturally taper above 6500.
Your engine is pushing way more air, which is why your tuner is seeing too much from the turbo early on, then it cant keep up at higher rpm, and the wastegate just cant cope.
Honestly I would expect to see a dom3.0 with your build specs.
kharmicresonance is offline   Reply With Quote
Old 02-14-2019, 02:43 PM   #28
dud3tt3
Member#: 497730
@kharmicresonance
Thanks for your input. I found this link upon my research going into this that led me to the decision for the 1.5. My goals are to listed as above, and being front mount I wanted to ensure I still had a decent lower end, reason why I went twin scroll.
https://preracing.com/stock-location...tutvkr309PQJ6U
Old 02-14-2019, 03:19 PM   #29
Foo_Blyat
Member#: 93750
Why are you guys bumping a useless 15 year old thread?
Foo_Blyat is offline   Reply With Quote
Old 02-14-2019, 05:46 PM   #30
dud3tt3
Member#: 497730
Default Why I bumped an old thread
I wasnt able to create a new thread until I had 3 official posts.
wat grade dino oil for built motor break in? jacky599r Built Motor Discussion 23 11-30-2008 04:19 AM
Want your wheels or small pieces painted? in MA check in here. browniesti04 New England Impreza Club Forum -- NESIC 4 06-02-2008 10:12 AM
Soccer fans check in here!! Jazz95 Off-Topic 37 07-31-2004 03:55 PM
11/19/01 Night of the WTLW (n00bs, check in here first) WRXedUSA Off-Topic 15 11-19-2003 10:41 PM
All Minnesotans, check in here midlifecrisis Mid West Subaru Owners Club Forum -- MWSOC 253 08-28-2002 05:56 PM
