Welcome to the North American Subaru Impreza Owners Club Tuesday March 19, 2019
Old 07-11-2018, 10:31 AM   #901
yamahaSHO
Member#: 73932
2005 STi EFR 6758
04 S2000 EFR 7064
If your fuel tables are off, they're off and you need to fix that. If you've tuned it properly and removed the OL delay, it'll follow your OL fuel table.
For AFR, if you don't know how to answer it, I recommend getting some dyno time and learning what works.
If you go higher in load than you are scaled for, it will just follow the last load column until you go under that load.
yamahaSHO is offline   Reply With Quote
Old 07-11-2018, 08:40 PM   #902
Crispy 1
Member#: 478948
02' WRX
SRP
Understood!
How can I, until I get a tactrix, find out where my fueling and load map stops with the stock unmodified ROM?
If my LV only goes to 1.70 load and 5,700 rpm does that mean that's as high as my map has tables for?
So anything above that and there's no guarantee what my A/F is other than what my 02 sensor says?
Crispy 1 is offline   Reply With Quote
Old 07-11-2018, 11:07 PM   #903
NSFW
Member#: 140444
05 Stage Free LGT
ATP 3076, 6MT, AVO FMIC
You could learn quite a bit by data logging, but that won't tell you about cells you're not actually hitting, and you need a cable for that anyway. You really need to pull the ROM to know what's in it.
Old 07-11-2018, 11:54 PM   #904
Crispy 1
Member#: 478948
02' WRX
SRP
Oh I am datalogging and have plans to get a tactrix cable and download my ROM asap I just can't afford it right now. Im logging with the btSsm AP and a vagcom cable and have already learned quite a bit.
Now I need a wideband and downpipe and lots more reading you've wrote on RomRaider.
Life is trying to kick my ass right now with a lot of family stuff going on that's draining my bank and my mental stability lol.
Hopefully soon I can finish up with the hardware and start jumping into the software side a lot more than ever before!
Old 09-02-2018, 06:57 PM   #905
scwb1987
Member#: 490961
Can you add a MBC to EBC if you already have a good tune and cannot access the map to change WGDC? What would happen? Just to limit flutter on EWG...
I have a Pro-tune map (SD) on Cobb AP. After reading the thread, it was pretty funny.. I just thought I'd ask if anyone has any input on what I'm trying to do? I don't want to mess with my tune. Until I get a couple more mods and need a retune...I'll probably just get my EWG plumbed back into my exhaust.. I just want to hear my motor I am Curious :0
I love the work my tuner has done. I am not trying to disrespect anyone in anyway BTW.
scwb1987 is offline   Reply With Quote
Old 09-02-2018, 07:37 PM   #906
no694terry
Member#: 220816
2018 Exotruck
EJ22e 415whp/398wtq
yes but it would need to be set lower than your current peak boost level to do anything. It would be a waste without being tuned for. Imo, its more of a failsafe.
no694terry is offline   Reply With Quote
Old 09-02-2018, 07:42 PM   #907
scwb1987
Member#: 490961
I think I understand it now lol. I'm just gonna leave it alone. I love how it's setup and don't want to change it. I've got some other mods to do before getting another tune anyways. It actually sounds pretty mean when out in the open. Just city driving sucks because everything echos. Thanks for the quick response man.
Old 09-02-2018, 09:52 PM   #908
PDXREALTOR
Member#: 468393
2017 STI
I tried it. You need to set wgdc to 100% and cap the VTA off the solenoid. Otherwise, it spools like ****. Even if you do set the MBC at or below the boost limit.
PDXREALTOR is offline   Reply With Quote
Old 09-02-2018, 09:56 PM   #909
scwb1987
Member#: 490961
I didnít think it would work correct without some kind of adjustment. I tried to PM ya but itís blocked I guess. Thanks for the info. I appricate the quick response! Suby ppl are awesome
Old 09-02-2018, 10:02 PM   #910
PDXREALTOR
Member#: 468393
2017 STI
No problem. Imo it's one of the best mods I did. Rock solid, super quick spool, and.... That's it.
Worth having the adjustment made to your tune. Who is your tuner? Maybe they will make the couple of adjustments for you. They don't need your car on a Dyno or anything like it..... Real simple 5 minute deal.
Old 09-02-2018, 10:32 PM   #911
scwb1987
Member#: 490961
Default new hybrid mbc/ebc method of boost control
Clark. I need to get some bigger injectors before he will make any adjustments. I can ask him though I suppose Iíve got romraider and access tuner and all that but I donít really want to mess with speed density🧐 As much reading on all these guys posts over the years, ya think ya would be able to figure it all out. One mistake and youíre rebuilding a block My car just sits in the garage cuz itís so hot most of the year to even do anything tuning wise. Itís kinda depressing lol
Old 09-02-2018, 10:49 PM   #912
PDXREALTOR
Member#: 468393
2017 STI
Clark. I need to get some bigger injectors before he will make any adjustments. I can ask him though I suppose Iíve got romraider and access tuner and all that but I donít really want to mess with speed density🧐 As much reading on all these guys posts over the years, ya think ya would be able to figure it all out. One mistake and your rebuilding a block My car just sits in the garage cuz itís so hot most of the year to even do anything tuning wise. Itís kinda depressing lol
I can tell you the exact changes to make. I'm SD too. Someone else can confirm my settings to make you feel confident. It's literally two tables/adjustments. Forget about changing boost just set it up so the MBC is controlling peak, which you can set just below your tuned peak, by say...... .25 psi.
That will eliminate your flutter and spool you quicker
What kind of boost control solenoid/boost controller is this? roninsoldier83 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 3 10-01-2007 10:24 PM
If the pill is your primary method of birth control, learn from my mistake George71 Off-Topic 59 03-15-2005 12:00 PM
mbc/ebc and peak boost in lower gears? chrisfranklin Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 2 08-02-2004 09:29 PM
Joe P. MBC XZ Turbo Manual Boost Controller (ebay no reserve) lstepnio Private 'For Sale' Classifieds 0 03-22-2004 06:43 PM
Need Help: An analysis of boost control methods smiles Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 16 01-07-2002 03:12 PM
