Welcome to the North American Subaru Impreza Owners Club Monday March 25, 2019
Old 04-21-2016, 03:56 PM   #151
mrsaturn7085
Member#: 375462
2006 Impreza WRX STI
WR Blue
Originally Posted by snowrx View Post
mrsaturn7085-
Thanks for the input, it's appreciated. And yes, the PNP box runs speed density
Cost update, the plug and play box for the 02-05 WRX running MS-3 code is going for $1200, and the MS3 kit + MS3X+ harness is under $600 if you're a serious DIY guy.
https://www.diyautotune.com/product/...05-subaru-wrx/
What I meant was: if you go from MS to a different speed density setup (AccessPort, standalone, etc.) it will be an easy changeover due to the changes you'll have in-place just to get the MS up and running.
For the price, I'd get an AP and call it a day.
mrsaturn7085 is offline   Reply With Quote
Old 04-22-2016, 01:12 PM   #152
snowrx
Member#: 6973
2002 WRX Wagon
My understanding of the AP is that it only loads other peoples tunes?
Not sure what "stage" my EJ257 block/worked EJ20 heads/VF30/STi cammed/700cc injector/full exhaust motor would be, but I'm guessing there would be extra expense in further tuning or licenses to tweak the AP, unless that's what the open source takes care of. I've not followed Subaru engine management options since I installed my UTEC/Tuner combo many years ago, I'm trying to get up to speed.
I'll confess that using the same software to tune both cars has an appeal that may discount other solutions!
snowrx is offline   Reply With Quote
Old 04-22-2016, 01:55 PM   #153
mrsaturn7085
Member#: 375462
WR Blue
Nope - the AP can log & monitor as well as live tune (or offline tune) using the free AccessTuner Race software. Cobb keeps the software under lock and key, however - you need to have a valid AP serial no. to be able to access the downloads, and even then, you will be limited to tuning your car unless you buy the professional version of the software.
Cobb offers a number of base and 'staged' maps to start off with, but the tunes are fully open to the end-user. Unfortunately, many professional tuners *will* lock the tune if you decide to have it tuned by them - finding a tuner that fits your needs is key, here.
The AP is versatile enough (and maintains OBD) that even though I have switched to a MoTeC M800, I keep my AP available to plug in the OEM ECU and renew the registration every two years. Having the ability to revert to OBD compatibility means I'm able to do the OBD emissions testing rather than needing a sniffer test; the car would probably pass either test, but the OBD check is MUCH faster.
Old 01-16-2017, 08:27 PM   #154
Outbackxt413
Member#: 461404
Anyone know of a good subaru tuner in Massachusetts? Preferably western mass?
Outbackxt413 is offline   Reply With Quote
Old 01-17-2017, 07:31 AM   #155
BlueScooby
Member#: 3675
2017 WRX 6MT
Brentuning in Sterling MA is probably your best bet for a dyno tune. I live in MA but after weighing my options and reading customer feedback I went with an Etune from Eric at Torqued Performance and couldn't be happier. He only tunes turbo subaru motors and his experience definitely shows. Great guy too.
BlueScooby is offline   Reply With Quote
Old 01-17-2017, 11:16 AM   #156
Scargod
Member#: 260314
2007 STI
silver gray metallic
I can offer you this customized Google map I made three months ago, when I was looking for alternatives.
As to Brentuning in Sterling MA, I did not contact him as recall and the website is dangerous, according to Google Chrome. I also did not go west into NY. I was trying to avoid towing my car on a trailer through the NYC area. There may be many places in the NYC area and on Long Island if you can drive there.
I'd suggest you pick a reputable place with an in-house tuner and not one with a roving, mercenary tuner.
Added:
Bren Tuning
Brendan Griffin
(508) 762-1769
6 years in business
377 Worcester Rd
Charlton, MA 01507-1503
AKA, Autobahn East
Scargod is offline   Reply With Quote
Old 01-06-2018, 07:59 PM   #157
OneBadAssWREX
Member#: 480220
Default 11 Wrx Stage 3 Overboosting Please Help
I have a 2011 WRX Hatch running Stage 3 AP.
My mods are
Cobb Accesport V3
Cobb SF Intake
Grimmspeed EBCS
Grimmspeed TMIC W/Perrin Throttle Body to Intercooler Coupler
Perrin Turbo Inlet Pipe
Stock BOV
Invidia Catless Divided Wastegate Downpipe
Invidia Catless Catback Exhaust W/1 O2 sensor
I'm currently running the cobb stage 2+sf 93 mt v331 LWG Map:
I did a data log and took a picture of my parameters. I am still over boosting in every gear. I'm boosting up to 20.1 PSI and once I hit 3rd hear an at 5500RPM it throws a code and puts my car into limp mode. The code of course is the overboost code. The check engine light comes on, the cruise control flashes, the brake light comes on.
Here is what my AP readings are in 1st-4th
gear 120mph 11° degrees out and I'm in the
Mountains high altitude
Boost
-10.11
11.76/19.57
Feedback Knock
-1.40/0.00
Fine Knock Learn
0.00/0.00
Dyn. Adv. Mult.
1.000
1.000/1.000
DAM
Dynamic Adv. Len
0.00
0.00/6.50
Dynamic Adv.
0.00
0.00/6.62
So first off is that a bad knock reading? And second how the hell do I stop over boosting before I blow something up?? [
OneBadAssWREX is offline   Reply With Quote
Old 01-07-2018, 06:12 PM   #158
snowrx
Member#: 6973
2002 WRX Wagon
Cold temps and the associated denser air always push my boost levels up.
Quite often my perfect summer boost settings are to high come winter.
Assuming all your boost plumbing is/was functional before this.
Old 03-05-2018, 07:28 AM   #159
theSTIprojectgrey
Member#: 355128
great info !
theSTIprojectgrey is offline   Reply With Quote
Old 02-26-2019, 04:58 AM   #160
Joey118
Member#: 399260
I need help finding a very basic plug-in “performance chip”. I was taking to one of my friends, telling him my car basically has no commercial mods available for it (2004 Impreza Outback [NA]) and he told me that Subaru’s respond really well to performance chips. So I want to find one that will work well on my car, which has no current mods. I don’t know anything about car tuning and it probably isn’t worth it to spend a lot on my car anyways. So I just want recommendations for a cheap and easy plug-in that will at least give my car a little more performance, if that’s possible.
Joey118 is offline   Reply With Quote
Uppipe FAQ: Read if you are thinking of buying one! Unabomber Newbies & FAQs 390 01-12-2019 11:31 PM
Exhaust FAQ: Read if you are thinking of buying one! Unabomber Newbies & FAQs 306 01-08-2019 01:49 PM
Downpipe FAQ: Read if you are thinking of buying one! Unabomber Newbies & FAQs 337 11-12-2018 05:55 AM
Pulley FAQ: Read if you are thinking of buying one! Unabomber Newbies & FAQs 118 12-08-2016 12:24 PM
