Welcome to the North American Subaru Impreza Owners Club Monday March 25, 2019
Old 10-25-2017, 11:56 PM   #3001
hondaeater69
Member#: 60324
1998 RS
Originally Posted by jag09 View Post
Wanting to go Flex Fuel on MY10 Forester XT. Cobb has no plans of supporting SH FXT's. I am trying to figure out what route I should take to go the flex fuel route. My current set-up is:
Blouch 440XT
AEM Drop-in Fuel Pump
ID1000's
PW TMIC
Catless DP
Q300 Exhaust
delicious tuning supports all kinds of ECU's that cobb doesn't for flex fuel. i'd contact them.
Old 10-26-2017, 09:01 AM   #3002
jag09
Member#: 463341
To my knowledge the delicious tuning kits will work with my ECU but Cobb doesn't support the SH Forester XT platform, so I still wouldn't have flex fuel capabilities.
jag09 is offline   Reply With Quote
Old 10-27-2017, 12:50 AM   #3003
hondaeater69
Member#: 60324
1998 RS
well... cobb doesn't support flex fuel for 2002-2005 wrx's, yet delicious tuning CAN tune flex fuel through the accessport on it. i have already contacted them about it. doesn't hurt to contact them.
Old 01-27-2018, 10:44 PM   #3004
WRXVishnueStg_2
Member#: 267875
2003 Impreza WRX
Originally Posted by amalgrover View Post
Not really sure I fully understand your issue, but I believe you are saying that you are currently leaning out. You went the wrong way with your scaling (I am assuming your numbers are missing the decimal...512.0 and 691.2...correct me if I am wrong)...you need to lower your injector scaling for E85, not raise it. That is why you would be leaning out.
The front O2 sensor isn't really a wideband because of it's placement, it is more like a narrow band sensor. If you move it behind the turbo, it will perform more accurately and will allow it to perform like a wideband sensor, at least down to about 11.3:1...below that it doesn't really work.
Sorry been off the forums for sometime now. So i was using Cobb ATR to tune not RomRaider. That calibration worked for me had the car running e85 like that capping out MAP at 24 psi, on an MAF based tune still had room on MAF (making less than 300g/s). Also found out under boost front O2 is about .3 to tops .5 off. It ran leaner than what I liked but had no issues. The tune worked well, made a lot of power and e85 has more cooling effect than gas and didn't have issues running slightly leaner. AFR per AP was about 11.5, leanest I saw with O2 up tail pipe external was 12 which is pretty lean for boost application. AFR value based on gas stoichiometry, which is what computer read actual values are much richer but the AP will not give u them as it doesnt know difference in fuel types. I ran sti pinks with td04 like that 7 years and sold the car a couple months ago. -just an update for anyone considering sti pinks/td04/e85. Idc was close to 100% on WOT runs. I just got an 05 STI with stock injectors and vf39 tuned at 18.5 psi I'm getting 100% idc, so really pinks which are a little bigger than USDM STI injectors worked fine for td04 ej205 e85 build. My friend is still driving the car around. 1 issue I did have was tranny blew 1st gear after to many aggressive launches. Weekend 1/8 mile several times a month for a 1 year. Total milage at the time when it happened was 130,000 with RP gear oil, bad experience. Rebuilt and put AMSOIL gear oil sold to my friend at 168000 miles and he's still driving it. :-)
WRXVishnueStg_2 is offline   Reply With Quote
Old 02-23-2018, 08:54 PM   #3005
Kobylden000
Member#: 482513
Unhappy My car stalls and can’t find the solution.
Hey guys I know that this might not be the best place to post about this but I need urgent help. So currently I have an automatic 2010 Subaru Impreza 2.5i and right now the car is stalling when the car is parked and has warmed up. I checked the codes and I got the “cylinder 1 and 2 misfire” code and the guys at the auto shop told me to start by changing the spark plugs, and so I started by first switching the sides of the coils, and the same code came up and so I knew that the problem wasn’t in the coils, and so I changed the spark plugs. I then checked again and the code for the oxygen sensor came up and so I then changed the mass airflow sensor, and finally i checked back again and I got the “catalyst fuel efficiency below threshold bank 1” code and so I started by changing the fuel injectors, then the cat sensors both upstream and downstream and finally the cat itself. The problem wasn’t fixed, there’s clear smoke coming from the exhaust, the fuel doesn’t fully combust, the gas smells with a mix of burning plastic and unburnt fuel as if you were standing in a running boat, and when you put the car into drive or reverse, the car shakes and has a high pitch sound as if you were to shake a can of spray or something. Any help is appreciated.
Kobylden000 is offline   Reply With Quote
Old 03-08-2018, 09:54 AM   #3006
no694terry
Member#: 220816
2018 Exotruck
EJ22e 415whp/398wtq
Had to think about something i haven't really cared about before. Fuel filter media.
What types are people running, seems no manufacture wants to fess up that there media is E85 safe although im sure some are, i been running a OE filter (who knows whats in it) for 3 years on e85 with no "known" issues. But I changed my chassis and fuel system, went to a Trickflow canister filter that comes with a fabric filter. They claim to have fabric, paper, cellulose and stainless media options. But i can only find the paper option as a replacement, stainless filters only seem to do 100 microns, so whats the snuff. Will fabric be ok?
no694terry is online now   Reply With Quote
Old 04-01-2018, 09:41 PM   #3007
HamFist
Member#: 2112
2000 Impreza 2.5RS
BRP
OE held up for a while, but doesn't flow enough volume. I use a Magnafuel filter with cleanable media. Pressure dropped back to stock with a better filter. It uses a metalized filter media. The first time I cleaned it looked like a soupy sandy puddle on the inlet side, like it had been rubbed in the dirt offroad. The output side looked great. I'm happy with it. The O-rings have held up well, too. It has never leaked. Use -6AN fittings and you can relocate the filter wherever you please.
HamFist is offline   Reply With Quote
Old 01-31-2019, 03:17 PM   #3008
probablyslowestwrx
Member#: 479299
Default good stuff
definitely helped a lot
probablyslowestwrx is online now   Reply With Quote
What do you need to do to use E85 fuel? wantsti Rocky Mountains Impreza Club Forum -- RMIC 37 02-20-2014 01:27 AM
E85 fueling question- 850cc + fpgreen...adjustable FPR? Blown95ImpalaSS Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 5 09-29-2009 07:37 PM
E85-Fueled Z06, 30th Anniversary Corvettes to Pace ‘08 Indy 500 AVANTI R5 Non-Subaru News & Rumors 0 12-27-2007 01:56 PM
E85 fuel available now in Arvada 9/22/06 hotrod Rocky Mountains Impreza Club Forum -- RMIC 9 09-25-2006 02:29 PM
E85 Fuel in Austin? When? dromango Texas Impreza Club Forum -- TXIC 8 06-29-2006 01:32 PM
