Welcome to the North American Subaru Impreza Owners Club Monday October 15, 2018
Old 01-11-2006, 11:11 AM   #1
shotoyan
Member#: 35716
2006 WRX
Obsidian Black Pearl
Default AP stg 1 + headers?
Would running a set of headers with AP stg 1 (stock TBE) cause any problems?
I'm going to be installing my Boost and EGT gauges soon & going through the how-to threads to see how it's done. I'm kinda wary of drilling into the stock manifold (never done anything like that before), so I was thinking I should have a spare manifold handy in case I mess it up. That got me thinking, what if instead of hunting down a spare manifold, I pickup a set of headers? I know my money is better spent on a TBE but I want to get the gauges in sooner than later to learn how the engine acts as close to stock as possible.
FWIW, I'm not even at stg 1 yet, I'm waiting to get the gauges in before plugging in the AP. If all goes well, I'll get the gauges into the stock manifold, then apply stg 1 after a few days of seeing how it runs stock, and then switch to the headers sometime after that. If however I mess up the stock manifold I'll install the headers & gauges first and then flash stg 1 a few days after.
Thoughts?
shotoyan is offline   Reply With Quote
Old 01-11-2006, 11:17 AM   #2
Davenow
Member#: 23676
Considering that the AP stage 1 has a hard time dealing with even an intake, then yes you will very likely have problems.
Either get real EM that can be adjusted, or dont get the headers
Honestly drilling and tapping the stock manifold shouldnt frighten you, its INSANELY easy. I know its intimidating, but I assure you that there is very little chance that you cant handle this.
Its 7 bolts to remove the drivers side manifold, then drill the hole (start with a small bit and work up in sizes till you hit the correct size) Tap the hole and put it back in.
Davenow is offline   Reply With Quote
Old 01-11-2006, 12:12 PM   #3
shotoyan
Member#: 35716
2006 WRX
Alright thanks Davenow, I'll give it a go without the spare...thanks
Just flashed with cobb ap stg 1. 8psi boost joehack98 Engine Management & Tuning 17 01-07-2006 12:38 AM
AP stg.1 or stg.2? spooledwrx Engine Management & Tuning 7 03-03-2005 02:02 AM
AP stg 1 or 2 audio1der Engine Management & Tuning 1 03-02-2005 04:19 PM
WOOHOO AP Stg.1 surprises them! Predator3 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 19 11-20-2004 07:02 PM
CHI: AP stg 1 or stg 2 WRX owners ... cyberwolf Mid West Subaru Owners Club Forum -- MWSOC 0 10-25-2004 01:16 PM
