Welcome to the North American Subaru Impreza Owners Club Sunday May 16, 2021
Old 03-05-2021, 06:11 PM   #1
HixiDixi
Member#: 522799
Default JDM Ej205 Swap
So I've been looking around for an answer to this question and haven't really got a definitive one: I have a USDM 2002 WRX and was wondering if I can use the USDM harness with the JDM ECU and engine with the additional iWire wiring kit for AVCS. Will this work or will I need an AVCS harness? Thanks!
HixiDixi is offline   Reply With Quote
Old 03-05-2021, 07:38 PM   #2
snow_bound26
Member#: 395793
2005 92x Aero
Beige
If you're talking about the USDM bulkhead harness, then yes. You need the JDM engine harness and then either buy a wiring kit or make your own.
snow_bound26 is offline   Reply With Quote
Old 03-05-2021, 08:59 PM   #3
HixiDixi
Member#: 522799
Yes I meant bulkhead, sorry. Thanks a lot man
Old 03-08-2021, 07:21 PM   #4
je03672
Member#: 522375
I used a JDM engine harness and then ordered a jdm body harness separately. I cut all the wires off the body harness except the ones for avcs and ran it through the firewall. Itís only like 8 wires you need I canít remember exactly.
je03672 is offline   Reply With Quote
Old 03-09-2021, 09:59 AM   #5
Bluestreak03
Member#: 125887
2001 EJ207 V7 RSTi,
Mica Blue
Correct, use the ECU and order the AVCS wiring kit, and make sure you change the required pins in the other harnesses
Bluestreak03 is offline   Reply With Quote
