Welcome to the North American Subaru Impreza Owners Club Wednesday May 12, 2021
Go Back   NASIOC > NASIOC Classifieds > New Product Development
Old 03-29-2017, 12:39 PM   #126
subydude
Member#: 80649
2000 2.5 Auto-X RSTi
Sparkly
Originally Posted by KillerBMotorsport View Post
The problem with the Band-Aid Accusump fix is that is will also cause pressure oscillations in use. It also does not have the capacity to flow anywhere near what's necessary for these engines.
When used as a means for priming, or as a damper, they are great.
It depends on the valve type for pressure oscillations. It would not have the capacity to flow on it's own, but that's not the point. The point is as a damper as you later noted. You can't replace a positive displacement oil pump at 7,000 rpm with a reasonably sized pressure canister for very long at all, but you can augment a system that's dropping pressure for a short period of time to help a potential dip in pressure.
Old 04-13-2017, 04:36 PM   #127
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
Originally Posted by subydude View Post
I still think a lower G value would be better here, because otherwise the valve is going to only close briefly and then open right back up still allowing oil to be pushed.
You might be right, or wrong. At this point, without trying, it's speculation. I have no answer, besides that I auto-X on 295s and have a bone dry inlet. I'm also out there to have fun more than being competitive so take that as face value.
You're missing the point here. Throttle time in seconds is not important. Throttle percentage over the course of turns is.
Lets debate this some more, because I think I'm right and so do you. We both need to better detail the arguments here and why I say it IS important is because oil flow changes with on/of throttle. Of course these cars have positive displacement pumps; flow out is dependent on crank RPM, but I think what you may not be considering is how the AVCS (on/off throttle) does effect oil flow.
The other thing to consider is that we may be trying to compare two means of oil making its way up to the head ports. Sloshing is what you'd see in auto-X vs pooling (often called surge) what you see on a road coarse. On a road coarse with sustained Gs the outside head is not flowing back into the pan. Instead it is filling up the head/valve cover. Under a high enough lateral load, even oil from the crank can join the party. Eventually, the head pools a decent amount of oil, reducing the oil available in the sump, and you have starvation.
So while the means of getting oil into the heads may be different, there is also the premise of oil being pumped into an outside facing head for 2 seconds or 6 seconds at full tilt. The longer you're at that load the more you run down the level in the pan. For a road coarse anyway. This is why long sweepers tend to define the oiling system's limitations.
Since you're always turning in autox WHILE on the throttle we're not allowing the oil to settle or the AOS to drain while on course.
This is where my experience differs. That doesn't mean it's right, or you are, we just differ. I had always been a fan of Crawford's A/O separator. Under 96% of conditions it worked well. Truth be told, on all three of our shop cars we never had a single issue with oil coming into the inlet during ANY auto-X events. The ONLY time I experienced the limitations were under severe load at high power levels (+900 crank HP) for long periods of time (5th and 6th gear WOT). The drain on the Crawford, and out unit for that matter, drains fast. If you are off throttle or feathering the throttle, it's drained. Even for a split second it drains fast. Now if you have excessive blow-by, you're getting too much flow through the drain and it WILL blow oil everywhere inside that separator and make it's way out. I've seen that happen, and the assumption at the time was that the drain was not working properly.
Thing is, throttle lifts in autox are incredibly short and there are no gear changes except at the beginning. We build oil up in the head(s) and it never goes away until the run is over.
understood, but if you go into any kind of straight line, or opposite direction (which is done a lot in auto-X) all that oil rushes right back out of the head. It doesn't build up. It might slosh back and forth, but unless you're running a crappy flat baffle it should not be all going directly from one head to the other. At least some, has to make it's way into the pan during each direction change. This is the point of our baffles, and even the factor pan baffles.
I've ran on small lots where I have no issues, or courses where there weren't many slaloms, but all digs and still had no issue. But on courses with a good mix of elements and good speed (like most of my locals and all national courses) I'm pushing oil.
This is great information right here! By your own statement there is a defined set of circumstances that effects the pressure. You want to find out exactly why? Log it! All this takes is knowing the load, durations, pressure, and RPMs. The vid was nice to see something is happening, but it's extremely difficult to pull truly useful data from it. You get more information and I promise I'll work to find or create a solution.
Can placement can have an effect for sure, and physics should always be reviewed.
Absolutely.
Yes, it will prevent the pressure from dropping as much, but is limited on the amount of time it will do that for so it could be the reason the engine blew at the turn's exit vs 3/4 of the way through. Maybe you bought enough time to complete the turn. It's not a solution to the problem is my point. The other downside, and I think it's often overlooked, is that these accusumps are dumb devices. Once pressure is restored they will recharge. Think about this for a second, when you have oil pressure restored, you're likely exiting a corner. When you are exiting a corner, you're very likely WOT. Bearing loads and oiling demands are at their highest. This is the absolutely worse time to reduce system pressure to 'recharge' the accusump. I can't recall who (I want to say OpticalNZ), but they datalogged using an accusump and you saw system pressure drop everything the unit recharged. It was tossed (along with most of his other current oiling system) after discovering that.
So does it have a place, absolutely, but IMO not as a saving grace for engine bearings. There are many more better reasons for owning an accusump.
KillerBMotorsport is online now   Reply With Quote
Old 04-13-2017, 04:39 PM   #128
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
I meant to post this a while back, but some more feedback from a real track guy...
This is a customer our ours that reached out to us a little over a year ago. Concerned with the sustained lateral loads the 818s were seeing on track (and they are impressive out of the box!), but he did not want to go to the extreme of going dry sump if it was possible...
Chris,
I finally got the car out yesterday at lunch time. I have made a few chassis and minor aero tweaks since my last outing and have made improvements in the feel, comfort and balance of the car.
Anyway what is important is the KB pan, Oil Control Valve and Crawford Air Oil Separator all are working well together. Oil Pressure under load throughout the run (25 minutes) stays steady at 74-76psi with oil temp of 220* pulling 1.5 plus lateral G. Off throttle/idle is steady at 55-56psi. (stock EJ205, TGV delete, JDM V37 twin scroll turbo, header and up pipe 285WHP on pump gas).
So the great news for me is confirming my determination not go to the expense of a Dry sump (and prove that a wet sump will work on these cars) so far has been validated.
For KB I am so please your products work as advertised, looking at both the AIM and Cobb data I am seeing 18psi boost, zero knock and intake air temps close to ambient at the throttle body with a STi TMIC. I am far from a Subaru expert but believe that great percentage of the guys that are knocking out rod bearings is more than likely due to detonation and not oil starvation if running a set up close to mine.
Mitch Wright
General Manager
NCM Motorsports Park
505 Grimes Rd
Bowling Green, KY 42101
Old 06-07-2017, 01:24 PM   #129
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
I know this is not Oil Control Valve, but somewhat related. We've released our GR version and just started taking pre-orders for GD version of our Air-Oil Separator. Great addition to any rear racecar, and it's made for that environment in mind too.
We will have units available and on display at Boxerfest and Wicked Big Meet.
Old 06-09-2017, 06:58 AM   #130
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
Someone asked, "How does this work with the oil control valve?" So here ya go...
Old 11-07-2017, 05:49 PM   #131
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
Just a reminder for the track guys, these can sometimes sell out in the spring when everyone is rushing to get their cars prepped for the season. Don't be that guy, early bird catches the worm
We've had awesome feedback in regards to how this product solves one of the boxer engine's downsides; pushing oil out the valve cover breathers under high cornering loads under racing condition. This component eliminates or drastically minimizes that problem.
Feel free to e-mail with any questions you may have
Old 05-10-2018, 08:12 PM   #132
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
Keeping up with race season, we have these in stock. Let us help you design the ultimate oiling system for your track car.
Old 04-01-2020, 12:53 PM   #133
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
Even if this is not the product for you, and you have oiling challenges, that's our specialty.
Shoot us a PM!
Old 04-02-2020, 11:55 AM   #134
Scargod
Member#: 260314
2007 STI
silver gray metallic
Shoot us a PM!
I saw an extended (deeper) pan you made. Looked to be one or more inches deeper. Is that something we can order? More info?
I do need one of your oil control valves...
Scargod is offline   Reply With Quote
Old 04-02-2020, 12:48 PM   #135
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
Our pan depth hasn't changed. It is deeper than stock, but by ~1/2". Any more than that and the belly-pan would need to be removed.
I think you'll be pleased with the OCV performance. It has eliminated a lot of frustration for many track Subies.
Old 03-30-2021, 06:41 AM   #136
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
Just a PSA for all the track guys prepping, we have these in stock and ready to go!
