Welcome to the North American Subaru Impreza Owners Club Sunday May 16, 2021
Rocky Mountains Impreza Club
Go Back   NASIOC > NASIOC Chapters > Rocky Mountains Impreza Club Forum -- RMIC
Old 09-28-2019, 10:58 PM   #1
snow_bound26
Member#: 395793
2005 92x Aero
Beige
Default Open source software
I just moved to SLC and am having some fuel cut issues. I have all the software downloaded and installed but haven't been able to figure out how to log properly so I can try to figure out what's going on and talk to my tuner. Just wondering if someone would be willing to sit down with me for a little while and show me how to properly log and save the data? I'm located in the Sugarhouse area but am willing to drive to you to make things easier.
snow_bound26 is offline   Reply With Quote
Old 09-29-2019, 09:59 AM   #2
Sour_K
Member#: 370021
2008 WRX Hatchback
What are you using to datalog? I'm guessing its not an accessport.
Sour_K is offline   Reply With Quote
Old 10-10-2019, 08:58 PM   #3
snow_bound26
Member#: 395793
2005 92x Aero
Beige
RomRaider
Old 10-11-2019, 11:05 AM   #4
oren
Member#: 31193
2003 WRX Wagon
Are you using Tactrix for hardware or something else?
oren is offline   Reply With Quote
Old 10-12-2019, 12:42 PM   #5
snow_bound26
Member#: 395793
2005 92x Aero
Beige
Yes Iím using Tactrix with EcuFlash and RomRaider. The typical open source tuning programs. Honestly I havenít heard of anything else when referring to open source for the Subaru world.
Old 10-14-2019, 12:13 PM   #6
oren
Member#: 31193
2003 WRX Wagon
Helps to check. For Tactrix, I can send you a logconfig file you can put on an SD Card that will log all the main interesting values. I can also walk you through the process to add more if you need help. Just PM me your email.
Romraider is useful but I found it more annoying to try to drive around with a laptop for a while.
I'm assuming you have the latest Tactrix with an sdcard slot. If not, you'll have to do the computer.
Old 10-15-2019, 09:16 AM   #7
snow_bound26
Member#: 395793
2005 92x Aero
Beige
I know how to select parameters of what I want to to log. The problem is I can't get it to show as a spread sheet per 100rpm. When I pull it up after saving it only shows what I've saved like a screen shot of the live view.
And yes driving around with a laptop is a pain. I have a PC based tablet I'm using which runs the programs fine but I usually ask a friend to come along to start and stop it so I'm not. I did buy the tactrix used but I'll see if it has an sd slot.
Old 11-10-2019, 04:20 AM   #8
K2marer
Member#: 495564
Hello,
Complete software is split into small modules and sub-features. An overall analysis of the complete solution is designed and discussed in the team. After that, the bare minimum features, which are required to release the first version is decided. It probably will be a good suggestion to have an option for it. In this case visit this software development company site https://vilmate.com
K2marer is offline   Reply With Quote
Old 11-16-2019, 04:18 PM   #9
Anub1s
Member#: 81106
2011 STI Hatch
Lightning Red
Late to the party but did you set the log file output location under settings?
Pro-tip if you're doing the logging by yourself, set your parameters for logging, save it to a profile, easy loading. Then, turn the defogger switch setting on, that way you only have to hit the defogger button to start and stop and not look over at a screen.
Anub1s is offline   Reply With Quote
Old 11-26-2020, 12:54 PM   #10
K2marer
Member#: 495564
Hotel management system but essential to providing the best customer experience. Often the hotel equipped itself with very complex tools that, in the end, will not be used by the staff. When choosing a hotel management system to consider first what you need. Check https://www.otelms.com/
