Welcome to the North American Subaru Impreza Owners Club Saturday May 15, 2021
Old 04-12-2021, 02:53 PM   #126
YungSav_SG
Member#: 513265
Originally Posted by K3rm1tth3fr0g View Post
You'll probably make around 300WHP with those mods listed. Biggest thing holding you back is your turbo, the VFs really don't do great anywhere but the midrange. But also remember, comparing and basing judgements of tunes and setup's purely on peak horsepower is not ideal because of how much horsepower numbers can vary dyno to dyno.
My tuner's Mainline dyno measures a 2020 STI at 190-200WHP (it makes 310 @ the crank) but a stock 2020 STI measured on a Dynojet would make easily 260WHP. Lots of variability makes comparing different dynos hard and the data from separate dynos virtually useless for direct, hard comparison purposes.
I would ask your tuner what a stock STI makes on their dyno because the STI has made ~300HP at the crank for 15 years and that will give you a good judge of if that "300WHP" is something you'll be okay with. 300WHP is a lot and can make most people happy if its a daily. Especially because at a later date you could slap an 18G on your setup and probably hit your HP goal.
I know personally the 260 WHP on my EJ205 VF39 bugeye with Headers and 1050Xs feels a lot faster than "260" sounded on paper.
One last thing I'll mention is ethanol. If you have E85 fuel available near you, it is worth getting a quote for a flex fuel tune in my opinion due to just how much better ethanol performs. Easy 40+ WHP gain and prices are pretty good on fuel.
Good luck!
Thanks Iíll definitely message my tuner and see what he says and go from there. Im about 90% sure he uses a dynojet. I know my 06 Forester made 280whp on a dynapack and it felt super quick for a daily I was hoping to gain an extra 40-50 hp on my WRX since it has stock bigger injectors than the forester and I saw @Synolimit make 330hp 360tq on his 09 with stock injectors so I was hoping to come close to those numbers having almost the same upgrades. As for E85 itís hardly available in Canada unless you go to BC Iím in Ontario so itís a little hard to get and I donít want to use meth Iíve heard too much horror stories so Iím trying to get the most out of the vf52. Planning on upgrading the turbo and stuff in the future but for now while dailyíing it I would love to get the max I can safely. Dont want some aggressive tune thatís gonna blow my motor either.
YungSav_SG is offline   Reply With Quote
Old 04-12-2021, 03:02 PM   #127
K3rm1tth3fr0g
Member#: 508105
2002 Black WRX Wagon
VF39 + 4.44 5MT
Originally Posted by YungSav_SG View Post
Thanks I'll definitely message my tuner and see what he says and go from there. Im about 90% sure he uses a dynojet. I know my 06 Forester made 280whp on a dynapack and it felt super quick for a daily I was hoping to gain an extra 40-50 hp on my WRX since it has stock bigger injectors than the forester and I saw @Synolimit make 330hp 360tq on his 09 with stock injectors so I was hoping to come close to those numbers having almost the same upgrades. As for E85 it's hardly available in Canada unless you go to BC I'm in Ontario so it's a little hard to get and I don't want to use meth I've heard too much horror stories so I'm trying to get the most out of the vf52. Planning on upgrading the turbo and stuff in the future but for now while daily'ing it I would love to get the max I can safely. Dont want some aggressive tune that's gonna blow my motor either.
A good set of equal length headers and a cylinder 4 cooling mod would be next on my list if I were you. That combo should reduce some knock by evening out cylinder head temps + just lowering EGTs in general. And depending on which header you get, you'll have more power all around with similar or potently even better spool (Killer B).
If you're trying hard to make over 300, stock injectors may be an issue as 565cc is not very much flow for a 2.5L and your tuner may need to pull power back for safety sake when dynoing so just keep that in mind. A set of ID 1050Xs (or whatever 750CC+ injector your tuner suggests), is a good future proof way of allowing you to max out your current setup and keep fueling safe, while preparing yourself to slap a bigger turbo on down the road with less hassle.
K3rm1tth3fr0g is online now   Reply With Quote
2010 WRX VF52 331/374 on 93+ 317/351 on 91 boost-o-matic Proven Power Bragging 32 01-23-2013 02:09 AM
11 wrx hatch wheels bigvicswrx Interior & Exterior Modification 11 12-19-2011 08:28 AM
FS : Nameless Axelback $350 fits hatchback came off 11 wrx Jermaine2011wrx Engine/Power/Exhaust 2 12-16-2011 10:32 PM
09 WRX Stock Turbo Retuned on 93 - Airboy Plot RicersWetDream Proven Power Bragging 6 08-27-2011 09:19 PM
Max PSI on 93 octane, conflicting results. Tgui Open Source Reflashes 4 05-28-2009 09:55 PM
