Welcome to the North American Subaru Impreza Owners Club Tuesday May 11, 2021
Old 04-10-2021, 06:36 PM   #1
LakixPompa
Member#: 521740
Default Can anyone help me indenting these wires ? 04 WRX
The 1 black wire comes up from the dash I知 not sure what it should be connected to.
https://ibb.co/GTbhJV6
These two wires blue/black and black are come from the floor underneath the seat, I also found a connector (the white on on the pic) that has been connected to something underneath the seat , and it had no wires, I assume it could be these two wires , whereas which wire should go into what hole of the plug. (I have a airbag light on my dash, could it be from this ? ) Apologies for the mess, I知 working on fixing the carpets but noticed these wires underneath the seat that don稚 connect to anything
https://ibb.co/yYTmqyS
LakixPompa is offline   Reply With Quote
Old 04-10-2021, 11:47 PM   #2
AliBenn
Member#: 487
1998 /2005 STunIcorn
Acadia Green RS-T
Dang
Those wire so thin I would guess speaker wires
Old 04-11-2021, 01:26 AM   #3
LakixPompa
Member#: 521740
Speaker wires form underneath the driver seat ? It痴 super weird because the connector I showed (white) was plugged in , but the wires were missing , I assumed that these wires were for it, but now I知 even more confused ***128514;***128514;. Any idea about the black wire from the dash . Appreciate you for taking your time to respond .
Old 04-11-2021, 03:52 AM   #4
Diavolo_
Member#: 522840
Did you strip them back that far? or just find them like that?
do you have a volt meter?
I would bet that black wire from the dash is a ground wire someone added for something that isnt there anymore. gauge pod maybe? On the other end theres probably just a screw through the body on the other side of that kick panel. Did you see where the wire goes?
Looks like its headed to a common spot to ground something, and black is a typical ground wire color.
The other wires under the seat could be for a factory subwoofer. I couldnt find a picture of a harness to confirm colors but a picture of a factory sub looks like that clip could go right in. Usually an under seat factory sub attaches with a bracket to a seat rail on the the drivers seat, on the rail closest to the center console. does it look like there used to be something there? maybe an impression in the carpet or a mark from a bolt on the rail?
Maybe someone who didnt know what they were doing tried to wire into an audio signal there and chopped off the plug.
Regardless it looks like a speaker harness plug. do the doors have aftermarket speakers in them?
Airbag wiring will all be yellow or pink. I think in Subarus its all yellow. It will be very bright and obvious and separated from other wires. Therefore I do not think that blue/black wire under the seat has anything to do with your airbag light being illuminated on the dash.
Diavolo_ is online now   Reply With Quote
Old 04-11-2021, 11:33 AM   #5
LakixPompa
Member#: 521740
Thank you so much for this information, I値l double check underneath the seat if there used to be something there. I found the wires broken off (stripped only a little bit) and then I decided to strip them. I wonder what is causing my airbag light to be on then .
Old 04-11-2021, 03:47 PM   #6
Diavolo_
Member#: 522840
Originally Posted by LakixPompa View Post
Thank you so much for this information, I'll double check underneath the seat if there used to be something there. I found the wires broken off (stripped only a little bit) and then I decided to strip them. I wonder what is causing my airbag light to be on then .
in my 05 Legacy the air bag light came on and i had to re-solder a connection up by the rear view mirror to fix it.
so it could be something strange like that in your car too.
lucky for me someone on the Legacy forum knew about that problem, because even trained mechanics might not have known about that. some people spent a lot of money and time and frustration chasing down those problems. fortunately it took me about an hour of time and a little blob of solder.
coincidentally the problem for me occurred right after i had replaced my heater core, so I had taken the dash out and stuff, and was worried i had left one of the airbags unhooked or something, but nope. it was a solder joint.
just be careful not to set your airbags off if you go poking around while the battery is hooked up. theres sensors that if you unmount and turn over the airbags will think the cars in a roll over and they will deploy.
if you have a similar problem, and a similar overhead console check this out:
https://legacygt.com/forums/showthre...149073p13.html
Old 04-11-2021, 08:06 PM   #7
AliBenn
Member#: 487
Acadia Green RS-T
All airbag harnesses are wrapped in a yellow sheath by every manufacturer in US
Those are not airbag wires
Could have 2 separate issues
Guessing the seat mounted airbag yellow pigtail is not connected
Any way you can turn on radio, jump in back seat and make sure your hear sound from both rear speakers?
Old 04-12-2021, 03:13 PM   #8
LakixPompa
Member#: 521740
I checked today, turned on the radio went to the back, and the sound coming out of the rear door speakers, so that's fine I assume, (the wires that were under the seat still disconnected) also, the airbag wires under the seat are connected (yellow wrapped wires), I took off the airbag from the steering wheel and the airbag was also connected, I'm so lost rn. I don't know why i still have the airbag light on... Is there a way to check exactly what it could be? With romraider or something IDK. I have a digiprog 3 and ,xtool x100 scanner, and that doesn't really tell me anything.
Old 04-13-2021, 04:27 PM   #9
Diavolo_
Member#: 522840
Did you see my post about the over head console and the airbag light?
i put a link above. maybe thats your problem.
also, its an airbag fault light? or is it telling you your passenger airbag is off because no one is in the seat?
Old 04-13-2021, 05:13 PM   #10
snow_bound26
Member#: 395793
2005 92x Aero
Beige
Does your horn work? If the clock spring is broken then it typically trigger the airbag light and the horn won't work.
snow_bound26 is offline   Reply With Quote
Old 04-13-2021, 11:46 PM   #11
LakixPompa
Member#: 521740
I have checked, and I do not have a overhead console, since its a 04 wrx, I don't think they come with that, at least mine doesnt.
Old 04-13-2021, 11:48 PM   #12
LakixPompa
Member#: 521740
Yes, my horn works just fine. I'm so confused now. Everything is plugged in except the two wires underneath the seat which I shared the photo, and the airbag light is still on...
Old 04-13-2021, 11:58 PM   #13
Diavolo_
Member#: 522840
edit:
the blue/black wires under the seat have NOTHING to do with the airbag light, because you can see the yellow airbag wires under the seat correct? and its plugged in?
you dont have map lights?
P/N 84621AE020NEG
I tried to look at a pic of what might be in your car, it doesnt seem like it has a circuit board in it, like the Legacy's from around the same time period does.
however its probably a similar problem with some corroded or broken solder joint somewhere.
Grab the yellow connectors under the seats, and squeeze the two sides of the connectors toward each other.
then report back
Old 04-14-2021, 12:09 AM   #14
Diavolo_
Member#: 522840
im not 100% certain but the airbag module is different than the ECU. the dealer can connect to it, or theres some other sort of scanner thing you need. i think it flashes a certain amount of times to indicate where the problem is.
probably just easier /cheaper to call a shop on that instead of buying a device you're not likely to use again and might not be qualified to.
Old 04-14-2021, 12:57 PM   #15
LakixPompa
Member#: 521740
edit:
P/N 84621AE020NEG
then report back
Will do , thank you so much , I値l let you guys know as soon as I do it
Old 04-17-2021, 12:49 AM   #16
Diavolo_
Member#: 522840
did that work?
Old 04-18-2021, 02:08 AM   #17
LakixPompa
Member#: 521740
Nope , still on
Old 04-18-2021, 02:40 PM   #18
AliBenn
Member#: 487
Acadia Green RS-T
Your probably going to have the airbag code read
Tip a tech to hook up to his $2000 code reader
Or
Take to dealership and pay $200+ just to read
Smaller shops are cheaper and easier to deal with BTW
Possible as easy as a front seat buckle
