Welcome to the North American Subaru Impreza Owners Club Friday May 7, 2021
Old 08-18-2006, 10:28 AM   #1
elohdaeh78
Member#: 61395
2005 WRX
CGM
Default accessport boost readings on more then one car at a time?
Can you use the accessport to read realtime boost on more then just the car that is married to? I want to hook it up to my friends car to see what kinda boost he is running, also my accessport is for an 05 but he has an 02. Any ideas?
elohdaeh78 is offline   Reply With Quote
Old 08-18-2006, 05:32 PM   #2
parker
Member Status: Member
Member#: 46241
- Can I get
a wayo
Good question, I'm not sure, it wouldnt hurt the car to try though.
My guess is it needs to be married to communicate properly (in realtime)
parker is offline   Reply With Quote
Old 08-19-2006, 10:18 AM   #3
AllAWD
Member#: 17079
I don't know if that will work, but if if doesn't you can use the accessport cable and a labtop loaded with ecuexplorer to read the boost as well as many other values.
AllAWD is offline   Reply With Quote
Old 08-20-2006, 05:58 PM   #4
desertaero
Member#: 88954
'05 Saab 92X Spec C
desert silver metallic
It works...i did it for someone else and then used my ap shortly after. There were no ill effects.
desertaero is offline   Reply With Quote
Real Low boost readings on Accessport?? Kings028 Engine Management & Tuning 0 05-05-2010 09:41 PM
Will V2 accessport install on more than one computer? AntiZeroTrip AccessPort 2 05-17-2008 10:32 PM
acessport flashing more then 1 car Cmathews AccessPort 3 04-19-2006 02:53 PM
Different model rotas on car at same time? BelvnAWD Tire & Wheel 4 08-04-2005 11:05 AM
Has Anyone blown more then one MAS??????? Xscreamer Technical Forum Archive 5 06-30-2000 03:43 PM
