Welcome to the North American Subaru Impreza Owners Club Saturday May 8, 2021
Old 06-27-2013, 10:30 PM   #1
Rockymtnsubie
Member#: 360781
1999 Forester L
Green
Default What motor to swap into my 1998 forester
Hey Guys have a few questions about swapping!
I have a 1998 forester and want to swap a wrx engine into it
But just have a few questions!
First off I have around $3500 to do the swap. And my uncle has his own shop with lifts and everything I would need to do it. It's not my daily driver so I'm not worried about it being out for a while. What are some of the biggest problems when people do a swap into a forester.
Also what are some websites for rebuild or used engines?
What years of the wrx engines are the a good fit?
2002?
Also can I use my 5 speed transmission?
And how much will it cost?
Thanks a bunch and sorry I'm a newbie
Rockymtnsubie is offline   Reply With Quote
Old 06-28-2013, 02:36 AM   #2
lavid2002
Member#: 226864
Wrong section. You're going to need to swap a wiring harness and ECU over with the WRX engine.
You can find used engines here in the for sale section. Your 5 speed should work fine on a wrx engine if I am not mistaken. I think your bell housing only has 4 bolt holes and the wrx engine has 6 IIRC. Might want to check yourself though.
Old 06-28-2013, 06:55 AM   #3
Paul
Member#: 56203
00 RSTI Coupe
Twin Scroll 2.5XTR EJ207
the holes on the bellhousing arnt really a issue.
OP: I have a buddy in the same shoes and with the same budget. 100% get a totaled 02-07 WRX and swap what you want over and sell everythin else. You can find them on Coparts.com all day for under that price.
Old 06-28-2013, 12:00 PM   #4
NW2TONE
Member#: 212509
unde your hood makin
your **** go faster
save yourself the trouble and have the wiring harness merged by iwire. That way all your old wiring will be plug and play along with the new wrx engine. and youll have working windows and dash with a 02 wrx motor.
TRUST me i get clowns coming into the shop all day with problems of swapped dashes and such.
NW2TONE is offline   Reply With Quote
Old 02-25-2021, 10:58 AM   #5
UlisesC
Member#: 522616
Default Some info that may help
I just looked into this for my project and you want to get an engine from 99-04 wrx. You'll need the complete engine, wiring harness from the car (unless you send yours to Iwire to merge, recommend this option cost is 850***128556 ecu, cross member, fuel module, fuel pump. Hope that helps.
UlisesC is offline   Reply With Quote
