Welcome to the North American Subaru Impreza Owners Club Sunday May 16, 2021
Old 11-14-2013, 04:08 PM   #1
BaronOBeefdip
Member#: 320335
2005 STi
It's WRB-y
Default Baron's 2005 STi journal - car is gone, now have R34 GT-R
Hello NASIOCers, long time coming...but I am finally making my journal here.
I've been obsessed with cars as far back as I can remember, so I can't really get enough of 'em actually. I've also been a longtime enthusiast of motorsports, including WRC, which is where the love for Subaru began. Watching the GCs dominate in the late 90's and GCs/GDs in the early 00's was so memorable. Then when I saw that the STi was coming to U.S. shores for the '04 model year, it was desire right there. Maybe that's why I'm so fond of the GDB chassis. I just knew I had to have one some day. I never gave up that dream and finally, in May of 2012, I was able to get one after an extensive search. I knew what I wanted, so I was on a two year hunt for an untouched, low mileage, one owner car with a clear history/title, and it had to be a fair price to boot!
I found the car the same day that Subaru of Gainesville had listed it on the internet and somehow, I was the first one to call about it. It had just over 28k on the odo, one owner, and was bone-stock. It wasn't listed more than 24hrs and after talking it over with the salesman, my mind was made up: I had to jump on this one because the price was remarkably fair compared to what the rest of the market was doing at the time. After working out a fair deal, it was shipped to me up in Nebraska, and it's been a joy to own ever since.....
Only problems were one wheel had some minor curbage and there were many bug marks permanently in the paint all over the front clip, because the owner did not like to clean I guess. After the flurry of getting things done right after the first month of ownership(it really needed a deep clean, since the previous owner did not care much, and the dealer's "detail" department was less than optimal in their work on it), I decided to fix the major cosmetic issues rather than put money into performance mods. I had the front bumper, hood, hood scoop, and trunk lid repainted. Also had some surfaces buffed and small dents removed. The rest of the car could use a good buff and there are a few small rock chips here and there that I will be touching up myself, but other than that, the paint and clear coat is in good shape and it's a damn perfect car. I am very particular and detail-oriented, so this translates to my car.
As for my plans with it, it's a nice weather toy only. My goals are pretty modest and not attention-grabbing, so to some of you my journal may be somewhat boring and the upgrades may be rather slow since I won't be dumping all my money into it(read: not abusing it and racing irresponsibly).
I have a pretty well-thought out mod path and I know most of the parts that I want to put into it(but suggestions are welcome), so whatever the best power gains from the best possible tuning, I will be happy with. When I'm done upgrading, I'm shooting for somewhere between 330-380whp, but it won't be the easiest to obtain 320 on the 39. I will NOT be going rotated or FMIC probably ever. I want to retain responsiveness and drivability, so I will be staying with the stock turbo as long as I can, as well as the TMIC orientation. I know there's really not that much lag involved, but everyone goes rotated and FMIC around here and I'm not really looking for huge power. I want to be a bit different. Who knows, I may eventually consider an 18 or 20G though; would love to have a ball-bearing turbo. Too bad VF34's don't pop up very often! Most everything else is fair game. I do plan on replacing or upgrading much of the chassis and suspension components relatively soon.
As I said my journal may be boring to some and it will take some time for parts to go on it, but I welcome discussions on anything and like to talk technical, so have at it! I'm over on IWSTI under the same name.
http://i.imgur.com/fF5a3.jpg
More to come!!
BaronOBeefdip is offline   Reply With Quote
Old 11-14-2013, 04:08 PM   #2
BaronOBeefdip
Member#: 320335
2005 STi
It's WRB-y
The obligatory Mod List!
RED = Don't have yet, but planned/want to buy
Orange = Pending/Waiting to go on the car
Green = Installed/completed
Blue = Old setup
ECU
  • Cobb AP tuning by jazTuning
Engine
  • Rotella T6 5w-40
  • DEI Reflect-A-Gold - heat shield and TMIC
  • Block machine work, crank polish, dynamic balance, and assembly by IAG Performance
  • Head resurfacing by IAG Performance
  • Closed-deck conversion by IAG Performance
  • Powdercoating by Trail Performance - Papillion, NE
  • Headwork and valve job by Daly's Machine Co. - Omaha, NE
  • Turbo rebuild service, coated turbine housing, and upgraded billet compressor wheel by Pavel @ PRE Tuning
  • ARP 2000 head studs
  • Cobb 3-port EBCS
  • Cobb turbo heat shield
  • Cobb XLE BPV w/GrimmSpeed BPV gasket
  • CSF Cooling 3076 performance radiator
  • Denso U-Groove K20HR-U11 spark plugs - gapped to 0.027in
  • Flex Innovations grounding kit
  • GrimmSpeed manual boost controller
  • GrimmSpeed VF series wastegate bracket
  • IAG StreetSeries AOS system
  • JE ProSeal 0.039in headgaskets - 100mm
  • KillerB oil baffle tray
  • KillerB oil pickup tube
  • KSTech 73mm cold air intake w/AMSoil EAAU3570 cone filter
  • LIC Motorsports aluminum head plugs
  • King MB5382XPG main bearings
  • King CR4125XPGSTDX rod bearings
  • Manley Turbo Tuff 99.75mm 8.5:1 C/R forged pistons
  • Manley Turbo Tuff I-beam forged rods w/ARP 2000 bolts
  • Motive AutoWerks composite top-feed TGV deletes
  • New 06+ STi OEM oil pan
  • New OEM 10mm oil pump
  • New OEM water pump
  • New OEM Subaru crank pulley, valve cover gaskets, timing belt, timing components, brackets and other hardware/gaskets
  • PTP turbo blanket
  • Perrin throttle body coupler
  • Subtle Solutions alternator cover
  • Subtle Solutions radiator cover
  • Tomei timing belt guide
  • Tomei silicone turbo inlet
  • Torque Solution billet radiator stays
  • Torque Solution billet pitch stop arm
  • Turn In Concepts FU Cam bolts
  • AMR/ETS/Process West TMIC
Fuel System
  • '07 OEM STi top-feed rails
  • DeatschWerks DW301 340lph fuel pump - hardwired
  • Earl's Pro-Lite Ultra 350 hose and Earl's fittings
  • FueLab 51502 FPR and gauge
  • Injector Dynamics 1000cc injectors
  • iWire Services fuel pump hardwire kit
  • New OEM fuel filter
  • Tomei FPR adapter
Exhaust
  • All pre-turbo exhaust components coated by SwainTech - TBC-EX White Lightning coating
  • Blitz Nur Spec Touring CBE
  • GrimmSpeed PnP OEM exhaust manifolds
  • GrimmSpeed Hi-Flow crosspipe
  • GrimmSpeed Hi-Flow 38mm EWG uppipe
  • TiAL MV-S blue-top 38mm EWG
  • Tomei Expreme Ver.2(two-piece) bellmouth catless downpipe
  • GrimmSpeed/Tomei/Blitz gaskets
  • Cobb/Cusco/Kartboy exhaust hangers
  • IAG Performance/GTSpec/AMR/Tomei Expreme UEL(when/if new turbo is had)
Drivetrain
  • New Subaru OEM flywheel
  • South Bend Stage 2 Daily clutch kit
  • Subaru Extra-S 75w-90 gear oil
  • Subaru OEM LSD oil
Suspension/Handling/Chassis and Settings
  • Cusco 22mm sway bar - front
  • Cusco 22mm adjustable sway bar - rear
  • Cusco front endlinks
  • Fortune Auto 510's Version 6 - 9k/8k Swift springs, rear adjustment extenders
  • Fortune Auto camber plates - F/R
  • Kartboy front and rear stay shifter bushings
  • Kartboy solid rear endlinks
  • Koyo sealed radial bearings - front
  • STi GrpN motor mounts
  • SuperPro RCA kit
  • Whiteline rear sway bar mounts
  • Whiteline PU sway bar bushings - F/R
  • Torque Solution shift linkage bushings
  • Whiteline/Cusco lateral links
  • Cusco/MSI trailing arms(if needed)
  • Replace all bushings with Whiteline/Kartboy/SuperPro PU bushings
Wheels/Tires/Brakes
  • AMS stainless steel brake lines - F/R
  • ATE Super Blue brake fluid
  • Bridgestone Potenza RE-71R - 255/40/17
  • Cosworth Streetmaster brake pads - F/R
  • DBA 4000 ClubSpec T3 slotted rotors - F/R
  • RAYS Volk Racing CE28Ns - 17x9 +45 - bronze
  • RAYS 17HEX lugs - black
  • Advan Racing RGII wheels - 17x8.5 +50 - white - SOLD
  • Bridgestone Potenza RE-01R - 245/40/17
  • SSR Type C RS - 17x8.5 +48 - anthracite grey
  • WORK RS closed-end lugs - blue and red
Exterior
  • Bad Mutha's custom front plate delete w/Totsubo mounts
  • ChargeSpeed Bottom Line carbon fiber side skirts
  • ChargeSpeed Bottom Line carbon fiber rear skirts
  • JDM genuine S203 rear wing and repainted JDM STi trunk lid
  • JDM Subaru multicolor crystal ion fog lamps w/HeadLight Armor clear film protectors
  • JDM Subaru WRB fog lamp surrounds and covers
  • JDM genuine Subaru V-Limited lip
  • JDM-style taillight "mod"
  • Kansai Service carbon fiber diffuser
  • LED license plate bulbs
  • Matte carbon fiber-wrapped roof
  • Philips Xtreme Vision 85126XV D2R bulbs
  • RallyArmor UR black flaps w/grey lettering
  • Tein hood dampers
  • 35% front/20% rear tint
  • 4 inch blue vinyl windshield visor
  • Debadged except for a few STi badges and stars in grill
  • New weatherstripping on wing and hoodscoop
  • Lens restore and amber removal by Lightwerkz
  • ChargeSpeed Bottom Line Type 1 carbon fiber lip
  • PIAA H3 crystal ion bulbs
Interior
  • AutoMeter Sport-Comp digital gauges - boost, oil pressure
  • AutoMeter ES digital wideband AFR
  • FastWRX OEM-style dead pedal
  • JDM red hazard switch
  • JPM Coachworks black alcantara shift boot w/red stitching
  • Pioneer AVH-P1400 dual-din head unit
  • OEM-style WRXtra 52mm 3 gauge pod
  • WC LatheWerks titanium-blued shift knob(weighted!)
  • WC LatheWerks brushed stainless steel reverse ring
  • Those rare blue floor mats with the STi logo on them
Old 11-14-2013, 04:14 PM   #3
BaronOBeefdip
Member#: 320335
2005 STi
It's WRB-y
Old 11-14-2013, 04:15 PM   #4
BaronOBeefdip
Member#: 320335
2005 STi
It's WRB-y
Old 11-14-2013, 04:22 PM   #5
liltoua
Member#: 206802
1998 2.5rs
Wow your car looks in great condition!
liltoua is offline   Reply With Quote
Old 11-14-2013, 05:34 PM   #6
BaronOBeefdip
Member#: 320335
2005 STi
It's WRB-y
Thank you!
Old 11-24-2013, 10:31 AM   #7
BaronOBeefdip
Member#: 320335
2005 STi
It's WRB-y
So....I got the exhaust a week ago but due to being busy, I recently checked everything over. The box was quite torn up unfortunately, however I don't think it was from shipping, I just think whoever drop shipped it was sitting on this for a while. Also the two hanger mounts on the muffler are bent.
I emailed Cygnus Performance(this isn't their fault btw!) to see what they can do for me as far as a return for a better one. This is kind of a bummer since I jus got this and haven't even used it. Oh, and let's not forget it wasn't cheap either. I'm a name-brand fiend.
Here are some pics:
http://i.imgur.com/E6QzR3Z.jpg
http://i.imgur.com/SNjjFWk.jpg
http://i.imgur.com/ymKT2a9.jpg
Let me just say that the welds are pretty nice, especially the machined ones. The finish is superb and you can tell there is quality all around. I'm just disappointed that mine isn't perfect. Obviously I can't post a review 'til next season of sound and fit, but you get the idea. Everything feels really solid in these pieces.
Below is the flange that meets up to the DP. Contrary to what others are saying, this is not a 2.5" taper, but instead it is 2.8". I originally was going to have a local shop cut this part out and replace it with a SS 3" portion.
I have since changed my mind as a) I don't believe there will be any noticeable restriction in .2" difference of diameter and b) I just don't want to hack up this gorgeous piece!
http://i.imgur.com/dpMWTAi.jpg
Onto the business end:
http://i.imgur.com/HarsX6o.jpg
http://i.imgur.com/19pRbxw.jpg
The last three pics show the bent hanger mounts, and the middle one shows the angle of distortion, as the pic was taken directly above the muffler.
There's a physical dent in the muffler at each weld spot from bending inward. Not cool.
People could say "Well why don't you just hammer it back into place?!" Well, I don't want to break the welds or anything. "Then just apply heat to it!!" I don't want to ruin the finish.
http://i.imgur.com/wYUbgSK.jpg
http://i.imgur.com/cvomNdp.jpg
The mounts are supposed to be parallel to the ground by the way...woops!
http://i.imgur.com/kuEYZhb.jpg
Old 11-24-2013, 12:13 PM   #8
mcganz121
Member#: 138569
2017 A4 Quattro
I had a bent hanger on an Invidia g200... There is now a loud rattle after hammering back in place. I'm not sure if something was damaged inside the muffler.
mcganz121 is offline   Reply With Quote
Old 11-24-2013, 02:38 PM   #9
thrasher
Member#: 40579
2002 WRX Stage 2+
Tuned by IA Performance
Sucks about the exhaust. Those wheels are so freakin sweet. My favorite wheels ever, and the color goes so well with wrb. You have excellent taste!
thrasher is offline   Reply With Quote
Old 11-24-2013, 02:50 PM   #10
BaronOBeefdip
Member#: 320335
2005 STi
It's WRB-y
^^Yeah, that's another reason I don't want to take a hammer to it....
^Yep, but I'm hoping Cygnus takes care of me though. Thanks for the compliment! The only thing is, I wish they were the bronze color, but I can't be too picky. They aren't flashy, but they look so good.
Old 11-24-2013, 02:55 PM   #11
bdi
Member#: 66033
05 STi
Word up!! Good luck with the build!
Oh and nice wheels...they used to be mine
bdi is offline   Reply With Quote
Old 11-25-2013, 05:10 PM   #12
BaronOBeefdip
Member#: 320335
2005 STi
It's WRB-y
Oh hey man, thanks!
Ya know I'm still really grateful that I was the lucky one to snag these! Really makes my car unique!
Old 12-16-2013, 11:54 AM   #13
BaronOBeefdip
Member#: 320335
2005 STi
It's WRB-y
Again, it's been a while since I've been in here, but an update on the exhaust trouble:
After a long email conversation with Geoff @ Cygnus, it looks like I will be getting a replacement directly from Japan which may take up to two months to get to me since I was told I was the only one in the country with a brand new Spec Touring on his hands. Pretty cool, I think! That just makes it more "special" for my case! I'm not worried at all about the delivery time since the car is in storage. FedEx came to reclaim it this past Thursday, so now we play the waiting game.
I will say I am a bit concerned about the replacement though, seeing as how there was basically no damage protection packaging in the box I got. I hope/have faith that Blitz Japan actually packs their exhausts with better care, so I'm chalking this up to the distributor/FedEx for the lack of decent packaging/courier damage. I could tell that the distributor had been sitting on this piece for a while and that they probably threw out some of the original packing contents long ago. Anyone out there with a Blitz system that can chime in on this? How was yours delivered?
Again, Geoff @ Cygnus has been nothing but a great help and it's nice to know he treats his customers this way. I can say I will go back to him in the future!
Old 12-16-2013, 12:38 PM   #14
A-man07
Member#: 271525
7/2 STi/WRX wagon
SWP/AW
Digging the SSR wheels. They are some of the best. Good luck on the exhaust.
A-man07 is online now   Reply With Quote
Old 12-27-2013, 04:08 PM   #15
BaronOBeefdip
Member#: 320335
2005 STi
It's WRB-y
That they are! Hey thanks! I've seen your journal over on IW and your car is quite impressive as well.
Recently went in on a group buy with 17 other people to get some ID1000 injectors for a great price that I just couldn't pass on, so now just waiting on delivery of those.
Girlfriend also got me a Killer B oil baffle and Cobb EBCS fitting kit for when I get the EBCS from them. She's great!
Old 03-07-2014, 02:49 PM   #16
BaronOBeefdip
Member#: 320335
2005 STi
It's WRB-y
Small update:
Took delivery of some MAW Composite top-feed TGVs, '07 STi OEM fuel rails, lines and FPR. So all that's left is some extra bit of fuel hose, then it's E85 here I come!
Still have some other stuff I will be placing an order for soon, including the rest of my exhaust system with EWG, Fortune Auto coilovers, and other suspension bits. Speaking of exhaust.....my Blitz CBE still isn't here....sigh....
So I happened across this thread here for a set of lovely Gram Lights 57 Optimise for a decent price. I always have liked most GL designs and this one is a favorite. What do you guys think of WRB on these?? God I'm a sucker for wheels...
Old 03-07-2014, 03:21 PM   #17
LatentWagen
Member#: 50315
0806 LGTspecB & Saab
9-2xAero5MT DGM & MBP
Going from those SSR wheels to the Gram Lights would be a downgrade IMO.
Car really looks great. I would have words with the shop that sprayed your rear bumper though. Overspray everywhere!
LatentWagen is offline   Reply With Quote
Old 03-07-2014, 03:34 PM   #18
BaronOBeefdip
Member#: 320335
2005 STi
It's WRB-y
I was really going to keep both sets!
Thanks, I'm glad you think so.
The only thing I've had resprayed on the rear was the trunklid, and that shop pulled the lid off completely, otherwise yeah, I'd be pretty annoyed if someone thought that was an acceptable job. I never had the rear bumper resprayed(although I'd like to, there are some marks that bug me). Weird though, I was under the impression that some of the chassis comes slightly blue from the factory due to their paint process....
Old 03-18-2014, 04:45 PM   #19
yamahaSHO
Member#: 73932
2005 STi EFR 6758
04 S2000 EFR 7064
Originally Posted by BaronOBeefdip View Post
Small update:
Get it done!
yamahaSHO is offline   Reply With Quote
Old 03-18-2014, 05:15 PM   #20
ryan s.
Member#: 276486
'08 Lifted Outback
Wow, beautiful '05. Probably one of my top 5 favorites on NASICO.
ryan s. is offline   Reply With Quote
Old 03-18-2014, 05:18 PM   #21
Brandon2k13
Member#: 376571
A Subawooooo
Very nice ride!
Brandon2k13 is offline   Reply With Quote
Old 03-18-2014, 07:57 PM   #22
blkbugeye
Member#: 287821
2005 WRX STi PSM
*sold* 2002 WRX Sedan MBP
Car looks great man!!
blkbugeye is offline   Reply With Quote
Old 03-21-2014, 03:14 PM   #23
BaronOBeefdip
Member#: 320335
2005 STi
It's WRB-y
Originally Posted by yamahaSHO View Post
Get it done!
Just got fuel hose and clamps, so looks like I'm ready on that end. Much more to go though!
Thanks for the compliments guys, much appreciated!
Here's a small gripe:
So I call up the Blitz importer a couple weeks ago for a status update, they tell me to call that following Monday so they have a couple days to hear from Japan on where it is, because it was already supposed to be here. So I call the following Monday, only for them to tell me it hasn't even f***ing left Japan yet! I mean wtf?! Am I unreasonable?
So now they tell me early April is when I should see it. Good grief....I have bad luck.
Also they tell me I'm the only one who's reported a damaged Blitz exhaust since they started importing....I somehow doubt that.
Old 04-11-2014, 11:49 AM   #24
BaronOBeefdip
Member#: 320335
2005 STi
It's WRB-y
I'll be getting the car out next Thursday, I can't wait!
I still have not gotten my Blitz exhaust from Japan yet, so I'm getting a little upset at how long this has taken. Sent out a couple emails, so now just waiting to hear back. What a pain in the ass this has been...
My basement flooded a few weeks ago so I've been trying to recover everything and get my house back in order. I'm still in that process and luckily none of the parts got ruined, but some original Subaru documentation and booklets that I got from a member over on IWSTI saw water damage....ugh.
Old 04-19-2014, 02:10 PM   #25
BaronOBeefdip
Member#: 320335
2005 STi
It's WRB-y
Finally, she's back! ....with a picture too!
http://i.imgur.com/zjGIK30.jpg
So I went and got the car Thursday. Some preliminary checks, pulled fuse, primed and started right up. Ran it around for a bit to warm 'er up; all seems in order and up to par. There is a tiny leak on the oil drain plug. Fuel seems to have stayed in tact mostly which is good, no shuddering idle or running, but I would still like to burn this tank and get some new fuel in.
Still waiting on my Blitz CBE of course, but once that comes in, I will be ordering a pile of parts and arranging for a couple tunes locally.
