Welcome to the North American Subaru Impreza Owners Club Friday May 14, 2021
Old 04-06-2015, 05:18 PM   #51
25rsti
Member#: 166324
What happened to the STi?
Old 04-06-2015, 07:50 PM   #52
Aczwild
Member#: 71721
98 RSTi, 00 RS
13 Sierra
Originally Posted by remski View Post
Harness bar is the rear bar.
This is FIA certified cage.
I thought the same when I got it...
Looked like some gussets are missing and a vertical door bar is missing.
The guy welding it in (ex-prodrive tech) said that this is how they come.
Welding anything else on top of whats provided could void the certification.
The new 2014 version does have more bars.
Hunh I would have expected to have seen a bar like mine for a shorter run with the harnesses and for the addition of a back brace to the seat if needed, but I can see being able to run the harnesses all the way back (the excess of mine are rolled/bundled)
Aczwild is offline   Reply With Quote
Old 04-06-2015, 09:01 PM   #53
remski
Member#: 151895
I think there might be few benefits having the bar so far..
1. you can move your seat as far back as you want.
2. seatbelts during impact being longer, would stretch and absorb more shock.
Dont know if there are any downsides.
Who did your cage?
Has it been certified/log booked ?
Old 04-14-2015, 03:51 PM   #54
remski
Member#: 151895
Finally some progress...
Right before the operation...
With plasma its a blast.
Measure twice cut once !!!
Weld and cut. Repeat as necessary.
Until it looks like this !!!
Fitment test.
Old 04-15-2015, 01:25 PM   #55
BBY_Hero
Member#: 234236
06 STI
AW
Looks sooooo good should have marked it nsfw lol! Can't wait to see more!
BBY_Hero is offline   Reply With Quote
Old 04-15-2015, 02:25 PM   #56
fan boy
Member#: 241243
Who did your cage?
here is my idea on the topic-
I was told once by an NHRA tech inspector to add stops to my cage to prevent the harness from sliding side to side.. It was NOT required.. BUT, the more i thought about it, he had a point. If your seat ever failed during a roll over, the harness would keep your head inside the side window away from the ground. so I added them on.
BTW----I am talking from experience---a few months later i crashed the car, the seat bracket broke and the harness did exactly what he said it would.
EDIT: the belts were attached to the cage cross bar by the B pillar.
what are you running for a seat?
fan boy is offline   Reply With Quote
Old 04-15-2015, 04:01 PM   #57
remski
Member#: 151895
Yeah...
Harness stops make sense..
I was thinking about that since I had a Sparco harness bar in the STI and it did have a "loop" for that.
As for the seats they are Recaro Profi SPG XL.
Old 04-22-2015, 12:16 PM   #58
remski
Member#: 151895
... and this weekend the other side got some work done...
Plasma makes it so much more fun.
My buddy "the fabricator" in action.
Engine bay getting cleanup plates welded in.
...during lazy times we hire an additional helper...
Old 04-22-2015, 12:48 PM   #59
imxblue
Member#: 147284
2015 STi
I tell ya, if I ever had the skill or $$ to do something like this, I would do it the exact way you are. Well done sir!
imxblue is offline   Reply With Quote
Old 04-22-2015, 12:59 PM   #60
remski
Member#: 151895
I dont really have either.
Just lucky enough to have a friend that did this this kind of work before.
If I only had the $$ for a sequential gearbox....
"Skill is learned, money is earned."
Old 04-22-2015, 02:07 PM   #61
NWRS
Member#: 399624
Incredible build! Nice work documenting everything.
NWRS is offline   Reply With Quote
Old 05-01-2015, 09:34 PM   #62
remski
Member#: 151895
Any day gets better when Motec pr0n arrives !!!
Old 05-02-2015, 03:41 PM   #63
Suburban Ninja
Member#: 420207
So much want!!
Suburban Ninja is offline   Reply With Quote
Old 06-07-2015, 12:06 PM   #64
remski
Member#: 151895
Some progress better than no progress.
(2 weeks ago)
Some plasma action.
... And a test fit.
And finally all my grocery runs can now get log booked.
Old 06-07-2015, 12:06 PM   #65
remski
Member#: 151895
Just another day, or two.
Right side sill support, with jack stand reinforcement.
3 Middle supports.
Rear Jack stand reinforcement.
Finished right side.
Master welder in action.
All pretty and somewhat aligned.
Finally jack stand holes were cut, so the whole side can be test fitted.
Master in action.
"Rear" issues. Flat or curved sill ???
Old 06-07-2015, 12:36 PM   #66
arn4726
Member#: 192574
2015 STi
ISM
this has got to be one of the best build up threads i have ever seen! great work and can't wait to see more progress!
arn4726 is offline   Reply With Quote
Old 06-14-2015, 09:13 PM   #67
remski
Member#: 151895
Open the hood, close the hood, open the hood, close the hood. Repeat as necessary.
Also middle radiator support beam has been removed alongside enlarged intercooler opening.
Time to start looking for a core.
Front headlights are fitted and aligned !!!
Old 06-15-2015, 01:05 PM   #68
llbean
Member#: 419787
2006 Forester LLBean
awesome sauce! big applause
llbean is offline   Reply With Quote
Old 06-15-2015, 01:33 PM   #69
subydude
Member#: 80649
2000 2.5 Auto-X RSTi
Sparkly
Where did the bumper/fenders come from or did you make them?
subydude is offline   Reply With Quote
Old 06-15-2015, 10:51 PM   #70
remski
Member#: 151895
All of the carbon pieces came in one kit. Aerosim
Old 06-15-2015, 11:00 PM   #71
subydude
Member#: 80649
Sparkly
Do you happen to have weight differences between the stock pieces and these?
Old 06-16-2015, 10:03 AM   #72
unoracing
Member#: 359289
2002 WRX STI Prodriv
blue
Subscribed...
unoracing is offline   Reply With Quote
Old 06-16-2015, 10:22 AM   #73
RALLYT-WRX
Member#: 9369
F#ck U & Your Stance
BLOD
Woah***8230;***8230;...
RALLYT-WRX is offline   Reply With Quote
Old 06-16-2015, 01:38 PM   #74
remski
Member#: 151895
Dont know exaclty.. few lb per part I would say.
And the roof... ~40lb if you have a sunroof.
Old 06-16-2015, 02:14 PM   #75
tora
Member#: 5851
17 Ford Escape SE
Blk
Awesome project!
tora is offline   Reply With Quote
