Welcome to the North American Subaru Impreza Owners Club Saturday May 8, 2021
Old 11-10-2020, 06:41 PM   #801
QwaktastiK
Member#: 219100
2014 STI hatchback
Satin White Pearl
QwaktastiK is offline   Reply With Quote
Old 11-10-2020, 07:34 PM   #802
GK1707
Member#: 373868
'04 STi
Originally Posted by QwaktastiK View Post
That is a phenomenal power band!
GK1707 is online now   Reply With Quote
Old 11-10-2020, 11:15 PM   #803
werk
Member#: 382167
2014 wrx hatch
ISM
nice numbers homie! but it'll be a blast when you get it back
werk is offline   Reply With Quote
Old 11-11-2020, 07:07 AM   #804
Karlot
Member#: 339923
2006 Impreza WRX STi
grey
dang that powerband is awesome. what type of boost levels are you running?
Karlot is offline   Reply With Quote
Old 11-11-2020, 08:56 AM   #805
QwaktastiK
Member#: 219100
2014 STI hatchback
Satin White Pearl
Thank you. Very happy with that powerband. Iím a huge believer in cars are so much more than their peak numbers. What the curve looks like is much more impressive to me than big numbers with tons of lag. Canít wait to drive it.
Yeah man. Couldnít be happier. The boost levels are presented at the bottom of the dyno sheet. 23psi for Intelligent mode. 28psi for Sport Sharp. Im assuming R/T felt better about the longevity of the build at a lower boost level than the 30psi a lot of others run this turbo on.
Regarding the power portion of this build...
I still want to thermal ceramic coat the downpipe. Iím sure it will have a minimal effect on spool, but probably a very positive effect of heat soak, both of which will only help in real world driving situations. The thermal ceramic coating will take a minimum of 3 weeks turnaround time with Swain Tech. But Iím in no rush to do that. More eager to get the car back and drive it than anything else at this point.
Vince, the owner and tuner at R/T Tuning pointed out to me that the two other builds I was modeling mine after used Virtual Dynos, not actual dynos when posting their dyno graphs. So I take those with a grain of salt. But my powerband looks very similar to Pet3rís 2015 STI. At this point, Iím not sure if the cams neither hurt nor helped. But perhaps they helped offset the UEL headers a bit.
Old 11-11-2020, 10:40 AM   #806
Karlot
Member#: 339923
grey
well i'm dumb haha. to be fair i didnt have my coffee till later in the morning haha. but yeah that does look to be an incredibly nice powerband. I was pretty set on a garrett turbo but i may have to look into this with that powerband lol.
Old 11-11-2020, 04:21 PM   #807
wuuusaa
Member#: 92894
2015 Wrx
I am! Brakes are next on the list. Once I get my car back. Lol. Prolly going to wait until Black Friday sales to see if thereís any type of discount for what Iím planning to order. After brakes, I plan to do a fair amount of Cusco chassis bracing.
The brake kits I want to order come with calipers, pads, rotors and lines. Iíll just have to see about dust shields. And theyíll be custom order for the specific color combination I want.
Haha smart man with the upcoming black friday sales!
What brand of kit are you going to run?
Old 11-11-2020, 05:16 PM   #808
Dalessio
Member#: 358693
2013 STI Hatchback
Dark Grey Metallic
As everyone has mentioned, that powerband looks great. Driving that is going to be amazing!
Dalessio is offline   Reply With Quote
Old 11-11-2020, 10:09 PM   #809
QwaktastiK
Member#: 219100
2014 STI hatchback
Satin White Pearl
Brembo Gran Turismo
Thank you! Iíll definitely give you guys my first impression once I drive it.
Old 11-11-2020, 10:56 PM   #810
ProdriveWRC
Member#: 20779
2012 STi
WR Blue
[quote=QwaktastiK;46458830]Brembo Gran Turismo
Just a heads up, if you go with the 350x34 front rotors (which you should) you will not be able to run dust shields. I tried fitting APR carbon dust shields, but they will not clear.
ProdriveWRC is offline   Reply With Quote
Old 11-11-2020, 11:00 PM   #811
QwaktastiK
Member#: 219100
2014 STI hatchback
Satin White Pearl
[quote=ProdriveWRC;46458852]
Brembo Gran Turismo
Do the 2018+ STI front dust shields not clear?
Old 11-11-2020, 11:03 PM   #812
ProdriveWRC
Member#: 20779
2012 STi
WR Blue
[quote=QwaktastiK;46458856]
With the 355x32 rotors, yes - 350x34 HD rotors, no. The HD rotors were made specifically for the GR chassis.
Old 11-11-2020, 11:07 PM   #813
ProdriveWRC
Member#: 20779
2012 STi
WR Blue
If you're going with the 4-piston rear, you'll need to cut the backing plates as well.
Old 11-12-2020, 10:09 AM   #814
QwaktastiK
Member#: 219100
2014 STI hatchback
Satin White Pearl
[quote=ProdriveWRC;46458859]
Well thatís a bummer. With the dust shield fitment issue, the rear backing plate issue and the aftermarket tie rod clearance issue, I think Iím gonna lean towards the R205 brakes instead. I know the Brembo GT kit is slightly cheaper and you get more rotor for the money, but if that just causes fitment issues, I think Iíll be better off with the optional OE equipment on this one.
Old 11-12-2020, 12:24 PM   #815
Waddlz
Member#: 395275
2012 STi
Your graphs mimic mine as well.
Waddlz is offline   Reply With Quote
Old 11-13-2020, 09:35 AM   #816
QwaktastiK
Member#: 219100
2014 STI hatchback
Satin White Pearl
Canít see your rpms. Definitely a good looking powerband for sure. Canít wait to drive my car for the first time. Ever consider trying a different dyno thatís more accurate of a 20% drivetrain loss? I know CO is a lot higher elevation than the Philly area.
Old 11-13-2020, 11:43 AM   #817
Chief_WRX
Member#: 369934
2018 STI Limited
Heritage Blue
This looks like the perfect setup. Almost, 80whp difference between [i] and S#, great contrast between the two. I bet this is an absolute blast to drive. I have been putting together my build list over the last few months. The EFR7163 from Full-Race in the stock location with a TMIC is one of the leading candidates. Seeing how your graph looks darn near solidifies that choice.
Chief_WRX is offline   Reply With Quote
Old 11-13-2020, 11:44 AM   #818
Waddlz
Member#: 395275
2012 STi
Can't see your rpms. Definitely a good looking powerband for sure. Can't wait to drive my car for the first time. Ever consider trying a different dyno that's more accurate of a 20% drivetrain loss? I know CO is a lot higher elevation than the Philly area.
yeah I'll have to find a better pic of the graph
but, this is on a dynomite dyno which stock STis will dyno right around 200 whp. I was also having wastegate issues, where I was running out of WGDC. car would spike 29 psi but fall flat to 25ish.
*EDIT* Found a better pic
Old 11-13-2020, 12:53 PM   #819
yamahaSHO
Member#: 73932
2005 STi EFR 6758
04 S2000 EFR 7064
Do you mean uncorrected due to DA loss? This is wheel hp, so drivetrain loss has little use here. Pretty much all dyno's are going to default to corrected numbers, unless you're specifically looking for uncorrected. Additionally, what that dyno cannot account for up at 5,000ft ASL is the turbo running out of steam, compared to the same boost at lower altitudes.
This dyno is one of my favorite, most consistent dynos I've used (on par with DynoJet consistency). What do you think is inaccurate?
yamahaSHO is offline   Reply With Quote
Old 11-13-2020, 04:44 PM   #820
QwaktastiK
Member#: 219100
2014 STI hatchback
Satin White Pearl
The Full Race kit is a great way to go. I know there were some people having issues with the internal wastegate, where they needed to run a dual port wastegate actuator to help hood boost up top. So definitely look into that if you go that route.
Nice! Hell yeah man. Dyno graph great. Did you ever get your wastegate issues ironed out?
Old 11-13-2020, 05:42 PM   #821
yamahaSHO
Member#: 73932
2005 STi EFR 6758
04 S2000 EFR 7064
Yes, he did.
AFTER:
BEFORE: This is from the dyno above.
I had the Full Race kit with an EFR 6758 (it's the 05 STi on their site for the stock location kit) and I had to get a 2-port actuator and run the preload at 7mm. For a single gear pull starting at a lower RPM, it could build enough load to hit target.
On the strip, while shifting gears and not getting the load seen at a lower RPM, I ran out of WGDC and was shy of target boost. I was planning on putting a 4-port in, but sold the car before doing that.
My S2000 (also seen in the background of my picture on Full Race), I have an EFR 7064. I have a 2-port actuator with 7mm preload and I do have a hard time holding boost here at altitude. I picked up a 4-port to install. I only need the ability to hold 12 PSI flat as that's around 450whp. At 10 PSI, you can see the WGDC run up high and I still drop boost. This pull was 400whp with it tapering to 8ish PSI.
Old 11-13-2020, 06:13 PM   #822
QwaktastiK
Member#: 219100
2014 STI hatchback
Satin White Pearl
So doing a bit more research and consideration on brakes...
Initially I was planning on doing the Brembo Gran Turismo 6 piston fronts and 4 piston rears.
The Gran Turismo kit offers more for less when compared to the R205 brakes.
SpeedMasterLee did a great comparison of the GT6 vs the R205 fronts here:
https://forums.nasioc.com/forums/sho....php?t=2821654
But with ProdriveWRC letting me know that the HD kit doesnít work with dust shields, rear backing plates and aftermarket tie rods, Iím leaning away from this kit since my car is a daily driver.
Next up is the R205 kit:
This kit is great for that OEM+ fit and finish. It also utilizes 6 piston front calipers and 4 piston rear calipers like the GT kit. The front rotors drop down from 350mm to 340mm when compared to the GT6 fronts, but allow the use of dust shields. And itís still a big step up from the stock 326mm front rotors. Itís the same calipers that comes on the Type RA, Series Grey and Series White STI (and obviously the same as the 2018+ STIís, only silver instead of yellow.) As stated, it was the stock brakes on the R205 STI, a special edition hatch in 2010 exclusive to Japan.
The rears are a step down as well from 345mm to 326mm when compared to the GT4 rears, but allow the backing plates and no fitment issues with aftermarket tie rods. And itís still a step up from the stock 315mm rear rotors.
This is a great option that comes as a complete kit, but is the most expensive of the bunch.
Last up are the Type RA brakes:
The calipers can be purchased directly from Subaru and the rest of the parts can be purchased separately through any number of aftermarket suppliers that weíre all familiar with. They are the same front calipers and utilize the same rotor size as the R205, but the rears drop to 2 piston rears, but still larger than the 08-14 STI rear calipers. Lancaster did this upgrade on his Ď14 STI GV and is very happy with it.
As I said, Iím definitely leaning away from the Brembo GT kit at this point, but am trying to decide if I should do the Type RA front a rear calipers, or do the Type RA fronts with the R205 rears (4 piston).
Old 11-13-2020, 06:41 PM   #823
werk
Member#: 382167
2014 wrx hatch
ISM
you ever thought about doing the c6 corvette brake swap? they're getting more affordable just like the ctsv calipers
Old 11-14-2020, 10:38 AM   #824
QwaktastiK
Member#: 219100
2014 STI hatchback
Satin White Pearl
Nah. Iím not really a fan of when people put other cars brakes on their car. I prefer the brake kits that are specifically meant to go on a specific chassis.
Old 11-15-2020, 09:13 AM   #825
sayunkl
Member#: 302548
2019 Golf R
2018 High Country
Nice progress as always!
sayunkl is offline   Reply With Quote
