Welcome to the North American Subaru Impreza Owners Club Sunday May 16, 2021
Old 11-03-2019, 09:52 PM   #1
gunshed
Member#: 485056
Default 2004 WRX EVAP Delete Service Manual Question
Hello all,
I am looking to delete my EVAP system entirely (Charcoal canister, all solenoids, lines, etc...)
I am aware that I will receive the following codes:
P0458 - EVAP system canister purge solenoid valve circuit low
P0447 - Evaporative Emission Control System Vent Control Circuit Open
P1400 - Fuel tank pressure control solenoid valve circuit low input
I have an AccessPort, but the a**holes over at Cobb put AccessTuner Race under a paywall, but thats a totally different topic. Anyways, without that I can't easily turn off the codes.
So my solution is to place resistors on all the plugs to "simulate" the missing equipment. Now I need to find proper resistor values to make the ECU happy.
After some googling and digging through my Service Manual, I've come across some miss-matching information:
The manuals over at XXXXX show a very broad 10-100 ohm values for P0458, but an unknown manual another user posted on this thread: https://forums.nasioc.com/forums/sho....php?t=2302198 shows 29-35 ohms. I cannot find this version the manual... It looks like he is using a H4DOTC version, but I checked all the years and cant find the 29-35 ohm spec on the pdf versions I have.
Can anyone help me source the correct manual? I'd like to check the resistance values for the other solenoids. I'd guess a 33 ohm resistor would work fine for the others, but I'd like to make sure.
Any help is appreciated, thanks!
gunshed is offline   Reply With Quote
Old 11-04-2019, 08:11 AM   #2
Unabomber
👏 Big Ron 👏
Member#: 18062
on car parts so PM
me b4 j00 buy
techinfo.subaru.com is your source.
Old 11-08-2019, 03:27 PM   #3
saaiello21
Member#: 501997
gray
Easier method even though you have an Accessport would be to use an opensource tune it will allow you to turn off all your codes.
saaiello21 is offline   Reply With Quote
