Welcome to the North American Subaru Impreza Owners Club Saturday May 8, 2021
Old 03-30-2021, 12:15 PM   #76
MyNameIdeasWereTaken
Member#: 508165
WRX, Porsche 987S
Volvo C30 T5 AWD
Bailey received a little spotlight feature on Import Sauce: https://www.importsauce.com/bailey-h...16-subaru-wrx/
MyNameIdeasWereTaken is offline   Reply With Quote
Old 04-06-2021, 02:48 PM   #77
Member#: 508165
WRX, Porsche 987S
Volvo C30 T5 AWD
My AC is losing refrigerant an a fairly rapid rate... Less than 24 hours to go from fully charged to low enough that the compressor won't kick on.
The compressor is working perfectly when the system is fully charge.
I followed all the lines for any visible problems with no luck.
Dye and a UV light have been ordered and should be here next week.
Aside from checking all the joints, compressor, condenser, etc. are there any known components to be problematic on these cars?
I use the AC all year as a dehumidifier and it wasn't until this past week that I noticed the humid air and lack of cooling.
Old 04-19-2021, 07:55 AM   #78
Member#: 508165
WRX, Porsche 987S
Volvo C30 T5 AWD
Old 04-23-2021, 07:27 AM   #79
Member#: 508165
WRX, Porsche 987S
Volvo C30 T5 AWD
I'm baffled... The car is now holding charge.
Initially, I was using cans of R134a with a gauge set, but on this last top off, I used a quick recharge can from A/C Pro... Which I just realized has "leak protection."
Maybe it was the leak protection, maybe it was my own fiddling around at all the joints and making sure there were secure connections. But the car has been blowing ice cold, even on 1 hour drives.
I'm not entirely convinced my "major leak" hasn't just reduced to a minor leak.
We'll see if that leak seal gums up any other components... At least the AC system isn't too hard to replace.
Time will tell.
Old 04-27-2021, 07:19 AM   #80
Member#: 508165
WRX, Porsche 987S
Volvo C30 T5 AWD
I got the PQY wing stabilizers.
$35 off Amazon, I don't see why you would spend anymore for a piece of plastic to support your wing.
I opted for two, rather than three, and the fitment is nearly perfect. Only minor sanding was required to get them to line up without any gaps.
3M VHB tape is included. It's a tight fit and I had to try and lift the wing upwards when putting these in place; they aren't going anywhere.
The STI wing had a lot of flex at highway speeds, but it remains planted now. You could probably sit on this wing without it collapsing.
Old 04-29-2021, 07:19 AM   #81
Member#: 508165
WRX, Porsche 987S
Volvo C30 T5 AWD
Shifter stop installed. What a difference it made in tightening up the shifter feel!
Amazon link to the shifter stop that I bought: https://amzn.to/3eExMY7
I see no reason why someone should spend more money for this little piece of metal.
Old 04-30-2021, 12:11 AM   #82
D-Rodman
Member#: 110078
02 Bugeye JDM STi
OBP BLACK
Hopefully the frugal parts are durable and wonít have to do it all over again. Nothing wrong with frugal if the quality is there.
D-Rodman is offline   Reply With Quote
Old 04-30-2021, 07:46 AM   #83
Member#: 508165
WRX, Porsche 987S
Volvo C30 T5 AWD
For little things like the shifter stop and the wing supports, it's the same material used by the big-name sellers. In many cases, they're the same parts sourced from overseas and rebranded.
Don't be cheap on suspension and go-fast bits, quality matters there.
But for a tiny CNC'd piece of aluminum, it's all the same.
Old 05-02-2021, 10:56 PM   #84
D-Rodman
Member#: 110078
02 Bugeye JDM STi
OBP BLACK
I prefer the term frugal ;-)
Thatís why I buy Enkei or O.Z wheels and not exotic brands. It is possible to buy good quality at reasonable prices. I do wish I could talk myself into a set of RC-T4
