Welcome to the North American Subaru Impreza Owners Club Tuesday May 18, 2021
Old 02-24-2009, 11:43 AM   #1
antho!
Member#: 159057
2004 ts wagon
aspen white
Default diy! cruise control mod! 07 sti steering wheel into 04 ts!
i posted this in electrical and lighting, but some people might find it useful in doing an steering wheel swap
so i bought an 07 sti steering wheel a while ago and used this thread http://www.scoobymods.com/forums/ins...steering+wheel to use my 04 cruise control (remote on/off button), recently i had an urge to figure out how to get the 07 cruise control (on/off button on arm) to work, so this is my first diy
*cliff notes: splice green-blue from cruise control button to black on 07 cc through black clockspring wire(?) for trigger mechanism, provide power to red on 07 cc, easy?
1. this wiring diagram is a good reference to start from http://i42.photobucket.com/albums/e3...eschematic.jpg
2. for comparison
3. first locate the following
a. cc plug under airbag *note the blank spot - that's how we will trigger the cc
b. clockspring connector(?) *to get to this connector, follow the arrow in the picture above* then cut the black wire to splice with green-blue from the 04 cc button in the next step
4. on the back of the 04 cc button, locate the green-blue, then cut and splice about 12" of wire to connect to the black wire cut in previous step *ignore the other three wires (i terminated them)
5. cut all the wires as close to the 04 cc as possible, use the wires to connect to the 07 cc according to this picture *i used a spade connector on the black so i don't lose the ability to disconnect it
07 cc wiring functions for the curious
- green = 12v
- yellow = set
- white = res
*red and black are for triggering the cc, one is 12v and one connects to the trigger
6. reconnect everything *so the black from the 07 cc is connected to the black going into the clockspring and spliced to the green-blue from the 04 cc button (you can see this in the bottom left below)
antho! is offline   Reply With Quote
Old 02-24-2009, 11:43 AM   #2
antho!
Member#: 159057
2004 ts wagon
aspen white
7. enjoy
hope this helps, good luck
Old 02-24-2009, 12:02 PM   #3
PoorMan'sR
Member#: 202438
2005 WRX
CGM
wow nice write up
PoorMan'sR is offline   Reply With Quote
Old 02-24-2009, 02:11 PM   #4
ilikesubaru
Member#: 160085
2002 Bug Face
Amazing
ilikesubaru is offline   Reply With Quote
Old 11-01-2009, 11:06 PM   #5
crpwrx
Member#: 180710
2006 Sti WRB
WFC# 229
So is this so you can use the 07 cc switch instead of swapping with the original? Or is all the rewiring just to get the the trigger button to work?
crpwrx is offline   Reply With Quote
Old 11-02-2009, 01:13 AM   #6
richy_21
Member#: 58670
2005 got muuuuu?
your the man!
richy_21 is offline   Reply With Quote
Old 11-02-2009, 10:10 AM   #7
Detroit_Blue
Member#: 228318
2004 Impreza WRX
world ralley blue
it looks like this is to get the 07 CC lever to work in an 04.. that looks like an 04 interior to me!
Detroit_Blue is offline   Reply With Quote
Old 11-02-2009, 12:57 PM   #8
antho!
Member#: 159057
2004 ts wagon
aspen white
yes the 07 cc button on the end of the stalk will work if you do this diy
Originally Posted by richy_21 View Post
your the man!
rich, did you get this to work in your car?
yessir
Old 11-02-2009, 03:31 PM   #9
richy_21
Member#: 58670
2005 got muuuuu?
Not yet tomorrow maybe tonight for sure!!!
Old 11-07-2009, 12:29 PM   #10
arco
Member#: 57156
2007 V.8 207 STi
Mercedes Polar White
thanks
arco is offline   Reply With Quote
Old 11-07-2009, 12:53 PM   #11
richy_21
Member#: 58670
2005 got muuuuu?
Some issues. My clockspring wire is all white. But you mentioned its white red? Also where did you put the power wire threw?
Old 11-07-2009, 01:17 PM   #12
antho!
Member#: 159057
2004 ts wagon
aspen white
umm, on the clockspring wire there are 4 wires - you are only concerned about the black one. the white red is on the cruise control side. i tapped power from the green-black. hope this helps bro. good luck
Old 11-07-2009, 02:51 PM   #13
richy_21
Member#: 58670
2005 got muuuuu?
2nd to last picture on your 1st post is what im talking about. Also where did you slip the black where threw?
Old 11-08-2009, 12:55 AM   #14
antho!
Member#: 159057
2004 ts wagon
aspen white
ok so in the 2nd to last pic on my 1st post, there's two sets of wires - one is the wires on the top part of the pic (going into the sleeve) are the 04 cc wires with connector; the other is the wires on the bottom of the pic are from the actual 07 cc.
then in the next pic, the "black to black" - one is the black wire from the actual 07 cc (from the previous pic); the other is the black wire from the clockspring connector (going into the yellow sleeve).
i hope this clears it up. i'm in iraq right now, but if i was back in socal, i'd help you out for sure. maybe you can take a picture and post it, i can help you out better. good luck
Old 01-14-2010, 04:30 PM   #15
Unrealgtx
Member#: 178853
2001 2.5RS
RBP
sorry to bump such an old thread but i just did this mod right now and it is awsome!
did this in my other car (02 wrx) took me about 20 minutes to do!!
this should definatly be moved to the "diy compilation!"
Unrealgtx is offline   Reply With Quote
Old 01-15-2010, 01:38 AM   #16
crpwrx
Member#: 180710
2006 Sti WRB
WFC# 229
I second that^^^ Im about to do this.
Old 01-15-2010, 01:50 AM   #17
Ysidro
Member#: 197418
07 WRX Ltd
The Mighty Evo;Fun CRZ
hhmm. Maybe I'll do an sti steering wheel swap.
Ysidro is offline   Reply With Quote
Old 01-15-2010, 12:17 PM   #18
antho!
Member#: 159057
2004 ts wagon
aspen white
do it! let me know if you guys have any questions : )
Old 01-24-2010, 07:10 PM   #19
25rsti
Member#: 166324
does anyone have problems with the airbag working?
25rsti is offline   Reply With Quote
Old 01-24-2010, 07:43 PM   #20
Unrealgtx
Member#: 178853
2001 2.5RS
RBP
nope! never had any problems with airbag
Old 03-01-2010, 12:12 AM   #21
Rez1138
Member#: 211569
03 WRX Wagon VF36
WRB Blobeye conversion
Big props to antho! for this diy!!
I just did the swap in my 03 today and this thread got me through the wiring w/o a problem. The hardest part for me was getting under the dash to do the blue-green to black wire connection...kind of a pita for a bigger guy like myself but being a contortionist for a little while is a small price to pay for the new functioning sti wheel with the proper cc...love it lol!!
Rez1138 is offline   Reply With Quote
Old 03-01-2010, 03:09 AM   #22
I <3 PiNkY
Member#: 211924
2004 wrx
wr blue
Thumbs up
wow bro great diy
I <3 PiNkY is offline   Reply With Quote
Old 03-01-2010, 03:03 PM   #23
crpwrx
Member#: 180710
2006 Sti WRB
WFC# 229
One question, where did you run the black wire throug the column to the 04 cc switch?
Old 03-01-2010, 04:35 PM   #24
antho!
Member#: 159057
2004 ts wagon
aspen white
you're welcome. good to know that this is helpful
the black cable is existing on the white connector (see step 3.a.), so i cut it and connected it to the 07 cc stalk. the other end comes out under the dash (see step 3.b.), so i splice wire from the 04 cc button to that wire (see step 4). make sense?
Old 03-02-2010, 01:20 AM   #25
crpwrx
Member#: 180710
2006 Sti WRB
WFC# 229
So you dont run that wire right? It already exists down there?
How to install 04 STi steering wheel on 04 WRX (w/ cruise control) WRXakaBooSTi Interior & Exterior Modification 5 07-28-2020 03:42 PM
putting an 08+ STI steering wheel into an 07 WRX? NMZ_WRX Interior & Exterior Modification 1 05-19-2010 07:57 AM
STi Steering Wheel Into 04 WRX WRBLueGD2 Subaru Conversions 11 03-27-2010 01:45 PM
diy! cruise control mod! 07 sti into 04 ts! antho! Electrical & Lighting 0 02-24-2009 12:48 AM
Swapping v9 STi steering wheel into 04 WRX BIGSKYWRX Interior & Exterior Modification 30 10-29-2006 10:29 AM
