Welcome to the North American Subaru Impreza Owners Club Sunday May 9, 2021
Old 01-03-2021, 09:27 AM   #1
KAZMIK
Member#: 521394
2004 WRX
World Rally Blue
Default Pulling my first engine
I'm pretty savvy when it comes to cars one thing i have not done is pull an engine. I have to replace the head gasket. I have done a lot of research but I'm still a little nervous. any tips or tricks?
KAZMIK is offline   Reply With Quote
Old 01-03-2021, 10:51 AM   #2
snow_bound26
Member#: 395793
2005 92x Aero
Beige
Take your time, go slow and triple check everything. For me I start by disconnecting the battery, then draining oil and coolant. Then remove the TMIC. From there I start removing/unplugging things on the driver side rear of the engine and work clockwise to the passenger side rear of the engine. Then go counter clockwise back to make sure everything is disconnected. Then move under the car. Then remove the radiator. Remove pitch stop. Tie engine to firewall with the upper pitch stop bracket. And finally remove starter and trans bolts.
Good luck and have fun with it. Once you've done it you'll see that these cars are pretty straight forward to pull an engine.
snow_bound26 is offline   Reply With Quote
Old 01-03-2021, 04:19 PM   #3
KAZMIK
Member#: 521394
2004 WRX
World Rally Blue
Thanks I appreciate the encouraging words.
Old 01-03-2021, 04:54 PM   #4
Fndragn
Member#: 470845
2011 Sti
Take pictures, label as much as you can with painters tape or something similar. Put bolts back where they came from if possible during tear down, label and bag everything that can't be placed back. Label and take more pictures than you think you need. An extra 30 minutes on the front end will be invaluable on the tail end.
Fndragn is offline   Reply With Quote
Old 01-03-2021, 11:19 PM   #5
TwistedAxles101
Member#: 379235
2002 Impreza WRX
Blaze Yellow
If you are pulling the engine from a 02-05 WRX or any STi, you need to disconnect the clutch fork. Once you remove your starter there will be a hex plug behind it, remove it. Take a long bolt from your plastic timing cover and thread it into the pin inside the hole you removed the hex plug from. Pull on the bolt until you pull the pivot pin out completely. This is a 100% necessary step.
Another necessary thing- you must use something (jackstand or jack depending on weather you have a lift or not) on the transmission to lift the engine mounts out of the subframe.
TwistedAxles101 is offline   Reply With Quote
Old 01-04-2021, 09:10 AM   #6
rtv900
Member#: 428511
2016 STI
^right here
baggies and a sharpie
I even use egg cartons for certain items that need to go back exactly where they came from like lifters or rockers or something.
You always think at the time you'll remember and then 15 sets of fasteners later you completely forget where the first 5 sets went.
Old 01-04-2021, 09:57 AM   #7
NewSilverWRX
Member#: 58485
2004 RASC.207 WRX 5M
Find the factory service manual. Deviate from the process when it doesn't make sense. Keep power steering and ac intact. Get a quality putty knife you can hammer on to separate engine and trans. Make sure you have exhaust gaskets for wherever you break it apart. A way to control tilt on the hoist is helpful on the way out and invaluable on the way back in. Use tin foil to fashion a channel to keep the coolant off everything when draining.
NewSilverWRX is offline   Reply With Quote
Old 01-04-2021, 02:53 PM   #8
Markopolo400
Member#: 452996
Follow the correct procedure for tightening the head bolts, it's very specific and detailed.
Markopolo400 is offline   Reply With Quote
Old 01-10-2021, 08:54 PM   #9
Spendawg
Member#: 519924
Pictures are key and put nuts and bolts in labeled bags. Makes putting everything back together much easier
Spendawg is offline   Reply With Quote
Old 01-19-2021, 04:20 PM   #10
1970something
Member#: 374771
Subaru Only channel on Youtube has a playlist for his 1998 Impreza with EJ205. There are a bunch of videos in the middle of the playlist where he goes through each step of removing the engine. They are VERY detailed and thorough so will hopefully help:
https://youtube.com/playlist?list=PL...sOJlyLJ4mz7kzW
1970something is offline   Reply With Quote
