Welcome to the North American Subaru Impreza Owners Club Sunday May 9, 2021
Old 04-04-2021, 05:32 PM   #1
TxFxL
Member#: 212702
2018 Impreza Premium
Grey
Default Looking to Upgrade MFD on Impreza Premium
I did my best to search to make sure this hadnt been covered and couldnt find a direct answer, I saw a lot of info about swapping the 18 MFD into older models but not between the same model year. If I just buy a new MFD and try it but theyre pretty steep $
My question is if I buy the limited trim level MFD and install it in my premium level Impreza will I gain all the functionality?
It looks like both MFDs have the same 24 pin connector, Im hoping it would be a direct swap and it would be plug and play for functionality.
Im looking to gain the maintenance screens as well as the other functions of the MFD. Eventually Id like to upgrade to the automatic climate control as well which I think would be adding the limited level climate control panel and possibly the interior temperature sensor, I have the little spot for it in the dash but not sure if the sensor is behind it, if anyone had that info as well that would be great
Thanks in advance
TxFxL is offline   Reply With Quote
Old 04-04-2021, 05:50 PM   #2
TxFxL
Member#: 212702
Grey
So slight update.
You can feel behind where the interior temperature sensor is.
I could feel behind the dash on my wifes 19 forester limited and she has a sensor there, I felt behind the dash on my 18 premium Impreza and there is no sensor there so Id most likely need that for the auto climate upgrade
