Welcome to the North American Subaru Impreza Owners Club Thursday May 6, 2021
Old 06-18-2005, 03:43 PM   #1
ka mano
Member#: 78022
PdxT built 2.5L 6sp
30R.82, 274/276, H2O+meth
Default 245 or 235 tires on your wagon? (wagon-wheel fitment)
There's a lot of conjecture, expert speculation, noobgurgitation and a few good reports about whether or not the fatter meat will fit on a WRX wagon at all, especially if its lowered.
Been following that great thread started by omahasubaru in 2003 on lowered wagons with 225 rubber. Now here's a place for us wagon drivers to report on our 235's and 245's.
Searching and deciding and finally shopping, I really appreciated posts that had all of the information below. Wanna lend a hand to your wagon brothas and sistas? Put it all down.
wagon MY:
rim size:
rim offset:
rim brand & model:
tire brand & model:
tire size:
tread (actual patch) width:
camber adjustments:
suspension:
lowered?:
fender rolling?:
rubbing w/o load?:
rubbing w/ load?:
(handling /gearing):
ka mano is offline   Reply With Quote
Old 06-18-2005, 03:52 PM   #2
ka mano
Member#: 78022
PdxT built 2.5L 6sp
Default my set up
wagon MY: 2005
rim size: 17 x 7.5
rim offset: +50
rim brand & model: SSR Competition
tire brand & model: Michelin PS2
tire size: 235/40-17
tread (actual patch) width: 8.5"
camber adjustments: none
suspension: Perrin rear sway bar and end links / Espilir springs / (Cusco CF rear strut tower brace)
lowered?: 1"
fender rolling?: no
rubbing w/o load?: no
rubbing w/ load?: don't know, will report... I don't even like extra keys or spare maps. No problem fully fueled!!
(handling /gearing): noticed a slight gearing advantage in the low end with the shorter-diameter wheel (rim + tire). Handling? I jumped from 205's to 235's, so with the narrower profile and the fatter tread, I'm drivin' a new car! And the Michelins are great on wet and dry.
It'd be great to hear from BIGSKYWRX, abaxter34, OedipusWRX, BlkWRXWag, and RogersWRX.
Old 06-20-2005, 12:02 AM   #3
aakrusen
Member#: 77308
'02 WRX
wagon MY: Sorry, Sedan 02 (but this might help)
rim size: 17x8
rim offset: 48
rim brand & model: 5Zigen FN01R-C
tire brand & model: Falken Ziex ZE-512
tire size: 235/45/17
section width: Um....235
camber adjustments: 0 Camber front and rear (+/- .25)
suspension: Yes, but I think every car has suspension
lowered?: Yes, Prodrive springs
fender rolling?: No
rubbing w/o load?: No
rubbing w/ load?: Only at 60+ mph around oval track
(handling /gearing): Crappy, these tires suck because they are all-season. If you autocross then don't buy these tires, they are not sticky enough. Gearing is a little taller due to my choice in tire size.
aakrusen is offline   Reply With Quote
Old 06-22-2005, 07:25 PM   #4
dbrier
Member#: 6598
2017 Golf R
Limestone Grey
Originally Posted by mrn98
wagon MY: 2004
rim size: 17x8
rim offset: +45mm Offset
rim brand & model: Volk F-zero Tropy Collection
tire brand & model: Falken Azenis ST115's
tire size: 235/40/17
section width:
suspension: RSB
lowered?: 1"front/rear jdm wagon springs
fender rolling?: No
rubbing w/o load?: None
rubbing w/ load?: Not yet with me and 2 others
Didnt notice any acceleration increase, but who knows. I would highly recomend These tires to anyone with a wagon, great dry grip and much better performance vs stock. Low on road noise (but I do have straightpipe so cant hear much over exhaust).
I can't believe this doesn't rub. +45 offset and 235?
dbrier is offline   Reply With Quote
Old 06-22-2005, 09:50 PM   #5
remowgn
Member#: 41149
09 FXT
SSM
Just cuz I'm crazy I'm gonna be trying 245/40's on my wagon. I'll report back here once I do. I don't think that they'll fit, but since I haven't seen anybody step up to the plate on this one yet I figure I'll give it a shot.
remowgn is offline   Reply With Quote
Old 06-22-2005, 10:12 PM   #6
remowgn
Member#: 41149
09 FXT
SSM
Most likely the Kumho MX, as people have had decent luck putting them on 7.5" wheels and they're cheap. (Yeah, I know it's outside the wheel specs... but after reading up on it a bunch it's doable.)
Old 06-23-2005, 08:40 AM   #7
aakrusen
Member#: 77308
'02 WRX
I would have done 245/40 on my car if I had the money. The money was the only reason why I ended up putting 235/45 on my car. I think you'll be fine.
Old 06-23-2005, 09:00 AM   #8
dbrier
Member#: 6598
2017 Golf R
Limestone Grey
mrn98, I believe you.
I wonder if the there is better clearance in the 04+? I have ridden in 02-03 wagons with 225s on 48 offset and heard it rub.
I want to try some 235s on stock STi wheels on my car. Maybe after some more post and my 070s wear out.
Old 06-23-2005, 11:59 AM   #9
BlkWRXWag
Member#: 31821
2015 DS WRX
wagon MY: 03
rim size: 17x8.5
rim offset: 48
rim brand & model: Rota Slipstream
tire brand & model: Kuhmo MX
tire size: 245/40/17
section width: 245
camber adjustments: -3.0 F, -2.5 R
suspension: Koni Inserts, GC Coilovers with 400lb spring F & R
lowered?: Yes,
fender rolling?: Yes
(handling /gearing): Handling - great for street. Good for autoX. Gearing a little bit shorter than stock.
BlkWRXWag is offline   Reply With Quote
Old 06-27-2005, 09:06 PM   #10
salaki
Member#: 10572
92-X N62B44, ST 1050
ka mano,
Thanks for starting out this thread.
We, Wagon Owners need this!
MY: MY05 Saabaru 92X Aero.
(I hope you all don't discriminate me )
rim size: 17 X 8
rim offset: +48
rim brand & model: Enkei RP03.
tire brand & model: Falken ST115
section width: 245
camber adjustments: -1.2 R -1.2 F (Street car)
suspension: USDM STi Pink Wagon w/ Stock Struts
lowered?: Yes.
fender rolling?: YES. See my location.
rubbing w/o load?: Not all
rubbing w/ load?:
I'm now rubbing FREE!
Handling /gearin : My sister's car - conservative tire savings setup for street and spirited drives. (well I use it sometime too )
salaki is offline   Reply With Quote
Old 06-28-2005, 12:29 AM   #11
ka mano
Member#: 78022
PdxT built 2.5L 6sp
Sounds cool, Salaki. It's great to have buddies to loan you stuff for fitment decisions. Let us know!
Old 06-28-2005, 06:08 PM   #12
ka mano
Member#: 78022
PdxT built 2.5L 6sp
In my original posting I meant to put 'tread width' instead of 'section width'... just edited in the change. Manufacturers are moving away from publishing tread width 'cause it'll vary with actual inflation pressure and load.
It'd be great if wagoneer posters could take a tape measure to the 235 or 245 you've mounted on your ride and inflated to your normal setup -- and let us know your actual-patch tread width along with the other stuff.
When we're pushing fitment to its limits, we gotta look at shoulder shape. I don't know any way to report that objectively other than to compare section width to actual-patch tread width.
235mm = 9.25 inches
245mm = 9.65 inches
The 235/40-17 PS2s I'm no-rub runnin on 7.5" rims at slightly above stock inflation are coverin a 8.5" patch of tarmac... not too round but less aggressive than some rubber I've seen.
Old 06-29-2005, 04:31 PM   #13
eqlized_aero
Member#: 88699
2015 TS EFR7163 818S
V9 Spec C Type RA 92x
Would a 235 or 245 tire mounted to an 18 inch wheel have more consistent tread width because of the lower profile sidewall or is it still going to vary significantly by manufacturer?
The reason I ask is because I want to put 18's on my Saabaru and wouldn't mind a more significant footprint than 225.
Salaki - it would be interesting to see if your friend's 235's and 245's fit your saabaru before using your fender rolling kit.
eqlized_aero is offline   Reply With Quote
Old 06-29-2005, 04:46 PM   #14
BlkWRXWag
Member#: 31821
2015 DS WRX
You will have a much better selection of tires with a 17" wheel than the 18". Take the word of a man who bought 18's and sold them for 17's... me!
Old 06-29-2005, 05:56 PM   #15
salaki
Member#: 10572
Taking delivery of the car next Tues after long weekend
Soon after that, I will actively work on the Saabaru and will post everything up..
I have 245/40/18 w/ 18X8.5+48 on my STi (tall tires-wrong size but okay for daily drive). I can try to test fit these bad boys onto the Wagon if you want to see but I probably will experience major rubbing that probably can't even fixed w/ fender roller but I'm curiosu and let's see..
Old 07-08-2005, 12:21 AM   #16
Jasper
Member#: 80136
2006 Ford F-150
Originally Posted by BlkWRXWag
wagon MY: 03
rim size: 17x8.5
rim offset: 48
section width: 245
lowered?: Yes,
i'd be interested to see if these rubbed without so much negative camber
say, -1F / -1.5R ?
Jasper is offline   Reply With Quote
Old 07-08-2005, 01:01 AM   #17
BlkWRXWag
Member#: 31821
2015 DS WRX
say, -1F / -1.5R ?
I have had -1.5 on the rear and they fit fine. There is more clearance at the front, so I imagine you would be ok. In fact, without camber plates or adjustable lateral links, -1.5 is all you can run on the rear. If you try camber bolts, any extra camber will cause the tire to hit the strut.
Old 07-08-2005, 01:19 AM   #18
Jasper
Member#: 80136
2006 Ford F-150
im @ -1.7 & -2.1 in the rears (dropped on Tein S-Tech's)
~-.5 up front, i'll be fixing that this sunday though.
Old 07-20-2005, 01:28 PM   #19
El Supremo
Member#: 38388
Howdy,
wagon MY: 2002 WRX Wagon: Stage 4 +
rim size: 17x7.5
rim offset: 50
rim brand & model: SSR competitions-silver (12.8 lbs)
tire brand & model: Pirelli Nero Zero M&S
tire size: 225/45-17
tread (actual patch) width: 8.9"
camber adjustments: stock
suspension: Whiteline F&R swap bars, end links, F&R strut bars, alk, steering bushing
lowered?: No
fender rolling?: Yes (just last month-ready for a width increase)
(handling /gearing): After 55K struts/springs giving me a floaty/un-tight feeling in the mountain twisties, time for strut/spring upgrade and alignment.
ka mano,
How do 235/40-17's feel on a 17x7.5 wheel? Much sidewall flex that you know of? Any problems in general?
Thanks,
Supremo
El Supremo is offline   Reply With Quote
Old 07-20-2005, 04:55 PM   #20
ka mano
Member#: 78022
PdxT built 2.5L 6sp
Default Howdy? I haven't heard that since my tender years in Oklahoma. Same to ya!
I've had zero problems, the sidewalls feel stiff and I love taking sharp curves without breaking traction.
It doesn't give the appearance of the tire being jammed in there, either.
Check out http://forums.nasioc.com/forums/showthread.php?t=343100.
twotacosfor99cents has a nice photo in post #7.
Originally Posted by El Supremo
...225... ready for a width increase...
Hope you re-post after you widen your ride rubber!
Old 10-10-2005, 09:57 PM   #21
humara
Member#: 53289
04 wrx waggin'
wrb
Default 235/45/17 +48
wagon MY: 2k4 wagon
rim size: 17x7.5
rim offset: 48
rim brand & model: rota downshift
tire brand & model: toyo proxes t1r
tire size: 235/45-17
camber adjustments: -1.5 rear. -1.25 front. max negative camber with stock setup
suspension: stock
lowered?: No
fender rolling?: no
(handling /gearing): i don't see how a differnce of 3% in rolling circumference can make a difference that people would notice in the car for acceleration. handling is slightly better with the wider shoes. definately transfers more bumps into the cabin.
humara is offline   Reply With Quote
Old 10-11-2005, 10:35 AM   #22
salaki
Member#: 10572
Just updated my post above as promised.
17 X 8 +48 - 245/40/17 fits fine...
Also another crazy attempt I did:
245/40/18 on 18 X 8.5 +48 - temporary fitment last time.
Mid Major rubbing in the rear (not to fender lip) but to the rear bumper.
If I really leave it on as it rubs then I'm sure it will make little by little cuts on the rear bumper and at the end, the tires will cut it like "professional".
Old 10-11-2005, 01:03 PM   #23
ka mano
Member#: 78022
PdxT built 2.5L 6sp
Originally Posted by humara
rim size: 17x7.5
Thanks for postin, humara.
More pics: http://www.rollyourfender.com/projects.html
Congrats on your wide patch. Looks like you and BlkWRXWag are the only posters so far with 245s. Your 'Saabaru' and STi are lookin fine! Are the 911 and the other cars yours, too?
Old 10-11-2005, 03:44 PM   #24
salaki
Member#: 10572
Mine are the STi and the Saabaru.
The others are my buddies' cars that I sometime help them to work on few things..
Old 10-12-2005, 09:19 PM   #25
BIGSKYWRX
Member#: 7958
09 GH B+
I'll list mine even though they read "225"- they are the oe S2000 rear fitment Bridgestone S02's- they are pretty wide for a 225. The section width is 9.2, the tread width 8.5, for comparison the following 235/45/17's list RE050's 9.2/8.5, Goodyear GS DS 9.3/7.9, PS2's 9.3 (no tread width listed. They are closer to 235 than 225.
wagon MY: 04
rim size: 16X7.5
rim offset: 46
rim brand & model: Volk TE37
tire brand & model: Bridgestone S02
tire size: "225/50/16"
camber adjustments: front -2.2, rear -1.5
suspension: STi pink wagon/v8 wagon inverted struts
lowered?: ~ 15mm
fender rolling?: yes- thanks to salaki for the roller
(handling /gearing- gearing is oe, handling is wonderful- very sticky street tire, very stiff sidewalls
I think I still have some room to "play" , I'm going w/ 16X8 rims and R compounds next season- I think I'm going to try Victoracers in 245/45/16- then again I may play it safe and stick w/ 225's- the Victoracers are also on the wide side of 225- the additional 1/2" of rim should net me an additional ~ .2" of tire width
245 or wider tires on the rear? (WRX) j y Brakes, Steering & Suspension 8 07-05-2011 02:32 PM
245/40r17 or 235/45r17 on 17x8? toebotypera Tire & Wheel 7 06-08-2007 12:14 PM
245/50/16 or 245/45/16 tires on 16*7 rims?? coolray Tire & Wheel 0 09-28-2005 01:17 PM
Prodrive PFF7 and 235 tire on a wagon?? Alan l. Tire & Wheel 5 07-09-2005 12:36 AM
245 or 235s for my 18x8.5s tifosi77 Brakes, Steering & Suspension 3 12-02-2002 12:58 AM
