Welcome to the North American Subaru Impreza Owners Club Wednesday May 12, 2021
Old 10-13-2005, 08:42 PM   #26
burnside
Member#: 43404
2002 WRX Wagon
Excellent idea! Bump for the wagon thread
Also, what do you guys think about 245/40 vs. 235/40 (Falken FK451) for my application:
-02 wagon
-Prodrive springs
-rolled fenders
-17x7.5 ET48 wheels
-98% street driven
-0 toe F/R, ~ -1.3 F/R camber with driver in car
I am most concerned with the amount of sidewall "slop"/overhang and if this would adversely affect handling or steering response. I'd like to go 245/40 because it would be closer to stock rolling diameter and because salaki did it .
Also, here's the general specs for the tires in question:
Specification Sidewall Radius Diameter Circumference Revs/Mile Difference
205/55-16 4.4in 12.4in 24.9in 78.2in 811 0.0%
225/45-17 4.0in 12.5in 25.0in 78.5in 808 0.4%
215/45-17 3.8in 12.3in 24.6in 77.3in 819 -1.0%
235/40-17 3.7in 12.2in 24.4in 76.7in 827 -1.9%
235/45-17 4.2in 12.7in 25.3in 79.6in 796 1.8%
245/40-17 3.9in 12.4in 24.7in 77.6in 816 -0.6%
(courtesy of http://www.miata.net/garage/tirecalc.html)
burnside is offline   Reply With Quote
Old 10-14-2005, 12:50 AM   #27
ka mano
Member#: 78022
PdxT built 2.5L 6sp
30R.82, 274/276, H2O+meth
Default Your patch is as wide as mine.
Originally Posted by BIGSKYWRX
I'll list mine even though they read "225"... they are pretty wide for a 225.
Welcome to the thread, BIGSKYWRX, and thanks for the info. It's good to know you're not rubbin! Keep us posted on how you set up your Rs and how they work out!
ka mano is offline   Reply With Quote
Old 10-14-2005, 02:30 AM   #28
ka mano
Member#: 78022
PdxT built 2.5L 6sp
Default got a question? tell us your goals...
Originally Posted by burnside
...what do you guys think about 245/40 vs. 235/40 (Falken FK451) for my application... 17x7.5 ET48 wheels... 98% street driven... .
BlkWRXWag, are you trackin this thread? Your buddy tried the 245 on a 7.5 with no reported problems as of last April. Is he still rollin them OK?
For what it's worth, 2ndGearFling has 'seen it done.' It'd be great, though, if someone actually runnin this setup could report in.
Welcome, burnside! I can see from your wheel diameter lookup how the 235/40 and 235/45 have almost the same variance from stock... and both numbers are really small. I'd forgotten their absolute values were so close to each other but remembered from my own decision-makin in June that they were both under two. Their respective variances from stock are 1.2 and 1.3% greater than the 245/40. That's nothin. Lookin at the .9 inch difference in the diameter of the 235/40 and 235/45 wheels (rims + tires), I prob'ly hallucinated the gearing advantage I reported in my 2nd posting. Still, if you do go 235, you're better off with the 40 IMO to minimize fitment concerns.
So what else are you lookin for? Looks? Handling? Speed? Maybe just maxin out those possibilities and seein how far you can go? It's all cool with me.
If you want handling, you won't really need the 10 mm you're considerin unless you're takin a hard turn at speed. I've experimented with just that on my 17x7.5 235s and I've been able to break traction in a decreasing-radius turn at ~80. It was fun, but then I wasn't havin to worry about my rubber spillin out of its rims.
Somebody with 17x8 245s might have held the line, don't know. Don't know if 17x7.5 245s would pop their beads in a hard turn at 80, either. Some 245s are wider than others... maybe they'd all spill, maybe none. Only one way to find out, but then again I wouldn't have wanted that on my mind while handlin those turns at 80... or 60 for that matter.
If you want speed you gotta think about rotational mass and traction at launch. A 245 is bound to be heavier than a 235 with the same profile. That's askin your horses to pull more ounces each revolution, ounces located at the worst possible place, farthest from the hub. You'll drop some acceleration and top speed.
Don't know what's under your hood, but don't worry about breakin launch traction with 235s, unless you're somewhere north of 297 ft lbs at the wheels.
If you're goin for looks / takin it to the max, and you don't turn like a crazy ka mano, than I'd get the 245s and go for it. While you're shoppin, think about buyin some 8s or 8.5s and some peace of mind.
Old 10-14-2005, 03:50 AM   #29
MBREX02
Member#: 82733
2004 WRX STi
Originally Posted by aakrusen
wagon MY: Sorry, Sedan 02 (but this might help)
rim size: 17x8
rim offset: 48
rim brand & model: 5Zigen FN01R-C
tire brand & model: Falken Ziex ZE-512
tire size: 235/45/17
section width: Um....235
camber adjustments: 0 Camber front and rear (+/- .25)
suspension: Yes, but I think every car has suspension
lowered?: Yes, Prodrive springs
fender rolling?: No
rubbing w/o load?: No
rubbing w/ load?: Only at 60+ mph around oval track
(handling /gearing): Crappy, these tires suck because they are all-season. If you autocross then don't buy these tires, they are not sticky enough. Gearing is a little taller due to my choice in tire size.
Wait a minute! I have the same wheels with 225/45/17s and my tire rubbed. I had to roll my fenders and my car is only lowered by an inch! How do you not experience rubbing?
MBREX02 is offline   Reply With Quote
Old 10-14-2005, 09:19 AM   #30
BIGSKYWRX
Member#: 7958
09 GH B+
He says his did rub around a track. I think w/o a load (weight) or high speed turning- you can fit very wide tires- but who wants to go in a straight line all the time
Old 10-14-2005, 10:25 AM   #31
salaki
Member#: 10572
92-X N62B44, ST 1050
I'm assuming you have a Wagon.
aakrusen has a Sedan and Sedan's rear fender can accomodate wider tires probably up to 235 depending on tires and wheel width and offset too w/o fender rolling
If you have a Sedan and it rubs w/ that setup w/ 225 then it's weird
Back to Wagon topic..
Anyone fits 255/35/18 X 18.5
salaki is offline   Reply With Quote
Old 10-14-2005, 05:49 PM   #32
burnside
Member#: 43404
2002 WRX Wagon
Thank you all (especially salaki for the helpful PM)!
I think I am going to stick between 225/45 or 235/40 (Falken FK451) because I know I will not have rubbing issues under big loads/cornering and because the tire will better fit the 17x7.5 with less sidewall bulge and peripheral rotational mass.
Anyone know of any issues of rims bending because of the shorter sidewall on the 235/40? (I will be doing 98% street).
soh-fast EDIT: I will go with 235/40 just so I can post back in this thread
Old 10-17-2005, 12:58 PM   #33
burnside
Member#: 43404
2002 WRX Wagon
Another thing I've been thinking about:
When we use any tire that is not exactly stock diameter, what happens when we need to use the spare tire? Will the differentials be okay with running 3 tires of one diameter and one of a different diameter?
Old 10-24-2005, 12:54 AM   #34
MK19_
Member#: 49148
Dogs are forever in
the pushup position...
wagon MY: 02
rim size: 17*7.5
rim offset: 52
rim brand & model: Prodrive P7
tire brand & model: Hankook K104's
tire size: 225/45-17
tread (actual patch) width: dunno
camber adjustments: -1 degree
suspension: STi wagon struts- Prodrive P1 springs
lowered?: yep- bout 1.3-1.5"
fender rolling?: nope
rubbing w/o load?: nope
rubbing w/ load?: nope
(handling /gearing): Handles great, gearing is gpood too, but I am also running a 4.444 tranny; so it is really hard to say for sure. I just got STi V7 golds and I am thinking highly about squeezing in some 245's... that is risky tho, so we'll see.
MK19_ is offline   Reply With Quote
Old 11-07-2005, 02:33 PM   #35
rdy4flt
Member#: 86882
2005 92x Aero-stg2
Arctic Silver
Wagon MY: 2005 Saabaru 92x Aero
Rim size: 17x7.5
Rim offset: 53
Rim brand & model: BBS (What 04' Sti came with)
Tire brand & model: BFGoodrich Geforce KDW-2
Tire size: 225/45/17
Tread (actual patch) width: don't know...but section width is 8.9"
Camber adjustments: stock
Suspension: Stock, except for Perrin rear Swaybar.
Fender rolling?: nope
Rubbing w/o load?: nope
Rubbing w/ load?: nope
(handling /gearing): Handling is great. Awesome traction some. No rubbing what so ever, we will see what happens after spring upgrade.
Rudi
rdy4flt is offline   Reply With Quote
Old 12-19-2005, 03:06 PM   #36
BIGSKYWRX
Member#: 7958
09 GH B+
It's getting close to crunch time for me to order tires (they will be victoracers that much I know).
Play it safe 225/50/16 section width 9.2", tread width 8.6"- this is mesure on a 7" rim- I will be on a 8" rim. This I know will work as the specs are nearly identical to the S02's I'm running now (apparantly Victos run a little wide as well).
Or 245/45/16 section width 9.7", tread width 9.1"- this is measure on a 8" rim which I will be running.
The 245's have one other advantage besides more tread- they are also .3" shorter than the 225's- this would be beneficial from a "gearing" prospective.
To summarize my setup I'm on STI wagon springs (mild lowering ~ 10-15mm), spring rates are 223/192, camber is -2.0ish front, -1.5ish rear, rear fenders are rolled.
Decisions, decisions
Old 12-19-2005, 04:34 PM   #37
El Supremo
Member#: 38388
Tough decision, I'm just sad nobody makes a 245/40-16. I believe someone use to, but no more. 1.2 smaller dia, -4.7 gearing advantage, mercy.
Anyway,I'd go with the 245's. I've had em' on my 2002 wrx wagon before with no rubbing. Of course I've had my fenders rolled for over a year now.
El Supremo is offline   Reply With Quote
Old 12-19-2005, 04:38 PM   #38
salaki
Member#: 10572
You know how I would answer it
245/45/16...
Watch out for the front inside fender rubing w/ thicker tires.
My 245/40/18 on the MY04 STi rubs in the inner front fender.
Seems like I can cure it w/ 255/35/18 - lower profile tire.
Old 12-19-2005, 08:10 PM   #39
BIGSKYWRX
Member#: 7958
09 GH B+
That's two 's on my left shoulder
none of these
Old 12-19-2005, 11:50 PM   #40
ka mano
Member#: 78022
PdxT built 2.5L 6sp
Default if there's no 235s available to split the difference...I
Old 12-20-2005, 09:38 AM   #41
BIGSKYWRX
Member#: 7958
09 GH B+
I guess I knew what the consensus was going to be
Old 12-20-2005, 10:11 AM   #42
ka mano
Member#: 78022
PdxT built 2.5L 6sp
Cool Blind but happy
It's easier to shave rubber off than to glue it on, no?
What harm could there be in a little rubbin?
Old 12-20-2005, 10:43 AM   #43
Migo
Member#: 81352
2003 '03 EJ257 wagon
Green
wagon MY: 2003
rim size: 18x7.5
rim offset: +53
rim brand & model: Prodrive P1
tire brand & model: BFG Scorchers
tire size: 225/40ZR18
suspension: stock
lowered?: no
fender rolling?: no
rubbing w/ load?: yes
(handling /gearing): stock
It rubs the front INNER FENDER under moderate speed full-lock u-turns. Think I can alleviate this problem by getting 2-3mm wheel spacers and rolled outer fenders? I'm getting performance springs/struts soon and that will lower me an additional 1.2" in the front, so I'm going to have to think of something.
Help...? I think it all has to do with the rims' +53 offset. Maybe a 48-50 offset would have been better.
Migo is offline   Reply With Quote
Old 12-20-2005, 11:49 AM   #44
BIGSKYWRX
Member#: 7958
09 GH B+
Yeah ^ one of the exceptioons of a higher offset being the best- inboard rubbing.
I'm currently running 46 et (Volk TE's) and inboard rubbng hasn't been an issue.
omahasubaru pm'd me w/ a good idea that I need to think over- that's run a 245/45 up front w/ a 225/50 in the rear- increased grip up front. There are a lot of time attack folks running a staggered setup like this w/ pretty good luck.
A couple of things I need to consider is there is a small height difference between the 225/50 and 245/45 ~ .3" - it might actually be a smidge less as that is measurements on a 7" rim for the 225 and 8" rim on the 245- both of these would be on a 8" rim.
The other thing I've considered is the same tire front & rear- w/ 8" rims up front and 7.5" in the rear.
It's never easy
Old 12-20-2005, 01:35 PM   #45
El Supremo
Member#: 38388
Just noticed in my Les Schwab (West Coast) Monthly Tire flyer Newpaper that Les now carries 225/40ZR-16's and 245/35ZR-16's in the Toyo Proxes T1-R. Scary
Contact the store nearest you
www.LesSchwab.com
Supremo
Old 12-20-2005, 05:10 PM   #46
WgnWheel
Member#: 63605
04 Wrx Wgn TimeAtk
10 Golf TDI, 08 Stang GT
Bigsky, im currently thinking of doing the same thing on my wagon for track wheels......8's up front, 7.5 out back. this has been done for years in japan. let us know what you decide.
WgnWheel is offline   Reply With Quote
Old 12-23-2005, 05:28 PM   #47
ka mano
Member#: 78022
PdxT built 2.5L 6sp
Default Shopping tip...
Consider bigger tires for Christmas!
Old 01-04-2006, 11:58 PM   #48
mcdrama
Member#: 85083
2015 WRX Premium
World Rally Blue Pearl
wagon MY: 2004
rim size: 17
rim offset: 48
rim brand & model: Rota Sub Zero
PIRELLIS
tire brand & model: Pirelli PZero Nero M+S
tire size: 215/45/17
tread (actual patch) width: ???
camber adjustments: -1.6 rear -0.9 front
suspension: Stock
lowered?: half the life span of the tire
fender rolling?: no
rubbing w/ load?: yes on rear, removed rubber/steal cable liner and no more rubbing.
FALKENS
tire brand & model: Falken ST-115
tire size: 225/45/17
camber adjustments: -1 rear -1 front
suspension: Stock
lowered?: half the life span of the tires
fender rolling?: no
rubbing w/ load?: yes on rear, but only when the tire pressure is low and I am pushing it hard.
mcdrama is offline   Reply With Quote
Old 01-15-2006, 09:02 PM   #49
elsanto
Member#: 34832
1989 M3
Picking up a set of stock evo tires (235 45 17 yoko A046's) for my summer tires.. fingers crossed they won't rub on my 7.5" te37's with prodrive springs and kyb struts..........
might just roll the fender for good measure though once it gets warmer that is.
elsanto is offline   Reply With Quote
Old 01-15-2006, 09:22 PM   #50
BIGSKYWRX
Member#: 7958
09 GH B+
good choice of tires- they get pretty rave reviews
245 or wider tires on the rear? (WRX) j y Brakes, Steering & Suspension 8 07-05-2011 02:32 PM
245/40r17 or 235/45r17 on 17x8? toebotypera Tire & Wheel 7 06-08-2007 12:14 PM
245/50/16 or 245/45/16 tires on 16*7 rims?? coolray Tire & Wheel 0 09-28-2005 01:17 PM
Prodrive PFF7 and 235 tire on a wagon?? Alan l. Tire & Wheel 5 07-09-2005 12:36 AM
245 or 235s for my 18x8.5s tifosi77 Brakes, Steering & Suspension 3 12-02-2002 12:58 AM
