Welcome to the North American Subaru Impreza Owners Club Wednesday May 12, 2021
Old 01-15-2006, 09:42 PM   #51
ka mano
Member#: 78022
PdxT built 2.5L 6sp
30R.82, 274/276, H2O+meth
Originally Posted by elsanto
Picking up a set of stock evo tires (235 45 17 yoko A046's) for my summer tires.. fingers crossed they won't rub on my 7.5" te37's with prodrive springs and kyb struts..........
might just roll the fender for good measure though once it gets warmer that is.
Hey... good luck with that. What model year do you have and do you know the offset of your te37's?
ka mano is offline   Reply With Quote
Old 01-15-2006, 11:29 PM   #52
elsanto
Member#: 34832
1989 M3
its an 02 bugeye baby blue wagon.. et 48 I beleive, and its too cold to go outside and check thanks bigsky, I just hope they dont rub too bad, but could be a good excuse for coilovers
elsanto is offline   Reply With Quote
Old 03-01-2006, 11:09 AM   #53
g35sedamn
Member#: 87515
03 aspen wrx wagon
wagon MY:2003
rim size:17x7.5
rim offset:+48
rim brand & model:enkei rp02
tire brand & model:hankook rs2
tire size: 235/40r17
tread (actual patch) width:will get back to you on that
camber adjustments: approx. 1.5 front and back
suspension: megan racing coilovers
lowered?:13.4" front 13.2" rear hub to fender
fender rolling?: no
rubbing w/o load?: not yet
rubbing w/ load?: not yet
(handling /gearing):sticks better gearing the same... side by side the tires are identical in height. on paper they are .4" shorter.
g35sedamn is offline   Reply With Quote
Old 03-01-2006, 01:02 PM   #54
KSwrxWAGON
Member#: 56639
'03 WRX Wagon
wagon MY:2003
rim size:17x8.0
rim offset:+48
rim brand & model:Rota Torque
tire brand & model:Falken FK451
tire size: 245/35/17
tread (actual patch) width:haven't measured
camber adjustments: -2.3 front and -1.5 rear
suspension: Stock with '04 STi springs. 25 mm swaybars f/r
lowered?:a bit from the springs
fender rolling?: yes
(handling /gearing):Gearing is great for autocross. However, I wouldn't want to drive on these every day since they'll rack up mileage on the car pretty quick! A decent tire, but not as good as the old Azenis.
KSwrxWAGON is offline   Reply With Quote
Old 03-18-2006, 08:21 PM   #55
burnside
Member#: 43404
2002 WRX Wagon
EDIT: ooops, misread the 245/35/17...thought it said 235/45.
burnside is offline   Reply With Quote
Old 03-18-2006, 08:58 PM   #56
El Supremo
Member#: 38388
With an inch less sidewall on the 245/35-17's than stock you'll really feel the bumps and pot holes. I don't think I'd use those tires as a daily driver either. I'm old.
El Supremo is offline   Reply With Quote
Old 04-06-2006, 07:17 PM   #57
moxie
Member#: 89432
2015 Forester XT
This is a friends car.
wagon MY:2003
rim size:17x8.5
rim offset:+48
rim brand & model:GN+ maybe
tire brand & model:Falken RT-615
tire size: 255/40/17
tread (actual patch) width:???
camber adjustments: ~-1* front and -1.5 rear
suspension: Stock
lowered?: Nope
fender rolling?: No
(handling /gearing): Not my car so I can't say... Thats a big effin tire though
I am too wimpy and only run 225/45 on 17x7.5s
No rubbing with the rolled fenders though.
moxie is offline   Reply With Quote
Old 04-06-2006, 07:36 PM   #58
fireantresq
Member#: 107702
04 wrx wagon
wrb
wagon MY:2004
rim size:17x?
rim offset: ?
rim brand & model:MB Motorsport weapon
tire brand & model:yokohama es100
tire size: 225/45/zr17
camber adjustments: stock
suspension: stock...to be tein ss-p next week
lowered?: i said next week...sheesh
fender rolling?: nope
rubbing w/o load?: hope not
rubbing w/ load?: same
(handling /gearing): they definitely stick better...road noise is borderline unbearable...starting to get weird wear pattern along corner of tire where tread meets sidewall.
fireantresq is offline   Reply With Quote
Old 04-07-2006, 12:03 AM   #59
salaki
Member#: 10572
92-X N62B44, ST 1050
wagon MY:2003
rim size:17x8.5
rim offset:+48
suspension: Stock
lowered?: Nope
fender rolling?: No
Wowww.... he doesn't rub w/ full load on 255/40/17 on 17 X 8.5 +48..
You sure you looked at the right size?
The most agressive wagon I've seen is 245/40/17 on 17 X 8.5 +48 tires and he had coil overs and MAD camber and coilover setup plus his fender is definately extremely rolled to compensate the width of the wheel.
I am so positive that it will rub on Wagon w/ full full load when you go into a deep dip.
Got pics...? I'm interested to see
salaki is offline   Reply With Quote
Old 04-07-2006, 09:57 AM   #60
BIGSKYWRX
Member#: 7958
09 GH B+
key words "not yet"
Old 04-07-2006, 09:59 AM   #61
elsanto
Member#: 34832
1989 M3
you know what they say "rubbin is racing" but seriously there was an evo last weeks auto-x running 285 V710's... so jealous.
Old 04-11-2006, 11:53 AM   #62
elsanto
Member#: 34832
1989 M3
wagon MY: 2002
rim size: 17x7.5
rim offset: 48
rim brand & model: Volk TE37
tire brand & model: Yokohoma Advan a046
tire size: 235 45 17
tread (actual patch) width: hmmm
camber adjustments: -1.8 front -1.6 rear but sliipped while racing to +.2 front
suspension: kyb agx prodrive springs
lowered?:
fender rolling?: in rear
rubbing w/ load?: not while auto-x with no spare.. i dont usually carry bricks around in my wagon.
(handling /gearing): handled really nice before the suspension slipped. tires grip very well, and track very nicely... dont run dual camber bolts, they will slip
Old 04-11-2006, 01:43 PM   #63
ka mano
Member#: 78022
PdxT built 2.5L 6sp
Thanks for the post-up, elsanto... your handling info is esp. interesting.
...there was an evo [at] last weeks auto-x running 285 V710's... so jealous.
Fat is phat with tires, for sure. For me, the question is whether or not my torque would spin the wheels with a narrower footprint. If the answer is no, then I've sacrificed go for show by carrying useless rotational mass.
Old 04-11-2006, 01:53 PM   #64
elsanto
Member#: 34832
1989 M3
with the 2.5 id say bigger is better.. i was spinning the 225's around with little effort. might be my driving style, but im stubborn.
Old 04-13-2006, 12:57 AM   #65
99subi
Member#: 78118
2002 Corvette coupe
05 Legacy
ok anyone think this will rub
17x8
offset 48
225/45/17
lowers on s techs and kybs gr2 struts anyone think i will have a problem????
99subi is offline   Reply With Quote
Old 04-13-2006, 02:59 AM   #66
jdadour
Member#: 64028
2014 WRX Limited
wagon MY: 2003
rim size: 17x8.5
rim offset: 45
rim brand & model: Gramlight 57f Bronze
tire brand & model: Hankook Ventus RS2 Z212
tire size: 235/40/17
camber adjustments: F-1.6 R-.7
suspension: AGX front, STi rear struts
lowered?: Prodrive STi Springs
rubbing w/o load?: not even close
rubbing w/ load?: i had 5 people in my car and one guy said he heard a scratching noise coming from the rear when we were turning in a parking lot. i pretty much do what i can to not have anyone in the back seat at all.
jdadour is offline   Reply With Quote
Old 04-13-2006, 03:17 AM   #67
ka mano
Member#: 78022
PdxT built 2.5L 6sp
That's for the report, jdadour.
Originally Posted by jdadour
.... i pretty much do what i can to not have anyone in the back seat at all.
...or you could just take it out! (I did .)
Old 04-13-2006, 09:01 AM   #68
elsanto
Member#: 34832
1989 M3
99 subi you'll be fine. just do it!
Old 04-13-2006, 10:29 AM   #69
BlkWRXWag
Member#: 31821
2015 DS WRX
17x8
offset 48
225/45/17
Depending on the type of tire, that may well rub. It did on my wagon (with stiffer springs than those S-Tech POS).
BlkWRXWag is offline   Reply With Quote
Old 04-14-2006, 12:49 PM   #70
secu256
Member#: 59262
2002 WRX wagon
sliver
wagon MY: 2002
rim size: 17x8
rim offset: 48
rim brand & model: 5Zigen Fn01r-c
camber adjustments: F-1.5 R-1
suspension: Tein Flex F10K, R8K
lowered?: yes 13.75" from wheel center to fender
rubbing w/o load?: nope
rubbing w/ load?: nope, haven't autocrossed or tracked these tires/wheels yet, but I'm not expecting any rubbing. I'll edit if it happens
secu256 is offline   Reply With Quote
Old 04-14-2006, 01:03 PM   #71
ka mano
Member#: 78022
PdxT built 2.5L 6sp
Default You're ready for lookin' & bookin'!
Thanks, secu256. Those are sweet rims (I like 'em) and some mean rubber.
(Do Hankook Ventus RS2's come in a K212 or did you mean Z212? Thanks.)
Old 04-14-2006, 02:08 PM   #72
secu256
Member#: 59262
2002 WRX wagon
sliver
Doh, yeah they're the z212's. I just copied jdadours post for all the info that was asked for and didn't notice the error.
Old 04-14-2006, 02:26 PM   #73
ka mano
Member#: 78022
PdxT built 2.5L 6sp
s'cool. I hadn't noticed it there either.
Old 04-20-2006, 06:15 PM   #74
isis
Member#: 73283
05 OBXT & CTS-V
03 Z1000
2005 Saabaru
7.5x17 rota grids w/ 48 offset
235/45-17's (forget what brand, i'll check later)
Tein H-tech lowering springs/stock struts
no fender rolling (yet)
rubs like hell with or without load.
<--renting fender roller and having 1/2" spacers made for strut tops. (adds negative camber and ride height.)
isis is offline   Reply With Quote
Old 04-20-2006, 11:37 PM   #75
ripvw
Member#: 27790
Upgraded from 17x7.5 ET48 Rota Attacks to 17x7.5 ET53 OEM '04 STI BBS wheels
upgraded from 225/45x17 Falken FK451's to 225/45x17 OEM STI Bridgestone RE070's.
If you've ever seen the RE070's, you know how wide they run - they dwarf the FK451's - more like a 235/45x17 and hence the post. no rubbing thanks to the ET53 BBS offset and the mild rear drop of the Prodrives
wagon: '02 WRX
17x7.5
ET53
BBS oem '04 STI
Bridgestone RE070
static "patch" width damn close to 9" @ 36psi
F-2.0/R -1.5
Prodrive/Koni/Noltec
yes - about 1.25" F/.5" R
no fender rolling
no rubbing with/without load (drove 300 miles today with about 250 lbs. of stuff in the back)
and oh yeah - I love the combo!
ripvw is offline   Reply With Quote
245 or wider tires on the rear? (WRX) j y Brakes, Steering & Suspension 8 07-05-2011 02:32 PM
245/40r17 or 235/45r17 on 17x8? toebotypera Tire & Wheel 7 06-08-2007 12:14 PM
245/50/16 or 245/45/16 tires on 16*7 rims?? coolray Tire & Wheel 0 09-28-2005 01:17 PM
Prodrive PFF7 and 235 tire on a wagon?? Alan l. Tire & Wheel 5 07-09-2005 12:36 AM
245 or 235s for my 18x8.5s tifosi77 Brakes, Steering & Suspension 3 12-02-2002 12:58 AM
