Welcome to the North American Subaru Impreza Owners Club Tuesday October 4, 2022
Old 09-19-2021, 09:37 PM   #476
user1029
Member#: 57064
2008 STi IAG built
HTA86 E85 Kel272s Cos IM
Originally Posted by Ironnez View Post
Pros vs cons of Reverse set up? im already close to 20k into my subie and im a lil reluctant to spend more money is it worth?
In retrospect itís more headache than itís worth unless if youíre willing to sacrifice AC lol you have much better manifold options not to mention bigger throttle body fitment with a standard set up
user1029 is offline   Reply With Quote
Old 10-01-2021, 07:26 AM   #477
SoCoNoHa
Member#: 478524
1995 EZ30 Coupe
Green
I'd say it looks cool as hell and opens up a LOT of space in the rear of the bay for relocated reservoirs, etc. The space thing is the big one from my perspective.
There's possibly a small improvement in throttle response and/or spool time, but I wouldn't count on anything significant. I would expect barely noticeable gains performance wise, but I could be way off, and as Homemade WRX said it depends on the previous setup as well. A well designed standard rotation setup will outperform a crappy rotated setup.
SoCoNoHa is offline   Reply With Quote
Old 05-26-2022, 01:39 PM   #478
user1029
Member#: 57064
2008 STi IAG built
I got a problem with the car breaking up above 30psi it drives smoothly out of boost and below 30psi. The NGK 2309 spark plugs/ OEM coil packs are all new and gapped appropriately to 0.024Ē. Battery 2 years old. The -10AN fragola fuel filter is new, ID2000cc injectors are new and refreshed, Walbro fuel pumps are all new, air fuel and fuel pressure are all good, no knock. I think the spark is getting too weak for high boost pressures. I may need to change out my 14 year old alternator and get a grounding kit. I will also change out my 14 year old crank sensor
Old 05-26-2022, 02:42 PM   #479
user1029
Member#: 57064
2008 STi IAG built
How the car currently sits. At least Subaru parts are cheap in my effort to keep my aging car alive (175,000 miles). It costs $4000 to replace AC on an R8 for instance
Old 05-26-2022, 05:35 PM   #480
no694terry
Member#: 220816
2018 Exotruck
EJ22e 415whp/398wtq
probably the fuel, I hear they're get that overseas watered down gas these days
no694terry is offline   Reply With Quote
Old 05-26-2022, 05:51 PM   #481
user1029
Member#: 57064
2008 STi IAG built
Iím running E85, made in the cornfields of Ďmerica
Old 05-26-2022, 06:45 PM   #482
no694terry
Member#: 220816
2018 Exotruck
EJ22e 415whp/398wtq
Nice, thought you were still doing the meth
Old 05-26-2022, 07:12 PM   #483
user1029
Member#: 57064
2008 STi IAG built
After I lost my upper row of teeth, I decided to stop
Old 06-12-2022, 01:57 PM   #484
TDagen
Member#: 163648
V9 6mt R180 Brembos
That sounds like spark blow out. I had that issue with the hta86 running the older wrx black coil packs. Diagnosed it by installing a friends sti grey coil packs and the issue went away.
The grey coils were spendy and the time so I kept my blacks and installed a ken bell boost a spark and tightened my spark plug gap down to 0.022 or 0.021 (canít recall it was back in 2010). Never had another problem.
Did the alternator fix the issue?
Old 06-12-2022, 01:59 PM   #485
K3rm1tth3fr0g
Member#: 508105
Link flex tuned 02
WRX EJ205 20G-XTR JDM 6MT
R35 GT-R coil conversion time
K3rm1tth3fr0g is offline   Reply With Quote
Old 06-22-2022, 10:37 PM   #486
user1029
Member#: 57064
2008 STi IAG built
Nope alternator, new coil packs, grounding kit did not fixed the hesitation issue
Turns out it is likely due to cracks in my 14 year old IAG rotated kit uppipe
it will be replaced
Old 06-23-2022, 08:20 PM   #487
K3rm1tth3fr0g
Member#: 508105
Link flex tuned 02
Hooray for figuring out what it is - Boooo for an up-pipe leak.
Make sure to get some ceramic coating or a blanket on that new MF
Old 06-24-2022, 11:00 AM   #488
umscooby
Member#: 50902
98 GM6
60mm WB
In retrospect it's more headache than it's worth unless if you're willing to sacrifice AC lol you have much better manifold options not to mention bigger throttle body fitment with a standard set up
Can be reversed without sacrificing AC. The better mani's are available in reverse layout, with any throttle body size you want. Unless over 600-650whp stock throttle body size is fine anyway, coming from both my tuner and engine builder.
Shorter and cleaner piping runs > stock config.
Anything can be done, just depends on how much work you want to do.
umscooby is offline   Reply With Quote
Old 07-19-2022, 02:21 PM   #489
user1029
Member#: 57064
2008 STi IAG built
new uppipe reinforced to hell and back
Old 08-01-2022, 07:37 PM   #490
user1029
Member#: 57064
2008 STi IAG built
Car is all fixed! Turns out all my boost issues/stuttering are due to my 14 old Grimmspeed EBCS! Car is back hitting 40psi smoothly
Old 08-02-2022, 12:11 PM   #491
Black90tsiawd
Member#: 524857
Only 40 psi?!?!
We need you to turn it up to 50 and report back ASAP. You know, for science or something.
Black90tsiawd is offline   Reply With Quote
Old 08-03-2022, 12:43 AM   #492
user1029
Member#: 57064
2008 STi IAG built
Originally Posted by Black90tsiawd View Post
Only 40 psi?!?!
My car is geriatric after all these years it struggled to hit 40psi these past months nor could it hold an erection
Old 08-03-2022, 06:51 AM   #493
Black90tsiawd
Member#: 524857
Nasioc needs a thread about a 1000 whp daily driver.
Old 08-03-2022, 12:30 PM   #494
BlueSTI4Me
Member#: 34361
04.7 STI
WRB IG @got2boostit2
Yes it does and this OP would be a great information source.
BlueSTI4Me is offline   Reply With Quote
Old 08-04-2022, 05:12 PM   #495
umscooby
Member#: 50902
98 GM6
60mm WB
...and the OP needs an AMS rotated uppipe/downpipe kit.
Old 08-04-2022, 10:28 PM   #496
user1029
Member#: 57064
2008 STi IAG built
Maybe Iíll go for 1000whp once I hit 250,000 miles
