Welcome to the North American Subaru Impreza Owners Club Thursday September 29, 2022
Old 08-05-2022, 02:45 PM   #1
Pawnstar
Member#: 413312
Default 19-20 Sti engine into 15-18 Sti shell
Our 2015 sti just spun a rod and we found replacement engine for a fair price. I know it's a direct swap but will there be any check engine lights? I understand the 19-20 has different pistons and are tuned differently. Would the compression causing any issues for the ecu ? I don't want to rebuild I just want to swap and go.
Pawnstar is offline   Reply With Quote
Old 08-05-2022, 03:02 PM   #2
rtv900
Member#: 428511
2016 STI
The ECU has no idea what compression a motor has.
It looks for detonation
rtv900 is offline   Reply With Quote
Old 08-05-2022, 03:03 PM   #3
rtv900
Member#: 428511
2016 STI
Old 08-05-2022, 03:54 PM   #4
Pawnstar
Member#: 413312
Should I should be good to go? The rebuild I was quoted is almost the same price as the engine replacement with 7k miles.
Old 08-08-2022, 06:46 PM   #5
ProjectXT
Member#: 483233
It will work fine
Sent from my iPhone using NASIOC
ProjectXT is offline   Reply With Quote
Old 08-12-2022, 10:16 AM   #6
alexu27
Member#: 531040
You'll be fine, i did the same swap in my 2006 outback xt.
alexu27 is offline   Reply With Quote
Copyright ©2000 - 2022, Jelsoft Enterprises Ltd.
Powered by Searchlight © 2022 Axivo Inc.
