Welcome to the North American Subaru Impreza Owners Club Tuesday September 27, 2022
Old 07-28-2022, 01:46 AM   #1
trashboy
Member#: 446533
2020 sti
cwp
Default absolutely horrid mpg after going stage 1 (pro tune)
is it normal to have absolutely terrible gas mileage after tuning (2020 sti)?
for context, when i was stock, i was getting around 20-24 (mix of city/highway) without caring about conserving gas.
i went stage1+ with a cobb sf intake and the ots tune, and again, without caring about my gas mileage would get about 20-24 (mix of city/highway). so it didn't really affect my mpg as far as i could tell.
yesterday, i got protuned and noticed my mpg was super low. so i did a test. i drove 20 miles (1 of which was city). never shifted past 3k rpm, never went past 70 on the freeway, and got 12 mpg. am i wrong in thinking this is insanely low, or is this just one of the things that comes with tuning the car.
trashboy is offline   Reply With Quote
Old 07-28-2022, 02:16 AM   #2
D-Rodman
Member#: 110078
02 Bugeye JDM STi
OBP BLACK
That does not sound right.
Sent from my iPhone using NASIOC
Old 07-28-2022, 08:00 AM   #3
whozatguy
Member#: 179775
03 WRX/15 FXT
14 BRZ/ 92 SVX
Did you add any new parts when you got the pro-tune, or was it just a custom tune for the intake and everything else remained the same?
Is the tuner someone who is experienced with Subarus? It sounds like something isn't right, a good tune shouldn't drop mpg like that.
whozatguy is offline   Reply With Quote
Old 07-28-2022, 08:17 AM   #4
undyjr
Member#: 459692
2019 WRX STI
silica black
That's the mileage I get on E85.
undyjr is offline   Reply With Quote
Old 07-28-2022, 08:33 AM   #5
Max Capacity
Member#: 149347
05 LGT ,09 SpecB
Black/silver
My car gained mpg with cobb AP and custom tune. Been that way since I installed Cobb AP V1 back in Dec 2004. Highway miles at 70mph or a little slower will get 26mpg +.
Max Capacity is offline   Reply With Quote
Old 07-28-2022, 01:45 PM   #6
trashboy
Member#: 446533
2020 sti
cwp
he tuner got back to me and said "the car calculates the mpg by using the maf calibration table amongst other things to come up w a number. compare with what it thinks you will get per tank and calculate your actual mpg when you fill your fuel tank at the station. also look at your af correction and make sure it isnt trying to add a bunch of fuel unnecessarily"
so i think it may be a misrepresentation of my actual numbers rhat iím seeing. i filled up my tank, am going to run it about half, and divide the amount of miles driven by the number of gallons on my next fill up to get my true mpg. i will say that it (the reported mpg) doesnít seem to be accurate. iíve driven a good amount since the tune and didnít think it was draining any faster than stock. will report back on my next fillup.
Old 07-28-2022, 01:48 PM   #7
trashboy
Member#: 446533
2020 sti
cwp
no i didnít add any additional parts. the only thing itís tuned for is the intake. the tuner is a reputable subaru tuner and has an 02 wagon if his own. he was showing me different cars heís tuned and when he was scrolling through his customer list, i saw lots and lots of subarus.
Old 07-28-2022, 06:01 PM   #8
a5m
Member#: 519868
2010 Impreza WRX
I always calculate by hand. Possible the ECU calculation is just wrong.
a5m is offline   Reply With Quote
Old 07-28-2022, 06:46 PM   #9
K3rm1tth3fr0g
Member#: 508105
Link flex tuned 02
WRX EJ205 20G-XTR JDM 6MT
Your ECU MPG calculation isn't going to be correct unless your tuner adjusted the scaling of the multiplier
K3rm1tth3fr0g is offline   Reply With Quote
Old 07-28-2022, 06:48 PM   #10
djoye
Member#: 50072
2017 STI
I think it takes an extra commitment by the tuner to get the electronics to accurately report fuel mileage after a tune. I'm guessing Cobb's shelf maps are all set because I used their map and don't remember the MPG estimate being wrong before I got a custom tune, after my custom tune it wasn't accurate (bigger injectors apparently affect it). I later went back for another tune and asked the tuner if he could tweak the fuel mileage display settings, it got better, but it's not perfect.
https://cobbtuning.atlassian.net/wik...lay+Correction
From the linked page:
To adjust values based on manual fuel mileage calculations, apply the following formula: "(FMD Mileage Value / Actual Fuel Mileage Value) * Current Table Correction Value".
I'm guessing that if you calculate your mileage manually, then provide that number and the number displayed on your fuel mileage display at time of calculation, your tuner can then multiply that value by the correction value that's currently set and improve the accuracy.
djoye is offline   Reply With Quote
Old 07-28-2022, 11:53 PM   #11
K3rm1tth3fr0g
Member#: 508105
Link flex tuned 02
This ^
Old 07-29-2022, 05:25 AM   #12
trashboy
Member#: 446533
2020 sti
cwp
as an update, talked to my tuner. he checked the map and noticed "some things changed with the fuel economy display that shouldnt have been changed". sent me a new map, i retested using the exact same methodology and got 27 mpg. so all is good.
thanks everyone
Old 08-12-2022, 10:18 AM   #13
alexu27
Member#: 531040
My car gets an average of 12.9 mpg with a protune as well. My tuner says its normal but I'm not sure if I trust him 100%
alexu27 is offline   Reply With Quote
Copyright ©2000 - 2022, Jelsoft Enterprises Ltd.
Powered by Searchlight © 2022 Axivo Inc.
