10-12-2003, 03:31 AM | #1 |
Member#: 9749
SWIC
Vehicle:- |
Okthe misfire codes wont stop..
I keep getting a misfire in 1 and 3 every 3-5 days.. It is a solid cel.. What the hell is causing this? The car is running decent.. Could it be a bad coil pak? Please any help would be great i am tired of resetting my ecu..
Dave
10-12-2003, 03:57 AM | #2 |
Member#: 7138
Im having the same problem - normally under partial throttle but on boost. Takes about 3 restarts of the car and the cel goes away. Sound familiar? I was thinking about switching to cold plugs - anyone have a solution?
- chris |
10-12-2003, 04:41 AM | #3 |
Member#: 10334
Vehicle:91 RX7 LSx swap '09 CC 3.6 4motion |
Do a compression check. Lower compression will cause the codes. But it may not be low enough to where you can feel a difference.
Hopefully it is not the cause Also our coil packs have been known to go out. |
10-12-2003, 09:59 AM | #4 |
Member#: 16697
South East
Vehicle:2004 2.5 Hybrid 18g Wagon + LGT 1-4 g00dness! |
Pull your dipstick tube and feel for blowby and smoke...
I'm dealing with this right now.. |
10-12-2003, 11:56 AM | #5 |
Top Scoob 002
Member#: 32771
BAIC
Vehicle:03 Black WRX 04 White M3 |
What engine management do you have? If it's utec then....
10-12-2003, 01:46 PM | #6 |
Member#: 9749
SWIC
Vehicle:- |
Nope i have ecutek, and the cel's are solid not flashing.. I did a comp test and all 4 were low, but the car still runs fairly good so i began to think i might need a better guage.. THe spark plugs looked good when i pulled them during the com test.. I dont know what is causing this.. The car has 50k+ miles but was always taken care of and i would say compared to a lot of other people i absolutley baby the car..
Dave |
10-12-2003, 07:58 PM | #7 |
Member#: 9749
SWIC
Vehicle:- |
any one?
10-12-2003, 10:11 PM | #8 |
Member#: 18251
TXIC
Vehicle:1996 Skyline GT-R Midnight Purple II |
My cel is on all the time. I just ignore it now. THe car runs great all the time. Some people say it is because of the Unorthodox Racing underdrive pully, others say it is because of the ClutchMasters aluminum flywheel. Either way, always the same thing..Misfires 1,2,3,&4. Factory ECU with a Apex-i AVC-R set at 17 PSI running 93 oct. all the time (except track events then its 101). Anybody have any ideas????SOA??? anybody?
10-12-2003, 10:40 PM | #9 |
Member#: 21497
i get 1-4 constantly. i have just learned to not pay attention anymore. i too have been told it may have something to do with the lightened flywheel. i know it happens alot on the dsm's as well. if the car checks out and runs good, forget about it.
10-13-2003, 08:52 AM | #10 | |
Member#: 9749
SWIC
Vehicle:- |
The thing is i dont have a lightened flywheel. I am going to do another comp test soon and see.. I am just wondering if it is something stupid i am just missing.. Dave |
10-13-2003, 09:00 AM | #11 |
Member#: 4811
NESIC
Vehicle:2014 Focus ST NESIC track Ho #35 |
I think I was getting those codes too- when they sent in my ecu for re-programming/reflash
may want to ask the dealer- see if they can tell you which codes would constantly get thrown speed safely Brian |
10-13-2003, 11:41 AM | #12 |
Member#: 15533
Vehicle:2010 Dodge Ram Hemi boat, dirt bikes, bobcat |
*raises hand*
I get constant 1-4's also.... It stopped for a week after I changed my plugs but now I get #1 missfires sometimes.. Car runs great, I do have a Vishnu UD pulley though |
10-13-2003, 12:00 PM | #13 |
Member#: 16350
Vehicle:2018 M3 1971 521 2018 GLA45 AMG |
Do you have a grounding kit?
10-13-2003, 12:14 PM | #14 |
Member#: 8343
Vehicle:2005 2012 Jeep 2013 DGM BRZ |
I got misfire cel's with the vishnu pulley installed.
10-13-2003, 01:14 PM | #15 |
Member#: 9749
SWIC
Vehicle:- |
I have no pulley or grounding kit.. Anything else i am missing?
10-13-2003, 02:13 PM | #16 | |
Member#: 16350
10-13-2003, 03:06 PM | #17 |
Member#: 11571
RMIC
I have had a constant CEL for 1 & 3 misfire. Had the plugs changed today but I'm expecting it to come back. Have had a reflash and that didn't help. Next step is gonna switch the coil packs to the other side. If 2 & 4 show up, that's the culprit. If not, I'm thinking an air/fuel sensor may be bad.
10-13-2003, 03:25 PM | #18 | |
Member#: 9749
SWIC
Vehicle:- |
Thanks |
10-13-2003, 03:41 PM | #19 |
Member#: 18251
TXIC
I have the HKS grounding kit as well as a new OEM Subaru O2 sensor. Still the same...the CEL came back on within 3 miles of the new O2 swap out. At $120.00 each...I dont want to make a habit of changing then out. I am also running a new set of NGK Iridium BKR7EIX-11 plugs...Same thing once again. Oh well...I'll just live with it.
10-13-2003, 03:49 PM | #20 | |
Member#: 9749
SWIC
Vehicle:- |
10-13-2003, 04:49 PM | #21 | |
Member#: 22157
Vehicle:'02 WRX '04 350Z Cause We Are The Aquateen |
10-13-2003, 05:21 PM | #22 | |
Member#: 11571
RMIC
10-13-2003, 08:43 PM | #23 |
Member#: 643
BAIC
Vehicle:1999 2.5RS WRX powered |
This one's kinda out there, but another theory going around on this is the black topped coolant reservior on the '02's. The black paint comes off in the coolant and could block coolant passages causing hot-spots leading to some pinging.
My car has gotten the misfire codes for 1,2, and 3 quite a bit over the last year. But I've switched to the newer silver coolant reservior and haven't gotten another cel since. But, then again, it has only been a week and a half since the swap. |
10-13-2003, 09:19 PM | #24 |
Member#: 18251
TXIC
Cronic: I have right at 17,000 miles on her.
O2R6: No, VF34 with external Tial wastegate. Thumper23: My car only has 2 O2 sensors. One on the header and one on the downpipe. I have a HKS header, up-pipe, and downpipe. No cats. We can get away with it here. |
10-13-2003, 10:17 PM | #25 |
Member#: 12223
Vehicle:2005 WRX |
Try this. Sit at an idle and turn you ac on. Sit there for a bit with it on and see if you get a cel. This is what happened when #4 went on me a while back. I would get the code while I was driving always 1 or 4. but with the ac on it happened more often. See if the problem gets worse with the ac on. If it does chances are it is time for a short block.
Alarm wont stop going off, car wont start!! | felixk | Car Audio, Video & Security | 3 | 08-20-2009 05:10 PM |
TGV codes and misfire code upon start up | eliezerrosario | Service & Maintenance | 3 | 07-03-2009 05:27 PM |
Local NGK Source, P3023 #2 Misfire Code | hillman | Mid West Subaru Owners Club Forum -- MWSOC | 22 | 12-22-2007 02:38 PM |
Spark Plug Gap and Misfire Codes, Realtionship? | JayGold | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 6 | 05-15-2003 05:02 PM |
after unchip install i have misfire codes | MyFastToys | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 3 | 03-23-2002 12:04 PM |
