#76 |
Member#: 247861
Vehicle:2004 FXT Gold |
![]() Installed a Ball Bearing Arashi 20g. Today during tuning the turbo was overboosting to over 25 plus punds. Not sure why because according to specs, the turbo has a 1.1bar actuator on it, which equates to 15 psi. Is it possible an incorrect spring was used?
#79 |
Member Sales Rating: (10)
Member#: 116284
South East
Vehicle:2006 STi RBP |
![]() Been running mines now for 3+ years 30K+ miles with no issues.
Running EWG and meth injection at 24 psi making 415 whp and 380 wtq Dynojet (I have seen 440whp and 390 wtq on road dyno on a much cooler night). Turbo is about capped out there in terms of efficiency. |
#81 |
Member#: 491095
SWIC
Vehicle:2009 STi Blue Blue |
![]() i have the journal bearing with 11 blade exhaust and its about as responsive as the stock vf48...when it goes i am going to do the same turbo ball bearing and would expect it to spool a little better!
#86 |
Member#: 501997
Vehicle:2011 WRX gray |
![]() Been running my td06 sl2 20g now for about 20,000 miles now all in all great turbo for the money. Took me a little to get used to driving it with the lag at first, but once your able to keep it in that sweet spot with your shifts its a beast. I am thinking about switching out the compressor housing to a 3in anti surge style to see if it helps it with lag will update this thread if I do.
#87 | |
Member#: 254317
Vehicle:2011 STi |
![]() Quote:
Have you consider swapping out the journey bearing cartridge with a KBT bolt-on ball bearing to help with spool, I think Arashi offer this as an option. - |
#88 | |
Member#: 501997
![]() Quote:
<br> This on a 2.5l fully built with FMIC it hits 21psi at 3700 sometimes a little earlier depends on my driving. Will definitely hit higher boost but my trans will definitely not handle what this turbo has potential to do. Holds my 19 psi I have it set at til 7000 rpms no problem and pulls great. I stuck with a journal style turbo for reliability I drive too many miles to have to worry about rebuilding turbo every 20,000 miles |
#89 | |
Member#: 254317
Vehicle:2011 STi |
![]() Quote:
Is this statement based on personal experiences ? Or is this type of failure specific to Subaru or a particular brand of turbo ? I ask because a quick Google didn't show a lots of hits. If this is a concern, check out RHB turbo in Canada. They have a patented triple ball bearing design that float on oil film that might just be the best of both worlds. https://rhbturbochargers.ca/pages/fu...e-ball-bearing - |
#90 |
Member#: 518909
![]() For anyone that’s ordered a turbo from arashi how’d it go and how was communication. I’m trying to order one right now but having a lot of problems. Their website is having issues and I’ve gotten a few messages back and forth through Instagram dms, I’ve sent multiple emails but nothing in response. Any tips?
