Welcome to the North American Subaru Impreza Owners Club Wednesday January 27, 2021
Go Back   NASIOC > NASIOC Technical > FA Series Factory 2.0L Turbo Powertrain
Old 11-18-2020, 11:16 PM   #1
John1218360
Member#: 520372
2015 Wrx
Default 2015 stock boost 13?
I just got a 2015 wrx with 44k miles and ive heard people making more than 13psi of boost is it normal to be making 13 on stock tune
John1218360 is offline   Reply With Quote
Old 11-19-2020, 09:08 AM   #2
alapilusa
Member#: 424692
2015 WRX
I'm gonna have to go with no. I know the boost will vary by temperature, and with your location being in the northeast where it is currently quite cold (with dense air), it will take less boost to get the same amount of airflow through the engine. But even still, 13 sounds low. Typically, stock boost will peak to about 19-20 and then taper down to about 15 by redline.
alapilusa is offline   Reply With Quote
Old 11-19-2020, 10:37 AM   #3
John1218360
Member#: 520372
2015 Wrx
Do you think it might be a boost leak?
Old 11-19-2020, 11:35 AM   #4
crazy_irishman
Member#: 476872
I think you should have someone look at your car.
crazy_irishman is offline   Reply With Quote
Old 11-19-2020, 12:38 PM   #5
killadawg
Member#: 424203
2016 WRX STage ??
STI/PPG/ GM
As mentioned above, if it is cold out, you are just fine! with super cold weather you might just see 12 or 13 as the air is much more dense and you cap on your fuel delivery.. a datalog would show more info than just OMG it only hit 13psi or whatever. You should be fine if its super cold out.
killadawg is offline   Reply With Quote
Old 11-19-2020, 01:13 PM   #6
rtv900
Member#: 428511
2016 STI
does the wrx have the S and S# modes that affect boost peak?
my STI is down about 5 psi in S mode compared to S#
Old 11-19-2020, 01:27 PM   #7
Zak6182
Member#: 481754
2017 STi Base
I was thinking the same thing but I'm pretty sure SI modes for the WRX are only available in auto and it just changes the way it shifts.
Zak6182 is offline   Reply With Quote
Old 11-19-2020, 01:49 PM   #8
SnoBrrru
Member#: 501446
'15 WRX
gone plaid
My 2015 doesn't have those settings. I think they're only on the STI.
SnoBrrru is offline   Reply With Quote
Old 11-19-2020, 02:24 PM   #9
John1218360
Member#: 520372
2015 Wrx
Yeah mine doesn’t have those settings either maybe for auto wrx?
Old 11-19-2020, 05:56 PM   #10
killadawg
Member#: 424203
2016 WRX STage ??
STI/PPG/ GM
nope none of that coolness for us wrx kiddos.. that is only for them grown up STI's.. I don't even get this via MapDCCD with an STI Trans..
Old 11-28-2020, 11:54 AM   #11
vladd
Member#: 158185
17 WRX
CWP
This. I’ve seen boost peak at 11 psi when it was below zero F.
vladd is offline   Reply With Quote
Old 11-29-2020, 06:40 PM   #12
tegxsi
Member#: 446029
On a stock tune, the base boost targets is about 15 psi. It will subtract from base boost target based on intake temps.
It will take away:
-8.6psi @ 32F
-4.7psi @ 50F
-1.6psi @ 68F
It will also add boost at warmer intake temps. In extreme heat it will take boost away again.
tegxsi is offline   Reply With Quote
Old 11-30-2020, 03:10 PM   #13
vladd
Member#: 158185
17 WRX
CWP
It will take away:
-8.6psi @ 32F
-4.7psi @ 50F
-1.6psi @ 68F
What’s your source on those numbers? I’m curious cuz I’m seeing higher boost on a stock engine than what you say I should.
Old 11-30-2020, 06:37 PM   #14
240se
Member#: 7200
Don't confuse intake air temp with ambient air temp. Intake air temp is usually a little higher. You can use a OBD2 scan tool to see intake air temp.
240se is offline   Reply With Quote
Old 12-01-2020, 08:17 AM   #15
rtv900
Member#: 428511
2016 STI
honestly I wish the STI didn't have it either
It is a total nonsense feature. Every time I start the car I have to flick that knob to get full boost, and it's not like you have to be driving hard just because full boost is available
But the dumb thing will not stay in S# after shut down, always reverts back to S
Old 12-01-2020, 03:55 PM   #16
tegxsi
Member#: 446029
I have AccessTuner software.
You will see spikes and overshoot on the stock map because of the aggressive wastegate duty cycle tables.
Intake temperature compensations also apply to wastegate similar to boost targets.
Old 12-01-2020, 06:39 PM   #17
saaiello21
Member#: 501997
gray
Peak boost on 2015 WRX is 15.9 PSI and will taper down to 13 towards redline so if that is what you see this is normal. Stage 2 tune would peak at about 19psi and taper off at redline. Lower then expected boost can be so many things. I would check all intake hose and fittings first if nothing is obvious, smoke test it under pressure.
saaiello21 is offline   Reply With Quote
Old 12-13-2020, 04:48 PM   #18
vladd
Member#: 158185
17 WRX
CWP
I'm guessing there's more that goes into the boost target, such as elevation, cuz I was seeing around 11 PSI at -17F. This would be around 5K elevation.
Old 12-14-2020, 06:09 PM   #19
killadawg
Member#: 424203
2016 WRX STage ??
STI/PPG/ GM
Gross.. I guess not knowing what you don't have you might want it.. but thanks for that info!! I will take my full boost without extra knob fiddling anyday!! OH yeah we still need to switch off the damned traction thingy (not real traction control, but "slippage >> cut power" bs these cars have).. This is where the MapDCCD really shines
Old 12-27-2020, 06:40 PM   #20
edwards_26
Member#: 501464
2015 WRX
WRBP
When I was living in CT, my boost would peak around 18psi then taper down to 15psi so maybe a boost leak? I would check the stock BOV as I've heard that some will leak at peak boost.
edwards_26 is offline   Reply With Quote
