Welcome to the North American Subaru Impreza Owners Club Monday January 18, 2021
Old 07-23-2019, 12:21 PM   #76
Valarius Starchaser
Member#: 459312
2004 WRX Wagon
Hybrid 6MT Swapped WRB
Originally Posted by 02WRX84 View Post
Great write up man! Great stuff! Where does the hose just below the IACV and to the right of it go?
I’m looking around and notice that there isn’t a hose connected there or on the throttle body under the inter cooler. I’m thinking the hose popped off and that they should have a hose connected to each other. What do you guys think?
That’s a coolant line
A lot of guys remove it never understood why no matter what climate your in what the gain is to doing it
To my recollection it’s a cold start/emissions type system
Valarius Starchaser is offline   Reply With Quote
Old 08-03-2019, 09:46 PM   #77
Mountain Trek
Member#: 441288
2004 Forester 2.5XT
Red
Would this be the same setup for a 2.5XT Forester 2004 , or is there any significant difference to the sizes and lengths of hose needed? I had several crumble when getting the heads off.
Mountain Trek is offline   Reply With Quote
Old 08-14-2019, 11:15 PM   #78
not12listen
Member#: 147078
2006 WRX Wagon
Grey
Great write up! Been using their hoses for years - with rare exception - I wouldn't use anything else.
Hose D and G - those I had issue with. Those are for the transport of oil vapors (PCV) and oil isn't friendly (in my experience) with those hoses. Hose D in specific sheered off - it look like someone cut it STRAIGHT at the top end of the breather of the head itself - the heat, bend + less than friendly oil vapors.
Absolutely everywhere else, no issues.
I've also run their hoses in other vehicles like both of my wife's (1 wife, 2 cars) Outbacks and my 1986 Mr2 - stellar results in all 3 vehicles!
I've heard of a magical coolant hose that runs UNDER the throttle body (2006 WRX in my case). Just curious if I missed something, as I cannot find it on your WRX.
not12listen is offline   Reply With Quote
Old 12-06-2019, 05:18 PM   #79
Bdufala
Member#: 457779
I just installed a new radiator and am having issues with HOSE H. It is the factory hose so I plan on replacing it but the hose itself seems barely to big compared to being snug on my old radiator. HOSE I is slightly smaller (at least on my car) and seems like I need that same size on HOSE I.
Sorry if that is confusing or if I am on the wrong thread. Thanks
Bdufala is offline   Reply With Quote
Old 01-16-2020, 07:47 PM   #80
SIMPFLY
Member#: 54794
Jan 2004 WRX new
Jan 2021 297,000 miles
pic of heater hvac hoses below
part nos are 72411fe001 and 72421fe010
http://imgur.com/a/XWDmk7P
SIMPFLY is offline   Reply With Quote
Old 01-20-2020, 11:42 PM   #81
benders
Member#: 181247
2004 WRX Wagon
I believe it's also to prevent the throttle from icing up in cold. Otherwise the pressure/temperature drop after the throttle plate could form ice and a sticking throttle.
benders is offline   Reply With Quote
Old 04-20-2020, 04:53 AM   #82
evo_nahh
Member#: 492988
How are you guys clamping the hoses?
evo_nahh is offline   Reply With Quote
Old 07-06-2020, 07:49 PM   #83
PDXBugGuy
Member#: 504109
01G
Lets goooo, was hoping to find a thread like this. Crazy what the search feature can do
PDXBugGuy is offline   Reply With Quote
Old 11-30-2020, 01:04 AM   #84
bodhicheetah
Member#: 398045
2004 Impreza WRX
In the process of doing this right now. Was having a hell of a time following the write up and the pictures because my internet is slow as hell.
Took the liberty of creating a google doc with all the pictures in line with the text.
All credit goes to freeman.matt for the excellent original write up and pictures!
All I did was put it on the same page. Hope it helps someone out there.
https://docs.google.com/document/d/1...JpYelkEcw/edit
Btw, it seems HPSI-Motorsports has run out of or discontinued their Subaru hose kit? Can't find it on their site anymore. I ordered mine months ago, luckily I guess...
bodhicheetah is offline   Reply With Quote
