Welcome to the North American Subaru Impreza Owners Club Sunday December 16, 2018
Old 03-18-2017, 12:19 AM   #251
fredrik94087
Member#: 337075
2015 WRX Stg3 SOLD
Moderators, please remove post #s 249, 250, and 251. Obviously wrong thread.
fredrik94087 is offline   Reply With Quote
Old 04-02-2017, 04:49 PM   #252
knuckles43
Member#: 465398
Anyone ever tried this on a later model car? I have an '11 Outback sport and would like to drop in the STI engine when mine gives up.
knuckles43 is offline   Reply With Quote
Old 04-18-2017, 07:59 PM   #253
notacarguy
Member#: 462586
2006 wrx
wrb
notacarguy is offline   Reply With Quote
Old 04-19-2017, 01:54 PM   #254
shane.stavron
Member#: 465972
shane.stavron is offline   Reply With Quote
Old 10-11-2018, 12:27 AM   #255
GlenCastleberry
Member#: 63067
2002 Impreza WRX
World Rally Blue
Which years STI drivetrain + trans will swap into my 2002 wrx? I have a crashed 2011 STI I have an option to buy if it will work for the swap, brakes and all
GlenCastleberry is offline   Reply With Quote
Old 10-11-2018, 12:34 AM   #256
Charlie-III
Member#: 30669
1998 Legacy 2.5GT
Silver Sleeper BK, 5MT
Mostly my son, and I, just swapped a complete 05 STi (engine, trans, rear diff, suspension, brakes, full harness, etc) into a 02 WRX. Basically he has a 05 STi in a 02 WRX hatch.
I mean like everything except headliner and front door harnesses.
Bolting it in is one thing, getting some electrics to work is another. We had to swap some wires and bits from STi fuel tank to WRX tank, swap wiper motor, plus everything else listed.
Old 10-11-2018, 11:11 AM   #257
T-37
Member#: 175624
0304 WRX WRX
SY WRB
A 2011 is a totally different animal than an 05.
A 2011 won't just bolt in. Basically the suspension is totally different, so you won't be able to use knuckles, control arms, the rear brembos, or the axles, etc.
The pure drivetrain stuff should work with minimal complications. Transmission, rear diff. Need a DCCD controller and a wheel speed sensor to drive your cluster. (MapDCCD or DCCDpro can provide both) Then you'll have to find some GD chassis axles and knuckles
The engine is going to be a struggle to get to work correctly as there's no way to run dual AVCS off the 02 ECU and the wiring isn't exactly plug and play. Also the 2011 is CANBUS so EVERYTHING is run through the ECU.
You could potentially swap to your drive by cable intake and run the engine off of the 02 ECU without AVCS, but I'm not sure if that's possible will dual AVCS cars.
T-37 is online now   Reply With Quote
Old 10-27-2018, 07:18 AM   #258
silverbullet55
Member#: 445403
2003 WRX
your better off locating an early 04 STI for the easiest swap. The front hubs are the same, the rear hubs will need to be changed due to different splines for the R180 diff. Be sure to get the crossmember for the 6 speed. Wiring wasn't bad at all. You don't have to change the ABS or ECU and cruise and ABS still work, no abs or check engine light. You might get a p1596 if you are going from a 4eat to 6 speed and keep your 4eat ecu, but does not cause issues. I used the 4eat harness for a lot of my connections, Iwire has a nice plug harness kit for this swap, I only purchased a 3 wire VSS harness to tap into the 4eat 4 wire VSS as the STI is a 3 wire VSS set up. I do have the DCCD switches and module but decided not to install it as it is more involved and costly if you wanted the factory STI setup which means you would need the complete harness and STI cluster and ECU. I would go with DCCDPro in the future that make a nice setup and can use the sti thumbwheel and switch. Without DCCD installed, you will have a 35%F-65%R ratio. I would also suggest buying new switches such as reverse light switch on the tranny as its easier to replace while the tranny is out of the car, in the event the original is faulty, realizing after you installed everything and back out of the garage and reverse lights don't work. I suggest the same with the switches on the clutch pedal assembly as it is a PITA to do when pedals are already installed. We just got done with the swap in my sons car that had a 4eat and WOW night and day difference in performance to say the least! Not to mention him having fun driving a 6 speed vs auto! Good Luck!
silverbullet55 is offline   Reply With Quote
Master swap list for 04-07 Sti 6 speed into WRX crashtke Transmission (AT/MT) & Driveline 812 03-26-2018 09:06 AM
Feeler: 06 wrx sti 6-speed drivetrain swap... 06TRDude Drivetrain 8 02-23-2009 08:50 PM
Cost estimates for 6-speed swap into an 02 WRX? aasim_a Transmission (AT/MT) & Driveline 24 05-31-2008 05:37 PM
Parts needed for an STI drivetrain swap into an 01 RS SubeSTIle Subaru Conversions 15 11-04-2006 02:11 PM
Parts needed for an STI drivetrain swap into an 01 RS SubeSTIle South West Impreza Club Forum -- SWIC 2 10-31-2006 05:15 PM
