Welcome to the North American Subaru Impreza Owners Club Tuesday January 22, 2019
Old 11-19-2015, 01:57 AM   #1
Kevinsmith312
Member#: 380680
2006 Impreza 2.5i
navy blue
Default Lifespan of Center DIfferential
What is the lifespan of the center differential. If its any consolation my vehicle is a 5mt 06 2.5i. I know that the center diff is shares a reservoir with the transmission and front differential, and that there is silicone fluid sealed in the center diff. I also know this fluid does last a long time and will slowly lose the properties it needs so slowly my vehicle will become one wheel drive (since i have no front or rear LSD). Things that are bad are tons of wheel spin and that once this fluid goes bad the center diff just needs to be replaced. So my question is how long does this stuff last, what is a long time? I have almost 140k miles. I like snowboarding and i don't really wanna go up into the mountains with just 1 tire spinning.
Kevinsmith312 is offline   Reply With Quote
Old 11-21-2015, 10:11 PM   #2
MrH
Member#: 186279
2016 Forester XT
Ice Silver
I have 250000 miles on my '00 2.5RS and it still works. I ski up tin VT where there are piles of snow.
Get good winter tires.
Buy the tires in 4s.
Keep them rotated.
MrH is offline   Reply With Quote
Old 11-25-2015, 12:45 AM   #3
Kevinsmith312
Member#: 380680
2006 Impreza 2.5i
navy blue
check check check! sweetness good to hear! I'm pretty good on some all season tires with good tread
Old 02-14-2018, 06:17 PM   #4
car_freak85
Member#: 13530
EA63 , EA81T, EJ20G,
EJ205
The original factory center diff in my 2002 WRX seems to be giving up the ghost at 137k miles.
car_freak85 is offline   Reply With Quote
Old 02-14-2018, 09:39 PM   #5
monkeyposeur
Member#: 333468
1993 SS
03 WRB GD 205/22T 20G-XT
Had one center diff go @ 126k. Snap ring came off and muched the transfer gears. Second center diff started to go on my JDM 5mt recently. It supposedly had less than 60k on it.
Not too bad of a job to replace. But the center diff is a $500 part.
monkeyposeur is offline   Reply With Quote
Old 02-15-2018, 01:37 PM   #6
car_freak85
Member#: 13530
EJ205
Doesn't the factory procedure ask you to pull the trans and stand it up on end? I've read people do it in-car also...
Old 02-20-2018, 02:45 AM   #7
monkeyposeur
Member#: 333468
1993 SS
I didn't read the FSM procedure for this job. Just watched some youtube videos. I don't see why you would need to pull the trans. If I was going to pull the trans I would have just swapped in a 6mt at that point since it would be about the same amount of work, although more $$$ of course.
I was even shopping for a 6MT but decided to just replace the center diff in the end.
Old 02-20-2018, 03:47 PM   #8
mrsaturn7085
Member#: 375462
2006 Impreza WRX STI
WR Blue
You don't need to pull the transmission, but the upper bolts on the rear extension case are not at all easy to remove/install due to the proximity of the transmission to the transmission tunnel. You also need to clean and re-apply gasket former to the extension case during reassembly... and this is challenging with the transmission in, to say the least. Lastly, the 4 split bearings have to stay on the shaft when you install the c.diff itself... this can be challenging as well.
mrsaturn7085 is offline   Reply With Quote
