Welcome to the North American Subaru Impreza Owners Club Monday June 25, 2018
Old 01-02-2017, 11:09 PM   #51
gnashville
Member#: 460638
2004 Forester X
Originally Posted by dead_eye View Post
Excellent!
I say!
gnashville is offline   Reply With Quote
Old 01-25-2017, 09:41 PM   #52
LeeRSti
Member#: 266394
2001 2.5 RS
Black Diamond Pearl
I just want to verifiy, the R160 came in all Imprezas and WRXs, and the R180 came in all STis? JDM and USDM?
LeeRSti is offline   Reply With Quote
Old 01-31-2017, 03:04 PM   #53
R31oH
Member#: 265702
96 lgacy
white
Awesome post and awesome 818 in the background of the 1st pic! Kind of a noob question here... but how did you get the rear diff out of its casing?
I am currently doing a diff swap on my 96 legacy gt, I believe its an R160. The diff is off the car, I have the rear cover and side bearing retainers off, but I cant seem to wiggle the diff out! I thought I had to pull off the side bearings off the actual diff to slide it out of the housing, but you have bearings on all your rear diffs! This is my first time doing diff work and it is driving me nuts!!! Do i just yank it out of there or am I missing something?
R31oH is offline   Reply With Quote
Old 04-15-2017, 10:23 AM   #54
johnnyw2007
Member#: 463614
2007 wrx
black
Not sure if this is the right spot but pretty sure it is. But my front diff seems to be slowly leaking and I checked the levels and it's barely covering the L on the dipstick and I was wondering if this little leak is a common problem and just needs a little bolt snugging or what and also what kind of gear oil should I use? 2007 wrx 5 speed btw. Thank you!
johnnyw2007 is offline   Reply With Quote
Old 04-24-2017, 04:08 PM   #55
WhiteRguyX
Member#: 126782
Question for the diff experts:
Has anyone seen or heard any info on a front 1-way LSD for a 6MT 2016 WRX? Stage 2 with flex fuel ate mine on the track a week ago and I can't find any info on it.
Any help is much appreciated!!
WhiteRguyX is offline   Reply With Quote
Old 06-27-2017, 05:00 PM   #56
Awd1stgen
Member#: 440351
Does a 4eat front ring gear mount in a 5mt given same ratio?
Awd1stgen is offline   Reply With Quote
Old 03-20-2018, 07:51 AM   #57
JDM_mes
Member#: 201914
1997 Impreza
cant see any of the photos. would be great posts... but not
JDM_mes is offline   Reply With Quote
Old 06-06-2018, 12:50 PM   #58
Fierysun
Member#: 82745
2005 Subaru STI
2003 EJ207 S204 Wagon
How does the car handle/behave between the AP suretrac, Torsen, and clutch style diff? Basically, if i have a Torsen, is there a good reason for me to switch to suretrac or clutch type?
Fierysun is offline   Reply With Quote
Old 06-21-2018, 02:32 PM   #59
rain164845y
Member#: 419917
So is this a simple bolt in for 2015+ WRX? I have never seen the various splines to know if it is compatible or not. Also, is this a legit suretrac, or vlsd? How do I know?
Thanks!
https://rover.ebay.com/rover/0/0/0?m...2F273292043770
rain164845y is online now   Reply With Quote
