Welcome to the North American Subaru Impreza Owners Club Wednesday November 21, 2018
Old 02-14-2018, 05:28 PM   #1
esimili
Member#: 480004
2017 WRX
WR Blue
Default new clutch slipping and grabbing
got. new clutch for my wrx flywheel resurfaced. it's slipping and grabbing sometimes now what could cause this?
esimili is offline   Reply With Quote
Old 02-18-2018, 10:49 AM   #2
Pistonjunkie
Member#: 474008
2004 WRX Wagon
Did the flywheel and pressure plate get cleaned before assembly? Could be an oil contamination issue if they werenít cleaned.
Pistonjunkie is offline   Reply With Quote
Old 02-18-2018, 11:52 AM   #3
esimili
Member#: 480004
2017 WRX
WR Blue
that's what I was thinking. would a warped flywheel do it too? also when I picked it up, I asked if I should go easy on it to break it in. he said no. is that right?
Old 02-18-2018, 03:52 PM   #4
Pistonjunkie
Member#: 474008
2004 WRX Wagon
No, most manufacturers will tell you to take it easy for the first few hundred miles on most clutches.
A warped one maybe. How it was treated before it was resurfaced has a bigger impact. If it was thrashed pretty hard it could have some hard spots in it that wonít machine out with a re-surface job. I opted to replace mine when I did my clutch since Iím the 5th owner of my car and there is no telling how it was treated for the 13 years prior.
Old 02-18-2018, 04:13 PM   #5
Vancouver98STi
Member#: 459287
1998 JDM Impreza STi
White GF8 wagon
Question
Is that even possible? And if so, wouldn't it be readily apparent when looking at the freshly machined flywheel?
Vancouver98STi is offline   Reply With Quote
Old 02-18-2018, 08:37 PM   #6
Pistonjunkie
Member#: 474008
2004 WRX Wagon
It is and it would be. But it doesnít stop people from putting it together like that. Usually the same type of people that donít replace pilot bearings or clean the oil off of pressure plates or flywheels before assembly. And then tell you there isnít a break in on a new clutch.
Old 02-19-2018, 11:58 AM   #7
Samurai Jack
Member#: 21145
2002 Enemy of Aku
One has to question why the OP needs a new clutch after only one year.
As was said, new clutches have a break-in period of approximately 500 miles.
Abusing a clutch = early clutch failure.
Contaminates on pressure plate / clutch disk / flywheel = bad things happen
A warped flywheel? Highly doubt it
Samurai Jack is offline   Reply With Quote
