Welcome to the North American Subaru Impreza Owners Club Tuesday August 21, 2018
Mid Atlantic Impreza Club
Go Back   NASIOC > NASIOC Chapters > Mid Atlantic Impreza Club -- MAIC > MAIC Private Classifieds
Old 02-26-2018, 02:48 PM   #1
chansdaman
Member Sales Rating: (1)
Member#: 457390
Default MD: 2002 WRX wagon EJ25/B25 built 5spd $7000
Basics:
-2002 Subaru WRX wagon
-EJ25 block with B25 head
-5-Speed manual (built)
-228K on body
~70K on engine/transmission
-Clear title on hand
-Clean CARFAX on hand
-3rd owner (including me)
-Dyno'd at 277whp/291 Torque
-Professionally tuned at Agile Automotive
Bad:
-Dents with paint issues on the left side
-Missing a couple interior pieces such as rear headrests, cargo cover
-Rust in rear right quarter panel
-Paint chip marks on bumpers
-Small power steering fluid leak
-Clunking noise from rear right (possible from the coilovers)
-Typical rust for MD
Good:
Engine/drivetrain
-EJ25 block/B25 (STI head) build
-VF39 turbo
-JDM "pink" injectors
-Walbro 255 fuel pump
-Perrin turbo inlet hose
-Really nice turbo back exhaust with Borla Hush muffler
-Cosworth bearings
-Cosworth oil pump
-Cosworth crank
-Rebuilt transmission with Legacy GT gears (much stronger)
-Southbend Stage 1 HD clutch (~7K miles)
-DCCD's VSSPro (corrects lower speedo readings from the lower Legacy gears)
-Rebuilt rear diff
-TurboXS Hyperflow oversized top mount intercooler
-3 row aluminum radiator with new hoses
-Samco silicone hoses for most intercooler/coolant passages
-Ground kit
-Cobb Accessport
Brakes/Suspension
-CUSCO coilovers zero 2R
-GTSPEC subframe brace
-Whiteline Anti Lift Kit
-Upgraded Akebono brakes
-Braided stainless brake lines
-JDM FHI STI front strut bar
-CUSCO rear strut bar
-Spearco Assetto Gara rims with Continental ExtremeContacts
Recent maintenance/parts
-New Southbend stage 1 HD clutch
-Resurfaced flywheel
-OEM Coolant expansion tank
-OEM clutch slave cylinder
-New shift joint
-New coolant
-Redline lightweight shockproof fluid
-Replaced oil drain back hose clamp on the turbo
-OEM oil pan
-Akebono rotors and pads
-Brake fluid flush
-Valve cover gasket
-Rotated tires
-Spark plugs
-Fuel filter
-PVC valve
Interior/Body:
-Fairly clean interior
-JDM Subaru Armrest Extension
-JDM STI hood scoop
-Dynomat sound deadening materials in the rear
-Power windows/locks/cruise control, all electronics work, to include heat and A/C
I bought this primarily to be commuter, and as such put about $4,000 in maintenance/repairs (with receipts from Andrewtech Automotive) within the past year. I no longer have a commute, and with this being a 3rd spare car, it doesn't make sense for me to hold on to it. Although she isn't the best looking, this car is rock solid mechanically. No overheating (180-190F coolant temp while cruising), no misfires, no shifting issues, boosts to 17-18 psi, turbo flows well at 39 lb/min, and no check engine lights. The car handles like a go cart (albeit a little too stiff for my taste), very quick around town (max torque at 4K rpm), and has ton of headroom and cargo room (benefit of a wagon). The turboback exhaust is catted with a resonator, and Borla Hush has a nice muted sound, but still lets out a nice pop, as well as the subie rumble that we all love. I have the dynosheet and the tune files. With the engine, drivetrain/clutch and cooling system fairly new, this vehicle should serve the new owner nicely for a long time. I do not have receipts for the engine nor the tranny work (you can clearly see the EJ25 block stamp, and I added the speedo correction device for the regears, so it's all there), but still have ~$4K worth of maintenance/repair receipts from Andrewtech.
I have done my best to be as upfront as possible.
Price: $7,000 OBO
Located in Howard County, MD
chansdaman is online now   Reply With Quote
Old 03-02-2018, 03:32 PM   #2
chansdaman
Member#: 457390
Taking offers
Old 03-04-2018, 11:18 AM   #3
Smurftastic
Member Sales Rating: (43)
Member#: 243697
02 | BLOD Founding
Member | TopScoob 031
Looks like a hell of a deal, GLWS!
Smurftastic is offline   Reply With Quote
Old 03-07-2018, 02:10 PM   #4
chansdaman
Member#: 457390
Thanks for the support!
Old 03-10-2018, 02:26 PM   #5
chansdaman
Member#: 457390
Weekend bump!
Old 03-12-2018, 12:03 AM   #6
chansdaman
Member#: 457390
Some pics of receipts and carfax.
Old 03-16-2018, 03:49 PM   #7
chansdaman
Member#: 457390
Updated the post. The Coilovers are CUSCO Zero 2R.
Old 04-05-2018, 11:13 AM   #8
chansdaman
Member#: 457390
Bi monthly Bump
Old 04-11-2018, 08:54 AM   #9
chansdaman
Member#: 457390
Increased the preload on the rear right coilover, and the clunking is now gone. Less bouncy too.
Old 04-16-2018, 10:49 PM   #10
chansdaman
Member#: 457390
Added some updates (I guess I didn't know as much as I thought about the car!)
Comes with Whiteline Anti Lift Kit installed, JDM STI hood scoop, and JDM Subaru Armrest Extension (has two compartments)
Old 05-02-2018, 03:02 PM   #11
chansdaman
Member#: 457390
Just fixed leaky gasket in the high pressure AC hose, and had it professionally evacuated and filled. Coolant was just replaced as well. Ready for the summer.
Old 05-23-2018, 04:40 PM   #12
chansdaman
Member#: 457390
Replaced battery with Autocraft Gold (3 year warranty, 640 CCA). Also updated the original post regarding the build. During the last oil change, I found out this is not a hybrid build, but a EJ25 with B25 head, which is an STI head.
