#1 |
Member#: 164172
NWIC
Vehicle:97 OBS EJ20G ZILLA 87 GL |
![]() I need help finding homes for these plugs and stuff... i have a JDM 94 wrx motor... i took off the wiring and i thought it would be pretty simple to put them back on... but i cant find where they are suppose to go... i think i plugged all them in.. except these.
Please help me identify them and if u can give me the location on where they go.. THANKS. 1. 2. 3. 4. 5. 6. 7. ![]() CLOSE UP ![]() ![]() this is my car so far. gc6 converted to gc8 w/ej20g ![]() |
#2 |
Member#: 3362
Vehicle:2001 I've wired a Few cars in my day |
![]() 1. plugs into the ignitor
2. boost solinoid 3. Oxygen sensor 4. plugs into the ignitor 5. 6. 7. MAF I'll have to get back to you on 5 and 6 |
#3 | |
Member#: 3362
![]() Quote:
Anything that is on the engine should have a home. Look for what they could plug into. If you have not plugged in the ignitor the car will not get spark. It looks like you have a few items in there from the L that are no longer needed and need to come out of the engine compartment. Z |
#4 |
Member#: 177
NWIC
Vehicle:The 93 W/EJ20K-sold Subaru-less :( |
![]() map and purge?
#5 |
Member#: 141232
NESIC
Vehicle:02 v7sti wagon signal green |
![]() 5. BCS.
6. engine harness to 02 sensor plug. |
#6 |
Member#: 119995
W. Canada
Vehicle:2004 Outback XT Peachy |
![]() 6 looks like the ABS plug.
#7 |
Member#: 164172
NWIC
![]() THANK U EVERYONE for all the info... the engine Turns over... but i got no spark tho... i dont know if this is the problem.... but i have 1 plug that is unused... and i dont know what it goes to...
![]() Close up. ![]() |
#8 |
Member#: 8039
NESIC
Vehicle:94 v2 STi RA - RHD |
![]() That plug looks like one of the plugs for the coil packs
#9 |
Member#: 164172
NWIC
![]() ill look for the wire color tomorrow.... and also my fuel pump is only getting 4 volts.... and it supose to have 12.... no fuel is pumping throught.. im going to check the wires between the ecu and the pump... does this give me an excuse to upgrade my fuel pump? hha
#10 |
Member#: 164172
NWIC
#11 | |
Member#: 8039
NESIC
![]() Quote:
Sounds like you may be missing the diode. |
#12 |
Member#: 164172
NWIC
![]() CEL? whats that... when i turn the key to the ON position... the wipers work and the lights and stuff... but i dont hear the fuel pump, pumpin... u can usually hear a lil buzzing..
#13 | |
Member#: 8039
NESIC
![]() Quote:
If the cel is not turning on, then your ecu/fuel pump won't turn on. |
#14 |
Member#: 164172
NWIC
![]() yeah my CEL is on.... along with the oil light...my fuel pump is still not pumping... my ECU has power to it....
#15 |
Member#: 182337
Tri-State
Vehicle:1997 Impreza Outback Sport -- White |
![]() why wont the ecu work if the CEL is not on?
#16 |
Member#: 8039
NESIC
#17 |
Member#: 164172
NWIC
![]() well i got it started... but a few bugs here and there..my CEL is one... but i think its cuz my O2 sensor isnt plugged in.... cuz i have to buy one....
my car stays on even with the key out... my temp sensor doesnt work... and i think my speed and RPMs... gas works tho =). |
Need help on fuel pump wiring! | powerneedy | Subaru Conversions | 5 | 11-20-2008 05:56 PM |
EJ20G Merge..need help with some yellow wires | xlur8ed | Pre-2002 Factory Turbo Powertrain | 0 | 03-25-2008 05:06 PM |
$50 JDM EJ20G Plug wires -individual coilpacks | supermoose | Private 'For Sale' Classifieds | 16 | 10-17-2005 06:51 PM |
Need help on plug wires | yukon1 | Alaskan Impreza Club Forum -- AKIC | 10 | 05-26-2004 10:51 PM |
need help on 02RS ecu wiring diagram | SFimpreza411 | Normally Aspirated Powertrain | 8 | 06-13-2002 10:38 PM |
