Welcome to the North American Subaru Impreza Owners Club Sunday March 7, 2021
Old 02-09-2006, 05:51 PM   #1
xcntrk75
Member#: 60224
Default Official Legacy Part # thread
Post your Legacy related part-numbers for replacement and upgrade OEM parts:
(Replacement Part numbers, Upgrade/Performance Part numbers, descriptions, details, requests, and related comments only!)
Great parts guide with OEM numbers courtesy of LetItSnow:
>>>Parts book x-treme<<<
<DLC> No Questions folks, just parts. Ask questions in the forum please.
xcntrk75 is offline   Reply With Quote
Old 02-09-2006, 06:38 PM   #2
Cajual
Member#: 12900
1997 Legacy GT-Turbo
Quick Silver Metallic
Part Description:
Fender Plug
Model:
BD/BG (noted by Wiscon_Mark: does not fit '95 models)
OEM Part Number:
46059FA000
Notes/Verification:
Perfect fit, snaps right in and plugs up the hole. Must have for those who have done a snorkusectomy.
Picture for Reference:
Cajual is offline   Reply With Quote
Old 02-09-2006, 06:44 PM   #3
Cajual
Member#: 12900
Part Description:
JDM Aluminum Door Sills
Model:
BD/BG
OEM Part Number:
E1017AC000
Notes/Verification:
Installs directly over top the plastic sills with double sided tape and a couple of tabs that hook underneath. Adds some nice interior bling! The adhesive loses its stickiness in cold climates.
Old 02-12-2006, 02:01 PM   #4
xcntrk75
Member#: 60224
Model:
1998 2.5 GT Sedan (BD)
Part Description:
Front Hub
OEM Part Number:
28052AA010
Notes/Verification:
Often needed while replacing wheel bearing, this number is for an AT although they *should be the same as MT.
Part Description:
Front Ball-Joint
OEM Part Number:
21067GA050
Notes/Verification:
Direct fit, Right/Left side same.
Part Description:
Tie-Rod End
OEM Part Number:
34141AC010
Notes/Verification:
Part Description:
Front Wheel Bearing (cartridge)
OEM Part Number:
28016AA011NT
Notes/Verification:
Entire bearing assembly, this is for an AT although they *should be the same.
Part Description:
Inner & Outer oil seals, wheel bearing.
OEM Part Number:
28015AA070
28015AA080
Notes/Verification:
Both inner and outer wheel bearing oil seal. One is pressed into hub before bearing, the other after.
Part Description:
Radio Bezel, wood grain
OEM Part Number:
J1310AC020
Notes/Verification:
BD, 2-DIN, Radio bezel in wood grain.
Part Description:
Power antenna replacement mast (rod nut assembly)
OEM Part Number:
86323AC070
Notes/Verification:
Part works great, easy to replace, make sure you don’t loose the tiny screws which hold the motor unit together, also may want to use some additional grease to help with the install.
Old 02-12-2006, 02:05 PM   #5
xcntrk75
Member#: 60224
Model:
Various**
Brake upgrade numbers:
H6 rear brake upgrade:
(x2) 26700AE04A Outback rear rotor
(x1) 26696FC002 WRX rear brake-pad kit (early year)
(x2) 26625AE000 Outback rear caliper brackets
Subaru 4-pot front brake parts:
(x1) 26296FA100 4-pot front brake-pad kit
(x2) 26310AC040 4-pot front rotor
(x2) 26232FA020 4-pot cross spring
(x4) 26228FA000 4-pot retaining pin
http://forums.nasioc.com/forums/showthread.php?t=623187
Old 02-12-2006, 10:40 PM   #6
cardin555
Member#: 9972
2007 Jetta
grey
Model:
BE/BH
JDM parts
84001AE020 rh headlight (1 bulb system)
84001AE030 lh headlight (1 bulb system)
84001AE000 rh headlamp (2 bulb system)
84001AE010 lh headlamp (2 bulb system)
84001AE040 rh headlamp (HID)
84001AE050 lh headlamp (HID)
84201AE080 rh tail lamp (Lancaster)
84201AE090 lh tail lamp (Lancaster)
84201AE000 rh tail lamp (wagon)
84201AE010 lh tail lamp (wagon)
84201AE04A rh tail lamp (sedan)
84201AE05A lh tail lamp (sedan)
84251AE03A trunk finish lamp (sedan)
86512AE010 sedan rear wiper motor
86532AE040 sedan rear wiper arm
J1018AE000 Blitzen grille
J1018AE011 Blitzen badge
J1018AE012 Blitzen badge
93073AE440 B4 trunk badge
93073AE470 B4 trunk badge (pink)
E7218AE000** Blitzen sedan spoiler
E7718AE110** Blitzen front bumper
E7718AE120** Blitzen rear bumper
57711AE000 front re-bar
57711AE030 rear re-bar
57229AE010 turbo hood (steel)
57229AE030 turbo hood (aluminium)
** denotes 2 letter color code to complete
If anyone is looking for something in particular for JDM BE/BH, I will try my best to find it.
cardin555 is offline   Reply With Quote
Old 02-20-2006, 08:06 AM   #7
Legacy Rally Guy
Member#: 104066
1976 1976 Leone GSR
These are for the 1991 EJ22T Legacy
I have some dealer prices listed as well...
These are stock parts unless otherwise noted....
14462AA060 Air Intake Hose (Turbo to Intake Manifold) $193.30
10105AA052 Engine Master Gasket Kit $279.86
12018AA360 Left Hand Pistons $80.39
12013AA350 Right Hand Pistons $69.87
12033AA390 Piston Rings $155.06
12209AA000 Crank Bearing Set $116.08
12108AA290 Connecting Rod Bearing Set $250.23
21111AA065 Water Pump $120.19
15010AA108 Oil Pump $140.23
13028AA102 Timing Belt $60.07
13207AA120 Intake Valve Seal (1 seal per package) $5.11 ($40.88 for set)
13211AA110 Exhaust Valve Seal (1 seal per package) $4.96 ($39.68 for set)
I wonder why the pistons are different prices for left and right....?
Legacy Rally Guy is offline   Reply With Quote
Old 02-21-2006, 05:46 PM   #8
95legacy
Member#: 74009
95 Legacy GT
Deep Sapphire Pearl
Just one part for now, got to go through my records and pull the other numbers.
BD/BG/BK
91017AA010 grill mounting clip, the infamous piece everyone seems to need.
Price $3.92 from the dealer.
95legacy is offline   Reply With Quote
Old 03-08-2006, 08:37 AM   #9
cardin555
Member#: 9972
2007 Jetta
grey
84201AC000 JDM BD tail lamp rh
84201AC010 JDM BD tail lamp lh
84001AC100 JDM projector head lamp rh
84001AC110 JDM projector head lamp lh
Old 04-26-2006, 02:24 AM   #10
redgrocerygetter
Member#: 42044
1998 Legacy GT
Part: Bracket Hanger Manual Transmission 4WD
Part Number: 44021AC030
Discription: The Bracket that attaches to the transmission then to second Cat. My Total cost was about 30 dollars
On the Car
Hope this helps someone.
redgrocerygetter is offline   Reply With Quote
Old 05-29-2006, 03:47 AM   #11
NiTRoN
Member#: 30556
2000 Legacy GT (BE)
over 250,000 Miles
Alight guys and galls hope this helps
edit: Ok the old links got truncated.. so I redid it, hopefully this one stays allot longer.
Legacy&Outback 95-99
Legacy&Outback 00-01
NiTRoN is offline   Reply With Quote
Old 08-30-2006, 10:43 PM   #12
fibuz
Member#: 53410
BE-> GD->GR->SG->BL
WAawd.org
Model: BE/BH (Baja)
Part #: 57220AE01A Desc: Hood Compl F (00+ BAJA HOOD WITH HOOD SCOOP) MSRP: $339.95
Part #: 90821AE020NN Desc: Grille F Hood (BAJA HOOD SCOOP INSERT) MSRP: $106.53
fibuz is offline   Reply With Quote
Old 10-28-2006, 11:04 AM   #13
jac04
Member#: 49895
09 Forester
06 Legacy 2.5i Wagon
Model: 05 - 06 Legacy Wagon & Sedan
Part: Wiper Blade Refills (Inserts)
Part Number:
Nissan 28895-EA000 for LH side
Nissan 28895-EA010 for RH side
Discription: Wiper blade refills (rubber inserts only). You will need to transfer your stainless 'springs' to these new inserts. Why settle for the horrible Subaru inserts when you can have a quality insert?
jac04 is offline   Reply With Quote
Old 12-19-2007, 11:34 AM   #14
phieleven
Member#: 108466
'98 GT & '95 LX
Outback BH & BP
BD/BG/BK
BD/BG/BK
91017AA010 grill mounting clip upper (x 4)
91059FC090 grill mounting clip lower
(x 2, these go into the headlight.)
phieleven is offline   Reply With Quote
Old 01-31-2008, 06:06 PM   #15
DLC
Member#: 1964
2012 Fit Sport 5MT
Orange Burst
BD/BG/BK Grp. N strut mounts
ST203704S000 (RH)
ST203704S010 (LH)
Those are the original numbers...
New!
B0310FE010 (RH) $119.95
B0310FE011 (LH) $119.95
DLC is offline   Reply With Quote
Old 02-01-2008, 04:52 PM   #16
Slug71
Member#: 159963
2003 Subaru Baja
Black & Silver
Air Pressure Sensor
Part #22098AA000
Anyone know what this part is and where it is? I have the Haynes repair manual but its not very clear about the location. Its throwing a CEL (codes P0105&P0106) and need to take care of it but dont want to pay $258 through Subaru for it.
Slug71 is offline   Reply With Quote
Old 02-05-2008, 04:45 PM   #17
Slug71
Member#: 159963
2003 Subaru Baja
Black & Silver
Originally Posted by Slug71 View Post
Air Pressure Sensor
Part #22098AA000
Ok guys, for anyone having this same issue its the plug unit on the passenger side strut behind the Airbox with the number 22012AA070.
Old 03-05-2008, 02:17 AM   #18
subiekid
Member#: 25516
1995 Legacy TURBO!!!
EJ22T/TEC3 & '12 Civic
Part Description:
Clutch and brake rubber cover
Model:
BD/BG with M/T
OEM Part Number:
36015GA111
Notes/Verification:
Simply sides on over the metal
________________________________________
Part Description:
Key less entry remote
Model:
98 BD/BG
OEM Part Number:
H7110AS020
subiekid is offline   Reply With Quote
Old 05-01-2008, 06:17 PM   #19
sadsack
Member#: 102327
2003 Legacy - RIP
Part Description:
Bilstein HD monotube struts/shocks
Model:
BE/BH non-Outback
Bilstein Part Numbers:
F4-VE3-A168-M1 (Front L)
F4-VE3-A169-M1 (Front R)
F4-BE5-A170-M1 (Rear)
Notes/Verification:
HD series can be custom revalved
sadsack is offline   Reply With Quote
Old 08-05-2008, 06:00 PM   #20
blackfang
Member#: 131347
2007 Legacy 2.5i SE
For those wondering if a SPT Catback fits a non turbo Legacy...it will
Part Description:
SPT Catback
Model:
This also fits a Legacy 2.51/SE
SOA3881110
Notes/Verification:
None. It took 5 minutes to bolt it on.
blackfang is offline   Reply With Quote
Old 09-06-2008, 05:29 PM   #21
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
1996 Impreza coupe
Originally Posted by NiTRoN View Post
Direct link to that one from my website. That way you don't have to wait 45sec for megaupload.com to let you download it, and my download speed should be faster.
Hard rubber/plastic plug that goes on top rear of block, if removed you look down on the flywheel/flexplate:
11413AA033 - should cost you about $6.
Injector seals, sit in the recesses in the intake manifold with the injectors sitting in these fat o-rings:
16608aa020
Phase I DOHC manifold gaskets:
14035aa281 (single gasket, not a pair, so order 2)
Phase I DOHC valve cover outer gaskets:
13270aa062
13272aa063
Phase I DOHC spark plug gaskets, these are the oval-shaped flavor:
13293aa051 (you'll need 4, 2 for each head)
pre-'99 jet-style washer nozzles
86636ac021
86636ac031
Pat
Old 09-13-2008, 01:49 AM   #22
speed_ga
Member#: 188906
1999 Legacy SUS lmt.
Black Cherry
Bracket adjuster for A/C belt tensioner.
It's the plastic pieace with the threads that the tensioner bolt screw into.
Part# 73134AC001
Cost me $6.75
speed_ga is offline   Reply With Quote
Old 10-11-2008, 09:24 AM   #23
Dan Cech
Member#: 67154
2007 Audi RS4
Avus
Default Wiper Arm with Integrated Spoiler
Part Description:
Wiper Arm with Spoiler, Left
Model:
BD/BG
OEM Part Number:
86532AC231
List Price:
$49.95
Notes/Verification:
This is the wiper arm with integrated spoiler, available on 1999 GT Limited w/ Cold Weather package.
Part Description:
Wiper Arm, Right
Model:
BD/BG
OEM Part Number:
86532AC241
List Price:
$39.95
Notes/Verification:
This is the passenger side wiper arm.
Part Description:
Wiper Arm Cover
Model:
BD/BG
OEM Part Number:
86538SA020 (x2)
List Price:
$1.66
Notes/Verification:
This is the rubber cover for the base of the arm, you need 1 per arm.
Dan Cech is offline   Reply With Quote
Old 11-27-2009, 08:47 PM   #24
Charlie-III
Member#: 30669
1998 Legacy 2.5GT
Silver Sleeper BK, 5MT
Default Master window switch set----drivers door
For a 1998 Legacy GT wagon, fits other years/models:
Part Description:
Drivers door, master window control switch
Model:
BD/BG
OEM Part Number:
83081AC071
List Price:
$159.25 (price from a dealer 11/2009)
PITA to try & work another switch in since it's a single piece with all the switches in it. If you have the woodgrain, it fits over the switch unit itself so no color is called out.
My drivers window switch failed & I could not ressurect it.
Old 04-15-2011, 10:52 PM   #25
jlklegacy
Member#: 176006
1997 Legacy GT
Spruce Pearl Metallic
hello. i have a 97 lgt and just started posting in nasioc after crusing the site for awhile. i used to be a tech but now work in a subaru parts dept., so if i can help anyone find any part numbers please let e know, i would be glad to help. i will post pcs of my car when i can. But i wil be at the don miller subaru show in June. Anyone close to the Madison are should check this show out, its always a good time
jlklegacy is offline   Reply With Quote
('93-'01) The part # thread Hondaslayer Impreza Forum 186 07-14-2016 09:42 PM
Moderators: We need a sticky part # thread! xcntrk75 Legacy Forum 42 02-13-2006 06:00 PM
